More Info on KLEEMANN K23 Tunning Kit Needed
Old 03-25-2005, 10:22 PM
  #76
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
Originally Posted by 20FHK02
I've heard rumors that there'll be a run of Flip's M271K SS vs. pullied M111 auto vs. pulied M111 6-spd. Is this still in the radar?
Depends when you're available....
Say don't you have a 6 spd?
Old 04-27-2005, 05:27 PM
  #77
slkfans's Avatar
Kleemann M271 Pulley Kit with K-Box
I have recently got myself a Kleemann M271 Pulley Kit with the K-Box, I just can't wait to it fix into my vehicle. I am holding back as it keeps disturbing me whether I should exclude the installation of the K-BOX. I was informed that the K-Box works with the MB stock ECU, however, I had my ECU tuned by MKB of germany. The question is will my engine blow up if the K-Box works with the current MKB ECU with different parameters ?
Without the Kleemann K-BOX, having to install the pulley kit, will there be any noticeable difference ?
Old 04-27-2005, 05:47 PM
  #78
tommy's Avatar
2004 Civic Si. FWD for the Win!
I was in a similar situation - had my ecu chipped by Upsolute, then wanted to install a Renntech pulley.
Upsolute said that I would have some serious issues such as misfiring if I did not get the ecu set back to stock programming. So, between overnight mailings, I got it in time for the pulley install this past Saturday.
From all dynos I've seen, the pulley itself will make much more than the reprogramming, so you'll definitely feel the difference - I know that I did.
Old 04-27-2005, 06:17 PM
  #79
BabyBenz6spd's Avatar
2005 C230 Sedan 6spd
How does the K Box work? is it plug and play?
Old 04-27-2005, 07:22 PM
  #80
nuclearhappines's Avatar
it's a piggy back system.
piggy backs work by intercepting signals headed to the ECU and manipulating them to make the ecu think that the car needs more fuel, the timing isnt as advanced as it should be, you're not at full throttle yet... whatever
basically you lie to the ECU to make it react to your lie and by doing so it actually goes ahead and adds fuel, advances or retards timing ...etc without you having to go insided the computer and reprogram it .
supposedly the kleeman k-box messes with your a/f ratio, messes with the stock air bypass valve, and enhances the feel of drive by wire.
-nuke
I would really love to know how much it costs on its own
Old 04-27-2005, 07:24 PM
  #81
ctC230K's Avatar
excites your girlfriend
i thought it was near $1000 on it's own. don't you have to ship your ecu out to them and they ship it back? not plug and play at all.
Old 04-27-2005, 07:42 PM
  #82
that's upsolute where you send it in.
the k-box is a piggy back. It's external to the ecu. you wire it up certain wires in the car and that does it
Old 04-27-2005, 08:34 PM
  #83
slkfans's Avatar
Thanks, but how do I get back my stock ECU ? This is really a pain now.....
Old 04-27-2005, 08:56 PM
  #84
ctC230K's Avatar
powerchip as well! i dont like that idea. shipping your car's computer?
Old 04-27-2005, 09:14 PM
  #85
tommy's Avatar
They have these things now called "boxes" that I hear you can put your ecu in, and they arrive without damage. :p
Actually, the ecu's in a metal case - pretty hard to damage, even for a clumsy smurf like me.
slkfans - don't know. Couple of things:
If the piggyback completely throws out the old signal before routing it with the new parameters, then it may actually not be necessary to reprogram. I'd definitely check with Kleemann on this. Secondly, if they do need the ecu at stock, is it possible to just pop it out and send it to your MBK rep? Even for a small fee, it would be much better than leaving it chipped, and risk the entire engine. I would definitely check with K, then MBK if possible. Good luck!
Old 10-17-2005, 02:33 PM
  #86
Zillarpillow23's Avatar
I have the correct pricing (or what I was told by the dealer) for the Kleemann Engine Performance kit for an 05 1.8 c230k (M271). Read it here: https://mbworld.org/forums/c-class-w203/123493-decent-intakes-1-8-when.html.
Let me know if you guys think the pricing is correct.
Old 10-18-2005, 10:35 AM
  #87
trust203's Avatar
Thanks for all the info !
