2006 C280 suddenly lose audio system
Old 01-28-2009, 01:26 AM
autojava's Avatar
C280 2006
Hi, Guys:
The audio system work fine on the road when I sent my daughter for piano class. One hour later, when I start the car, then audio system has gone.
There has radio station (FM 101.3) or CD track info, but no sound. Also, when I select CDC, it says no CDC. I try to adjust the volume, nothing happens. The switch on/off button works fine though. Any idea?
Old 01-28-2009, 05:13 PM
autojava's Avatar
C280 2006
Hi, Guys:
Funny thing happen. At this morning in my garage, I start the car and prepare to go to the dealer. But teh audio system come back as normal and like nothing happens. Tonight I will take a test and park the car out of garage, and then start at tomorrow morning, if the problem happens, then I can know the issue is related to temperature.
Regards.
Old 01-28-2009, 07:35 PM
RIGOROD01's Avatar
2006 c230 sport
damn
this happen to me too my radio was on but no sound ... went back an hour later started the car all of a sudden everything worked
Old 01-28-2009, 08:58 PM
BF_JC230's Avatar
2005 w203 C230
STF...Mine happened out of the gate - Dealer tag states it was a bad AMP...Do you have the HK sound sytem with the AMP?
Jake
Old 01-29-2009, 12:57 PM
autojava's Avatar
C280 2006
HI, BF JC23:
How do you make the dealer believe that this happen when you arrive the dealer and the radio work fine at dealer lot? Also, AMP means amplifier? Does the dealer replace it for you? cost?
Rigorod01:
How about yours? Is it solved, or not happen again?
Regards.
Old 01-29-2009, 06:33 PM
RIGOROD01's Avatar
2006 c230 sport
The radio works fine, I even check the amp for burn wires or any burn smell but no issues there ...
Old 01-29-2009, 09:00 PM
BF_JC230's Avatar
2005 w203 C230
I am not 100% sure - I did not scan it or do the work - But the scan tool must have come back that CAN B was upset and the HK AMP was not active or functioning properly - So they replaced all under warranty -
I also am not 100% sure - But I read in some posts that the head liner (YIKES!) needs to come down to replace this AMP...if this is true - I am not sure why the great engineers at Mercedes-Benz did it that way...
However if you need to pull it down, you may want to look into installing IMS parts...If I had a good answer and knew about the issue (actual problem) I would have requested the IMS parts installed - IF - The headliner was pulled...I hope it was not...
Good luck,
Jake
Old 01-29-2009, 09:55 PM
UK-C200's Avatar
RHD C200 Sport Coupe, RHD SLK-55, LHD SLK-350
Good luck,
Jake
HK Amp's in the boot, so no clue what they would be doing with your headliner. Most common problem when you have no sound and your changer disappears is a loose or faulty fiber optic cable.
Old 01-30-2009, 09:02 AM
BF_JC230's Avatar
2005 w203 C230
Thanks UK-C200, I have also read that...So that is why I am stating I am not 100% here. I read and would think that an AMP would be some what large and located in the trunk...
Here are some shots from my trunk...With HK sound.
Here is what I read (One post) on the head liner from the wonderful web...
"alright so i recently got my car tinted...after tint..radio sucked bad and keyless entry only worked when ontop of the IR sensor and only within a handful of times actually worked. talked to the tint place..apparently they put metal tint on, so i had them remove it and before they put non-metallic tint we checked everything..nothing works still. so i took it to mercedes today and they said that the antenna amplifier somehow got shorted or the glue from the tint messed it up, but they also said that if they push on the headliner the right way that they can get the radio reception to be perfect and the remote to work fine but suggested it be replaced at a very cheap cost of 1350$. oh and i forgot to add that i did illegal 15% tint so therefore have no documentation of the tint job being done because here they won't give u a receipt and u have to pay in cash. well the nice people at the tint company won't pay for it and i obvioulsy can't sue. so i'm left with how can i fix it myself somehow. obvioulsy the connectors might be messed up a little but if they can get it to work perfectly fine with pushing its not completely fried to the point of 1350$ they just want to screw me. so i'm wondering if there is anything i can do, maybe a specific place to push or perhaps a fuse that might help if replaced? any sort of thoughts on the issue would be awesome! its also a 2005 C230 kompressor..figure that would help HA thanks!"
"so i tried messing with the headliner finally and when i pushed in the upper left corner where they told me..i didn't get the radio reception or the remote reception they said they noticed..i even pushed on the sensor itself because a hand can fit behind it easily without breaking the plastic peices that have to be removed to bring down the headliner...hopefully mercedes didn't purposely sortof make it less activating so that i would need to have it replaced instead of just being able to fix it...the replacement ant. amp. is about 400$ and somehow that merits 900$ worth of labor? insane i wonder if i could just snag one off a c230 that got wrecked or something."
Thanks all - Let's try to clear this one up - and the location of the AMP, antenna, connections etc...and it maybe here on mbworld - just need to STF.
Jake
Attached Thumbnails 2006 C280 suddenly lose audio system-2005_w203_trunk_right_hk_1.jpg   2006 C280 suddenly lose audio system-2005_w203_trunk_right_hk_2.jpg
Old 01-30-2009, 09:12 AM
jscavo's Avatar
w203
had similiar issue. sometime it would work sometime it won't. dealer indicated there was a pinched wire in the truck area. not sure if it was optical or copper.
Old 01-30-2009, 12:48 PM
autojava's Avatar
C280 2006
Hi, Guys:
I check the papers, and my car has
320: Entainment Package which include
810: Harman Kardon Sound System
819: 6-Disc CD changer.
