How do I make that function: Hold Lock/Unlock to Close/Open Windows work.. Better?
I've searched the forums, but maybe my search parameters weren't as good... but I've learned that I have to 're-sync' my windows to essentially make the 'summer function' work properly.
The 'summer function' I'm talking about is the neat little windows open/close thing when it's hot and steamy in your car or you forgot to close a window and don't want to go back into the car just to close it =/
So... from what I've read about re-sync'ing
You essentially open/close all your windows and Hold it for 5~10 seconds in that depressed state; all the way.
I've gotten my windows to respond; ie: open when I hold unlock and close when I hold lock to work after 're-sync'ing'
But when I tried it again later in the day.... it didn't work again =(
Anyone have some insight into this?
I like how cool it looks, but it's kinda' embarrassing when you say, "Hey guys, lookit thisss!" and nothing happens...
~J.
The "eye" (IR Reciever) is ONLY on the driver's side door handle; it's a little matte black looking square next to the keyhole. Point your smartkey at it at no more than 2-3 feet. Check your batteries too.
It works when I sync it right, but never consecutively after
I heard a lot of people have trouble with them too
I'm going to have to try this during my lunch break. (NOW) haha
Pretty neat feature.. I had to pay extra to have this done to my Titan. Opens & Closes the Sunroof too!
Thanks Jimmy!
But it just frustrates you when it doesn't since it worked before =/
Functionality is there; from MB... but the reliability part... haha.
The old idiom goes, "The more gadgetry advanced you become the more problems you incur from said gadgets."
Well... I have to go in for warranty stuff eventually anyways.
Do they cover cracked (side mirror signal glasses), fogging up Fog lights and a mal-functioning rear light?
The one that turns on if you turn your lights to the brightest function and pull it out two clicks? My right one is out... and is noticeable when the left one is on...
I haven't tried the key method, but it should work as it works for other cars I've used, but I'd much rather prefer the fob-key method
Spring Break come faster!
I don't think they'll cover cracked lenses, though. That's not manufacturing defect.
So the rear fog (double click) is only on the driver's side?
If that's so, then it's an actual oem thing, and I don't have a problem.
But as for that crack on the driver mirror and the fogging up of my driver side fog lens