Old 10-19-2005, 02:40 AM
  #88
white_w203's Avatar
is SOLD
how about NOS for $500???
Old 10-19-2005, 02:50 AM
  #89
Originally Posted by hanke
Kleeman has now released their M271 product, called KBox.
This package is made up of an electronic recalibration device that enhances power and torque, a crank pulley and a water pump pulley.
HP gain about 20
Torque Gain about 30
No ECU update necessary.
Price $1,600
This sounds like a nice package. Anyone try it yet?
Actually, the price on a Kleemann engine performance kit more like $2100 without installation which is around $250 for a 3 hour procedure. Already quoted. Read here: https://mbworld.org/forums/showthread.php?t=123493.
:v
Old 10-22-2005, 05:27 AM
  #90
Can this pulley kit be used for a c230?
http://www.evosport.com/product/prod...VO.PER.M03.PK1
:v
Old 02-15-2006, 04:32 PM
  #91
tifosiv122's Avatar
SLS AMG | S65 AMG | GL550
Smile Jumped head-in today, ordered Kleemann kit + header for M271
Hi guys, long time no post...sorry I've been very busy. I decided last night that it was time to put a bit more pep in my Coupe...so today I went and ordered the Kleemann Engine Performance kit and the Kleemann Header for my car.
In case your not sure of what it contains, it's supposed to be pulley set, high airflow filters, K-Box, and then finally the Header. I was told to expect 40/40 but I'll be happy if I see half that on the Dyno. I've been thinking about it on the ride home and I'm going to do 9 Dyno runs, 3 before, 3 after kit, 3 after headers.
I want to thank MotorWerks in Michigan for making me feel right at home and for the wonderful tour of the facility...seeing all those Mod'd Benz's made me want much much more.
I'll post the results and pictures when everything is done...I think the kit should be sometime in the next week or so, and the headers shortly afterwards.
Any opinion on if I should get the Kleemann engine cover? I'm not doing any visual Kleemann mods on the outside (badges, etc).
Anyway, had to tell someone!
Erik
Old 02-15-2006, 05:13 PM
  #92
MiKeSSw203's Avatar
Location: South Coast Metro/Cerritos/Yorba Linda California
'05 C230K '10 GLK350 '13 SMART
Congrats!
I'm jealous
Keep us updated on the project
Old 02-15-2006, 07:48 PM
  #93
Blake P's Avatar
'09 A4 S Line
I thought the M271 Kleeman pulleys were impossible to buy new these days?
Old 02-15-2006, 08:41 PM
  #94
electromethod's Avatar
Honda Grom
Long time no see eric.... congrats mang! Hope you don't dissappear on us again!
Old 02-15-2006, 11:08 PM
  #95
tifosiv122's Avatar
Better not be, I paid in full
We discussed going the Carlsson, Rennech, or Brabus route...Brabus giving the best results but with major engine modification, however, they suggested, for best bolt-on bang for the buck, to go with Kleemann.
AFAIK they called and checked everything out with Kleemann which is how they knew about the headers that aren't out yet.
Erik
Old 02-15-2006, 11:40 PM
  #96
white_w203's Avatar
is SOLD
so they do still sell the kit?!?!?
Old 02-16-2006, 12:28 AM
  #97
tifosiv122's Avatar
AFAIK. They list it on the website and I assume MotorWerks was able to place the order, I guess I missed something along the way, was it supposed to be discontinued or something?
Erik
Old 02-24-2006, 12:54 PM
  #98
tifosiv122's Avatar
Got the call yesterday, my pulley kit is in, install will take place on monday. I am doing a before dyno, but not an after pulley dyno...I'm going to wait for the headers...as much as I want to do it, I don't feel like spending the extra money...especially since I just had to buy 4 damn new tires.
Hopefully some pics on monday.
Erik
Old 02-24-2006, 01:19 PM
  #99
Super Moderator Alumni
drexappeal's Avatar
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Erik,
That's awesome. Keep us updated on how it goes and congrats!
Old 02-24-2006, 03:14 PM
  #100
white_w203's Avatar
is SOLD
Erik
i must be trippin. i thought kleemann didn't sell/make them anymore. you'll be happy with your kleemann mods
Quick Reply: More Info on KLEEMANN K23 Tunning Kit Needed
