My '03 C240 (pics)
either way it all works out in the end....
I've noticed a lot of people on here get the flat hood emblem.
I'm curious as to why it's so popular. Personal taste?
I kinda like the stock ornament :-p
You may also need to use the goodbegone (or what ever it's called) to get the residue off after you remove the badges.
Congrats. on the car; Wash and Wax often. Keep her lookin Fresh
Get the W204 OEM flat emblem, direct fit
Personally. . .I think it's because it makes the car look more stream-lined and sportier. All the newer Mercedes models (roadsters, CLS, etc.) all come with the flat hood emblems now. Hmn. . .
I like both ways =)
Your car is great!
Few questions...
1. Can you explain what the 5mm H+R spacers do.
2. Can you provide photos of what the Kenwood DNX head unit looks like installed.
3. Can you provide the total inches dropped for both Front and Rear.
Thanks.
T.0. has the same year make and model car... I asked the questions to T.0. because I wanted his input... not a smartass remark about "Searching The ****ing Forum"... I'm very aware of the search feature, but thank you for feeling the need to reiterate the search button.
Will post pics soon...
What's your actual car color keithgy? Is it 040 Black?
Welcome to the Forum !! You'll find a lot of great people here, and a wealth of information.
Cintoman
Cintoman
Thanks for the welcome...
The car is black, though i'm uncertain if it's 040. I noticed you stated, that you have the "BIX factory installed" does that mean that you took your car a MB dealer and had them do the work? The reason I ask is because I'm defiantly not a mechanic
, so once I purchase them... I'll have to find someone to install them
The car is black, though i'm uncertain if it's 040. I noticed you stated, that you have the "BIX factory installed" does that mean that you took your car a MB dealer and had them do the work? The reason I ask is because I'm defiantly not a mechanic , so once I purchase them... I'll have to find someone to install them
You can tell what color your car is by looking at the VIN sticker that's mounted on the inside of the driver's door jamb. It's a black and white sticker with a barcode on it denoting the VIN, along with vehicle weight, date of manufacture, etc. Towards the right, above the bar code is a 3 number code. It might be something like 040, C040, C359, C197, etc. This is your vehicle's paint code. Beginning with the 2004 model year cars, the number code was preceded by a "C", denoting that it was clearcoated with the superhard Ceramiclear clearcoat (dramatically reduces scratches, scrapes, pits).
As for my BIX, I meant it was installed when the car was originally built, and hence, part of the vehicle's options when built. My car is very well optioned: heated seats, harmon/kardon logic 7.1 surround with CD changer, sunroof package, the lighting package (bix with headlight washers), rear shade, COMAND Nav, etc. Basically, the only options it doesn't have is the full power driver's seat with steering column memory, Satellite radio, and split folding seats.
Cintoman
