thumbs up - H&R rear sway bar
Old Mar 13, 2009 | 09:41 PM
mlg's Avatar
mlg
06 C350 sport 6MT
installed 1 on my car -06 c350 lowered w kw v2, corner balanced, -1.5 degrees camber, zero toe, on suuuuuuuppper sticky tires--- took me, a novice 3 hours , would take me 2 the next time,,,, took car to my favorite east tn mountain road and it was a blast, more balanced and better turn in, very much worth the price $189 plus ship from tire rack, shout out to MRGM1 and splinter who recommended this upgrade and they were RIGHT ON. ,,, "Happiness IS the next corner"
Old Mar 13, 2009 | 10:59 PM
Glyn M Ruck's Avatar
Super Moderator
Good to hear - Everyone says this mod really transforms the cars handling.
Old Mar 14, 2009 | 11:14 AM
T.O_c240's Avatar
'15 C400, 03' C240, '79 240D
Good to hear. Im interested in getting a set of Eibach sways soon. Did you just do the rears?
Old Mar 14, 2009 | 12:56 PM
wawy's Avatar
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
+1
...did this when I had my C32 and it definitely helps!
Old Mar 14, 2009 | 12:57 PM
Super Moderator
People say it's the rear one that makes the big difference - you agree?
Old Mar 14, 2009 | 01:02 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Anyone know the magic rear sway diameter that makes your car balanced (ie BMW-like) WITHOUT triggering oversteer?
Old Mar 14, 2009 | 01:08 PM
Super Moderator
I think it's hell to trigger oversteer on these cars but I would like that dimension too - did AMG get it right?
Old Mar 14, 2009 | 01:17 PM
slammer111's Avatar
The question would be if anyone has done a rear bar ONLY (stock front, stock springs + shocks) and found the magic number.
Having AMG front + back definitely makes things more balanced, but there is still slight understeer. (probably for my own good )
Old Mar 14, 2009 | 02:19 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
As I've said in the past, for the coupe at least,
with it's big butt hanging up in the air,
a thicker rear bar in combination with the AMG front bar is a good combo indeed.
No oversteer, not by a mile, but now at speed on a curvy road,
it grabs in front whereas before it just kinda pushed, and at times that was pretty scary.
Still not as balanced as a BMW but closer.
In fact driving an M3 was the thing that made me realize that the
1500 I'd spent on CO's AND the AMG bars just weren't enough, my car still handled like crap compared to the perfect balance of the m3.
Swapping in the H&R rear 19mm bar vs. 16 mm AMG bar made all the difference.
Maybe could even be a little thicker??? But someone would have to try it.
So for you Slammer, spend the 170 bucks, get it on ebay it's a no brainer.
Old Mar 14, 2009 | 04:29 PM
whalebird's Avatar
2005 c230
Good post MLG. I would be interested in this mod. I am not clear if this is simply a rear bar w/stock front, or am I missing the front bar mod in the OP. I would want to maintain a nice balance and just a rear bar mod seems like it could go to far without some kind of compensation in the front. Sometimes a simple matter of eurothane swaybar bushing can make a nice, suddle differance. If These types of bushings are available, I don't know about it, but I would love to do this type of mod. If all things can stay stock, I would do this rear bar in a heartbeat. A full spring/shock setup is out of the question right now for me.
Old Mar 14, 2009 | 06:01 PM
Super Moderator
It sounds like 19mm H&R rear sway is the trick - It's not just the diameter - it's the material it is made from & it's effective spring rate.
Old Mar 14, 2009 | 06:33 PM
bumpnzx3's Avatar
W203 C230SS
I say this should be a thumbs up to H&R in general. I had their springs and sways on my Focus and loved them. I also have their springs (Koni yellow shocks/struts) and sways on my MB- love them on this car also.
Old Mar 14, 2009 | 06:56 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
IMO if your car does not already have the thicker front sway bar you should do the front+rear. Unless you already have the AMG front bar which is 20mm then the H&R 19mm rear bar would be a good combo. If you want a even stiffer setting Eibach's 24f/22r will do the trick even better.
Old Mar 14, 2009 | 07:35 PM
Super Moderator
Thanks Frank
Old Mar 14, 2009 | 09:30 PM
mlg's Avatar
mlg
06 C350 sport 6MT
i have stock amg front, i only replaced the rear and it made a subtantial difference, only down side is a slightly increased harshness over rough street, after extreme perf tires, i think this mod is THE best bang for buck to increase driving pleasure in this car.
Old Mar 14, 2009 | 09:45 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Cool. Pleased the rear H&R anti-roll bar worked well for you – in conjunction with your other mods.
Chassis tuning returns tangible dividends every time you’re behind the wheel. No WOT necessary. Tweak the underpinnings to properly unleash the car for which you’ve already paid.
Works for some of us…
Old Mar 14, 2009 | 10:10 PM
91RS's Avatar
2016 Chevrolet SS, 2006 Cadillac STS-V
So is the consensus to only do the rear bar and leave the front alone? My 06 C230 is stock (I have the AMG bumpers and brakes, not sure if that does anything with the suspension), should I do both sway bars or just the rear? At this time I have no plans to lower, but I won't rule that out for the future. Would that make a difference in which bar(s) to go with? As for the front bar, does anyone know any way other than to disassemble things to know if I have 10mm or 12mm end links?
Old Mar 14, 2009 | 10:13 PM
Mu9enx's Avatar
01' C32o
just got a complete set of Eibachs on ebay for 320 shipped. can't wait to put them on.. :P no more squeaking!!
Old Mar 14, 2009 | 11:39 PM
bumpnzx3's Avatar
W203 C230SS
you have the amg bars with 12mm end links.
Old Mar 15, 2009 | 12:41 AM
mlg's Avatar
mlg
06 C350 sport 6MT
splinter is right, mercedes makes a good car, with a stiff and solid foundation ,,, with a few tweeks the car really shines, if u like to DRIVE, do the rear bar, u wont be sorry
