M271 Oil Filter Question...
#51
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Guys - This is exactly what I was worried about with paper filters - They simply can't do what the fleece does. Jeff does not come from a dusty area and the moderate silicone levels (12ppm) show this to be true - Imagine if the dust levels had been high, the results would have been even worse - I don't buy Blackstones comments on normal filtration - yes, normal for paper. In fairness - they were not briefed on what we were doing here.
Anyway - reduce oil drains on paper filters until this is resolved - you obviously can't go 13,000 miles - I would like to see Jeffs next sample at 8,000 to get a trend.
Interesting, fortuitous timing - I had dinner last night with Phillip Johnson. One of Donaldson's global VPs from the US - He's a pom I've known for 20 years, & Andre Wessels his local Ops Manager. Mann + Hummel is well known to Donaldson. I raised the issue of Hengst paper vs. Mann fleece with them & they concur that the paper filter is not going to cut it for long drain - especially 20,000 Km or 13,000 miles.
#52
#53
Super Moderator
I will gladly get involved with issues OIL. Yes mleskovar - one swallow does does not make a spring which is why I would like to see a trend. This oil certainly has not done double distance or there would be other indicators like higher silicone. Jeff - do you have the cars service book? If so, does it appear to be in order?
#54
Super Moderator
BTW - It appears within reason to be Mobil 1 - it's 0W-40 & the additive signature is correct - the high temp Moly anti-ox is there. The detergeant/dispersant (Calcium) has taken a bit of a beating but I expect that in this case. Wish I could run my own IR scan.
#55
Super Moderator
...Interesting, fortuitous timing - I had dinner last night with Phillip Johnson. One of Donaldson's global VPs from the US - He's a pom I've known for 20 years, & Andre Wessels his local Ops Manager. Mann + Hummel is well known to Donaldson. I raised the issue of Hengst paper vs. Mann fleece with them & they concur that the paper filter is not going to cut it for long drain - especially 20,000 Km or 13,000 miles.
Perhaps it’s a vast conspiracy to hasten their demise and prompt new car purchases. ;-)
Fit a fresh Mann+Hummel to the M112 last Sunday:
![](http://i209.photobucket.com/albums/bb196/splintersAMG/hu7185x.jpg)
#57
Super Moderator
Seems counterintuitive that they’d discontinue the proper filter for an engine still in widespread use.
I drove into my dealer today to have my power steering fluid topped up. It squawked at me this morning at full right lock coming out of my garage. Idiots obviously did not top it up at the recent service - nice & quiet now. They are definitely still using fleece on the M271 here.
#58
Super Moderator
Yes - Get rid of the Fram - no good! The K&N is a Mann fleece repackaged. Just make sure it looks like the K&N & MANN pictures I posted early in the thread.
#61
AMG GTS
Just went to San Francisco's Parts Department (8th street and Folsom I believe) to pick up an oil filter. They're still selling the Mann Fleece oil filters. But for $25 a pop.
![action](https://mbworld.org/forums/images/smilies/action1.gif)
#64
That's a good price. I went to an auto store known as AutoZone and a K&N Oil filter was $25.00 and I said I rather go with the original.
I found this website it says all the parts are genuine and you can get an Oil Filter for $17.25 but I don't know if it fleece.
http://www.trademotion.com/partlocat...layCatalogid=0
I guess I can send them an E-Mail asking if it's fleece.
#65
2005 C230K Sport Sedan, 6 speed manual
Unlike some others on this board, I live in an area with a lot of blowing sand and dust. This is why I change my oil and filter at 5000 mile intervals. I also change the air filter and cabin filter at short intervals, since they get dirty so fast.
So my question is: is the new paper oil filter good enough, given the short drain intervals, but extreme conditions? Mercedes is a fairly rare car here, so aftermarket parts are not too common. Of course I still use the 229.5 Mobil 1 0W-40 synthetic oil.
Incidentally, my BMW (M54 engine) also uses a paper oil filter element, but it is much larger than the Mercedes M271 filter.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
#66
Super Moderator
If you are changing at 5000 miles & your air filtration is good you should be just fine. Have a sample or two analysed if you want a definitive answer.
#68
The Mercedes will stay home tomorrow anyway. We are expecting 60 mph winds and blowing sand. Nothing like the convenience of having the Chihuahua Desert on your front door step.
#69
So is it safe to say that the fleece filters no longer exist for a 2005 1.8L? No one can seem to find one (including me). I'm tempted to just buy the M&H filter from germanfilters.com.
I alos found both the Mann and the Mahle filters here:
http://euro.bmpdes********/OEM/viewPr...pID=Oil+System
any difference in the two?
#70
I used to buy a lot of parts (mostly Volkswagen) across the border in Ciudad Juárez, Chihuahua. The dealers there sometimes have parts unavailable in the US. Unfortunately, Juárez has now become so dangerous with violence that I haven't been there in over a year. When things settle down along the border, perhaps we can see if fleece filters are available through Mercedes Benz de México.
#71
Super Moderator
#72
an oil change is going to be necessary very soon. if i up the interval, what sounds prudent? half of what's recommended? could i just change the filter every 5K and change the oil every 13k?
#73
Super Moderator
Used filters work better than unused - so doing a halfway filter change makes no sense. Drop your change interval to 9000 miles & do an oil analysis when you have put on 9000 miles & see what the oil looks like. I'm hoping you guys won't have to halve drain interval.
#74
04 C230K SS 6Spd Manual
Where to buy the fleece filter
Guys,
Where can I get this fleece filter? My service A is "due now", and every freakin dealer I've called (MB of Greenwich, White Plains Mercedes, and MB of Larchmont), they only have the paper one. I've also tried to google the part number, but no luck. Please help, thanks
