Vibration and Slippage - Help?!
C320
Whats up guys? Let me start off by saying I'm not car savy really, and dont try to be. But I'm having some issues with my 2002 C320 and hope you guys can help.
First issue...when I start braking and come to a slow stop I can feel my left front tire skipping and some bad vibration. I can feel it mainly in the brake pedal (if thats possible) and in the steering wheel.
Second issue...my transmission is not shifting gears that smooth all the time. Most of the time, I never notice anything, but at times it jerks when shifting gears. Its really bad in the morning when I first start my car.
Third issue...I've noticed that when I accelerate pretty hard, my car doesnt seem to have as much torque at times. I can really tell when I try to get on the interstate, sometimes I "floor" it and I'm impressed with the acceleration, then other times it just creeps.
I just had an oil change, filter, blah blah blah... The spark plugs were replaced about 4-5 months ago and tires about 3-4 months.
Any ideas?
Thanks guys!
Any ideas?
Thanks guys!
Any ideas?
Thanks guys!
Any ideas?
Thanks guys!
Second issue, sounds like the Glycol contamination issue. You can perform a search in the W203 section and see what I'm talking about. It's in regards to a particular radiator that came with our cars which malfunctioned prematurely and let coolant seep into the transmission cooling lines that run through the radiator. I have one of these radiators (Valeo) and am switching it out just in case. I think your third issue may also stem from this problem as well.
'02 CL203 M111
1) That sounds like the control arm needs to be replaced or it could just be an alignment issue.
2)Not sure about here but it could be an electronic adjustment issue. Get it diagnose, check the torque converter.Assuming the tranny fluide has been changed at about 60k miles. (current milage?)
3) That could be anything even the use of cheap gas that clogged the injectors, use techron.
Wait for expert in M112 to chime in.
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
For your first issue, I would have to guess that it may be a warped brake rotor. Do you only feel it when you are braking? I'm not sure what you mean by "left front tire skipping".
This might sound like a dumb question but this Glycol issue is unheard of in South Africa. How do you know if you have a Valeo radiator???. I've looked at mine and see no identification at all that's obvious. Is it all in the part number/VIN number? Maybe SA built cars never had Valeo radiators???
Your help with this would be appreciated. I'm not having any problems - but like you don't want to have any either.
Try here:
https://mbworld.org/forums/2254029-post59.html
https://mbworld.org/forums/c-class-w...ase-chime.html
https://mbworld.org/forums/c-class-w...do-i-look.html
pics: https://mbworld.org/forums/c-class-w...placement.html
I've never checked myself. During the 75k service, I asked the mechanic to check it and let me know, and he advised that I didn't have the Valeo.
C320
Thank for the help guys. I've had my tires rotated with no help, I was told that it was most likely my rotor had warped. I noticed after a long trip to Mississippi so it very well could be.
And thanks for the suggestion with the tranny, I'm looking into that now!
Pete,
Super Moderator
Super Moderator
My auto box is beautifully smooth - I did not want any damn glycol messing that up. I can just imagine what it does to the friction materials in the box - plus glycol barely manages to lubricate a water pump seal adequately.