Symptom:
1): Audio Display is on.
2): Radio Station Info is on, but no sound.
3): CD track info is on and going forward, but no sound.
4): CDC can not be detected.
Old 01-30-2009, 05:29 PM
autojava's Avatar
C280 2006
BF JC230:
In your two pictures, could you tell me which wire are loosed and caused the problem?
I still not clear. Best Regards.
Old 01-30-2009, 07:21 PM
UK-C200's Avatar
<SNIP>
Jake
So I'm not sure what you want to clear up? There are a number of devices called "AMP"s in your car. You have taken a picture of one - the audio amp that's in the boot of the car. This amp takes a line level audio via the MOST fiber optic bus and converts it into output level sound signals to drive your speakers. A symptom of the failure of this amp is no sound from speakers when playing CD or Radio, but CD changer "seen" by headunit.
The other amp you are talking about from the post is the Antenna Amp - it takes a signal from the cars aerials and amplifies it, and sends this amplified signal to the radio tuner.
This amp is located under the headliner above the rear window in a C class, and working on / replacing it would require removing the headliner. A symptom of the failure of this amp is very bad / no reception on the radio.
The physical antenna is up there as well, but different depending on options installed. Connections is kinda a hard question to answer in a car with a couple of miles of wire, and a few feet of fiber - so I'm not sure what you are looking for here?
Old 01-30-2009, 08:10 PM
Super Moderator
Glyn M Ruck's Avatar
Check for kinked fibre optics. Also realise. These system all have microprocessors in them these days. Repowering will reboot these and you might not have any further trouble - hold thumbs!
Old 01-31-2009, 01:12 PM
BF_JC230's Avatar
2005 w203 C230
Thanks UK-C200...My problem is why I posted the trunk here...I had no sound at all from any source and I also had a reading of "NO CDC" when trying to access the changer...
This is the info I have...
Found faulty sound amplifier
SDS test. Code D101. Tested audio circuit and traced to faulty sound amplifier. Replaced amplifier. Cleared fault code. Retest. Operation OK.
Parts
1 x 169-820-80-89
Thanks,
Jake
Old 07-05-2009, 08:42 PM
CHiKompressor's Avatar
2005 c230 S.S.
just had this happen to me yesterday same exact thing everything "works" fine just no sound at all and NO CDC when accesing the cd changer. can anyone direct me to which wires/ where i can check if the optic cables are pinched? BTW sound came back today so all good for now. Tx
Old 07-07-2009, 11:05 AM
LeifW's Avatar
2005 C230 Sport Sedan w/Automatic
This happened to me as well when I first purchased my car. Eventually (several months later), the sound stopped all together. Luckily I was still under warranty. The AMP was replaced. I have the HK system. I asked the dealer if I had to foot the bill, what was the cost. They told me that the AMP alone ( without installation) was over a $1,000. Yikes!
Leif W.
Old 07-07-2009, 07:45 PM
SteveAustin's Avatar
2005 C230 Kompressor Sport Sedan
Mine also replaced under warranty, no problems since 2005. Also, they replaced cable to changer as it was damaged so I also had the CDC static issue on top of that.
Old 07-08-2009, 02:22 PM
2005 c230 S.S.
damn seems like an expensive fix. do you guys have a part number for the cable?
Old 07-09-2009, 08:52 PM
mtnman82's Avatar
'16 E350, gone: '03 c230k
I recently came home from a trip and had the trunk fully loaded withstuff. No problems on the way there or while there, but on the way back I started homoe and had no sound - radio & everything seemed to work, just no sound. After I got home and unloaded the car I went out to troubleshoot and everything worked just fine, and has been ever since (that was ~ 2 weeks ago). I was thinking I had unplugged a cable, but maybe I pinched one?!?
Old 08-21-2009, 02:57 PM
2005 c230 S.S.
just happened to me again yesterday. After a little forum search and some exploring on the car i found the solution so in case this happens to anyone try this first. in the drivers side fuse compartment take out fuse 26 it should be 25A and white. I took it out inspected it and it seemed fine plugged it back and the audio came back immediately
Old 08-21-2009, 05:05 PM
MiKeSSw203's Avatar
Location: South Coast Metro/Cerritos/Yorba Linda California
'05 C230K '10 GLK350 '13 SMART
I have to try that next time. HAd this happen to me before couple times actually. I noticed if I unplug the fiber optic cable on the changer and plug it back in it would work again
Old 08-23-2009, 10:06 PM
2005 c230 S.S.
this is good!!! thanks for an another possible fix mike. I noticed when i was looking at the other threads seems like everyone posted that this occured to them but no one really posted how they fixed it unless it was under warranty and the dealer replaced either the CDC or the amp. Mods maybe we can sticky this for harmon kardon users
Old 08-24-2009, 12:55 PM
autojava's Avatar
C280 2006
Hi, Guys:
Which one is easier - Unpluging the fuse 26 or fiber optical cable?
Also, based on my observation, my kids sit at passenger side and press music buttons one after another (for button A and B) very fast such that the fuction of button A does not happen yet and button B has pressed. Then no sound. I'm not sure these have directly related though.
Old 08-24-2009, 03:15 PM
2005 c230 S.S.
not sure which one is easier, for the fuse though all you have to do is remove the plastic cover on the drivers side (look in the manual for a picture) take out look at it see if its burned out and replace it if needed. worth giving it a try rather than spending $1k at the dealer for a new amp if thats even whats really wrong with the system.
Quick Reply: 2006 C280 suddenly lose audio system
