help - key problem
After a drive, I switch off the ignition, pull the key out, get out
of car and try to lock car using the remote key button, but nothing happens. I then have to re-insert the key back into the ignition several times before the remote key works. This is getting to be a nuisance.
Has anyone ever had this problem and knows its cure ?
However, I have no problem starting the car at all.
I bought to car from parallel importer (not main agent) so not getting the proper support on this.
As my other car has trouble unlocking via remote around areas where mobile phone tower are insight, although it isnt an mb.
The problem I have occurs daily. I think I will bring the car
to main dealer eventho that will mean I have to pay equivalent about us$ 400 just to register ! and let them check it out.
I suspect It must be the ignition module thats faulty.
happy driving
Thanks guys for all the response. I am from Singapore.
happy driving
Have you sent your car to the main dealer (C&C)? If not, you may want to try "re-setting" the remote - the procedure is in the manual. It works for my SLK - don't know whether its the same for the C-Class.
Good luck.
Good luck.
fcdry: check the serial number on your key near the panic button. if it doesn't start with 221 then your key is faulty. this is a known issue.
Jerry
my key was sorta like dat... it won't open the door... i had to use the metal key... and the alarm will go off... BOTH keys... so no battery problem. i had the car for bout 2 weeks. i took it to the dealer... and the car suddenly starts workin again. :o
Jerry
You need to use spell check and better capitalization.
Both my keys are 217 as well and I've had the car since 10/2001, never had a problem with my keys.
