Has anyone actually fixed the radio receiver problem: U have to be 2" away to lock/u
2002 C240 Sedan
One day, the car suddenly stops receiving inputs from both my keys unless I point it at the IR receiver on the door handle one inch away. Great, so I change the batteries in both. Still, I have to be one inch from the door handle to lock or unlock and that is iffy at best.
I purchase a new key with skeleton. $200 with tax. Ouch!
Same problem, except I can be two inches away from the door handle.
I am assuming this to be a radio receiver problem in the headliner. Has anyone fixed this themselves? If so, how and what parts.
I will do a DIY on this to post on my site but I need help to get that far.
Other notes: Radio reception seems fine. Windows are tinted.
TIA!
2002 C240 Sedan
TIA!
On a side note, i'd like to thank for your website wizkid. Its helped me a lot, looking your maintence diy's.
- Check wires not cut from rear screen when applying tint.
- Check stick on connector under center rear roof lining
- Check antenna amp earth in rear C panel
- Check antenna amp is not blown
Do a nice DIY for us.
Good luck
Here is a comment I posted earlier
"Yes the Aerial is built into the glass. The Amplifier is mounted above the rear screen on Coupes & in the LHS C pillar in sedans.
If tinting has been done then water frequently shorts the antenna & blows the RF amplifier or when trimming the tint they cut through the wires/traces as they exit the glass.
Metallised mylar tints frequently ruin radio & remote reception. Radio & remote share the antenna/aerial - Only option - remove & replace the tint.
So we have 3 potential problems.
- The tint itself
- Bad amp earth
- A blown RF amplifier
- A damaged antenna trace in the glass or wiring above the glass
The worse case scenario requires replacement of the rear window. The amplifier replacement is relatively easy."
Install University rocks
010 2038206489 001 AMPLIFIER ANTENNA
010 2038206689 001 AMPLIFIER ANTENNA
010 2038209889 001 AMPLIFIER ANTENNA
010 2038270742 001 AMPLIFIER ANTENNA
010 2038271942 001 AMPLIFIER ANTENNA
010 2038200989 001 AMPLIFIER ANTENNA
010 2038206889 001 AMPLIFIER ANTENNA
010 2038206989 001 AMPLIFIER ANTENNA
010 2038207289 001 AMPLIFIER ANTENNA
Good luck
...no I didn't have command....also this is what the SA had told me...so I can't say that was the cause/cure for sure...but I can't see why he wouldn't tell what was what...
I was getting the no reception from far, and limited results from within 2 inches with the IR. I tried changing batteries at first, but that did not fix the problem. I then tried to use my spare key from a distance and it did not work either.
So I assumed that i must have a bad amp or receiver since neither key was working. This morning I began to check all the fuses (all good) and the ground (good as well) to try and track down the problem.
On a fluke I decided to use my spare key, since I have never used it since I got the car. I put the key in the ignition, turned on the power to make sure the car was recognizing the key till I saw the SRS light come on, and listed to a little bit of music as I contemplated how much this was going to cost to fix (maybe about 20 seconds).
After removing the spare key from the ignition I tried again to use the key fob and like magic it all worked, both keys, from at least 50 feet away. I don't know the technical reasons why this worked. My best guess is that the car needed to recognize both keys after I replaced the batteries in order for it to allow the remotes to work properly.
Recap: If you have replaced your batteries and are now not getting any reception go take both keys and place them into the ignition and turn to when you see the SRS light come on.
I may have just gotten lucky, but i didn't know this and it hasn't yet been addressed in this thread at least.
Good luck.
Special thanks to Glyn for all the information as I tried to track down this problem.
Good luck.
I cant try this because i have only one key...
