EIS replaced
Old Feb 12, 2009 | 05:00 PM
DarthBudice's Avatar
08 E350 4MATIC
EIS replaced
If anyone is interested, I had my car's EIS replaced several weeks ago.
Her symptoms were 5-10 iterations of no-cranking each cold start before
finally cranking. I also noticed the steering wheel buttons were failing to
work until the interior started to warm up (not to be confused with a slow
responding LCD panel) and every once in a while I would get a single cycle
from the wipers for no apparent (to me) reason.
It started out as a single no-crank (sometimes two) which I initially suspected to be a problem of the key (it had developed a crack at the edge
of the lock button). Unfortunately it became progressively worse and worse
(as temperatures stayed well below freezing) to the point the key wouldn't
always authenticate, and the MFD would frequently continue to insist
"REMOVE KEY!" after it had already been removed.
After it was replaced (and I might add my new key looks pretty sweet!)
she hasn't given me one issue... except my ashtray cover had a nice 2.5"
squiggly scratch that was promptly replaced at no cost.
Perhaps this can help others.
Old Feb 12, 2009 | 05:06 PM
Glyn M Ruck's Avatar
Super Moderator
Thank you - Averyone I know that has had EIS issues seems to find that the problem is exacerbated by low temperatures - that seems to be confirmed here.
Old Feb 12, 2009 | 05:36 PM
WaveyKat's Avatar
Something Slow
how much was it to Replace this Unit? and do you have the Part Number?
Old Feb 12, 2009 | 05:38 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Interesting symptoms. Never woulda guessed the EIS.
Wavey, don't really matter on the pn, it's not user replaceable.
My local guy showed me one...said it was about 500 bucks for the part,
is ordered by VIN, comes with a special code to be entered into the
SD to register it with the ECU. Not a DIY job.
Old Feb 12, 2009 | 05:44 PM
08 E350 4MATIC
Total cost was $1,112.19. This includes tax, $201.50 for the new key/blade,
and $12.66 "chemicals and fasteners" - sorry for the full detail, I analyze a
6-digit telecom bill every month. =)
From my invoice, the EIS was 203.545.06.08.
Strangely enough, I was originally quoted nearly $1,400 (key not included).
Old Feb 12, 2009 | 05:56 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
What year is your car?
Old Feb 12, 2009 | 06:00 PM
08 E350 4MATIC
It's a 2001 with 110,000 miles.
Wonder why it's not being displayed any longer...
Old Feb 12, 2009 | 06:01 PM
LILBENZ230's Avatar
This seems to affect just the earlier 2001-2002 models. I wonder if they changed stuff for the later ones? Mine is an 05.
