help in sound system instalation
Old Mar 19, 2009 | 07:59 AM
wanteed_ss's Avatar
mercedes c230 kompressor 2005
Exclamation help in sound system instalation
hello all, i have a c230 komp 05 SS , i installed myself an amplifier with 2 subwoofers, but the (+) for the amplifier i wired it to the fuse box that is in the left of the driver seat ( between the door and the driver seat) but when i increase the sound and if i have the car lights on and there is a lot of boom then the light increase and decrease with the bass ( like if the amplifier is sucking all the electricity of the fuse box, i want to wired the amplifier imidiately to the battery but i couldn't find a hole between the battery and the inside of the car,does anyone know how to do it or where is the hole if there is any? and another thing , i have a command , the amplfier as u all know needs a 'remote' wire , i putted an ON/OFF to turn on and off the amplifier, can i wire the remote wire to anything so the amplifier goes off when the car goes off (like to the radio or a certain fuse box or something) ?
thank u in advance guys
Old Mar 19, 2009 | 12:17 PM
SickSpeedMonte's Avatar
2007 C230 and 1985 Monte SS
Sounds like you need to
1.) Wire it the right way
and
2.) Buy yourself a capacitor
Old Mar 19, 2009 | 01:26 PM
BLCKW203K's Avatar
2003 C230K SS
You can wire the remote wire to your head unit, or I guess not because you have comand. You could wire it to the ignition, but I'm pretty sure there is a switched power source in the trunk you can go to(dont remember what it is). To wire your power cable to the battery go through the firewall. Take off the passenger side kick panel and get a flashlight and look around you'll see it.
Old Mar 19, 2009 | 02:01 PM
bumpnzx3's Avatar
W203 C230SS
you are asking for trouble having it hooked to anything on the fuse box- it wasn't meant to handle that load.
there is a switched power source for the sig lighter. i can't remember which wire it is though- search the forum, it's been discussed before.
there is a plastic block in the passenger footwell. you can get to it from the footwell or behind the battery under the hood. there are a few plugs in that block that can be taken out to run the wire through to the battery.
a cap is not going to solve your problem, even when you do wire it correctly. the alt still has to charge the cap. when listening to bass heavy music- caps really serve no purpose. do the "big 3" upgrade and call it a day.
Old Mar 19, 2009 | 02:03 PM
http://www.carstereo.com/help/elect_upgrade.cfm
Old Mar 19, 2009 | 03:11 PM
bumpnzx3's Avatar
W203 C230SS
read any real audio forum or anything written by someone respected in the audio world- they are more or less a waste. a 'big 3' upgrade will be more than enough for what the original poster needs. more batteries and a bigger alt could be added (not sure if anyone makes one that works on MB) if really needed.
To quote your link: "Capacitors might help, but they do not take care of the fact that your car's system is underpowered. They are a "patch" for a more serious problem"
the only time they are slightly beneficial is in music that doesn't have much bass, then a sudden large bass hit. any kind of rap or bass heavy music they are of no use
Old Mar 20, 2009 | 04:02 AM
wanteed_ss's Avatar
thanks a lot guys, u were very helpfull
Old Mar 20, 2009 | 04:38 AM
infected's Avatar
2007 ML500
There is a rubber vertical strip behind the dash and above the passenger foot well that has some red factory wires running through it. You can see the outline of the other holes so use something long to poke it out and it will take you behind the battery.
Old Mar 23, 2009 | 10:03 AM
wanteed_ss's Avatar
if anyone want some help, i did it and it all worked , i wired directly to the battery by using a certain type of fuse , and the remote of the power i wired it to the fuse #7 that is in the fuse box that is in the trunk , and i putted 2 capacitors and it worked very good
Old Apr 21, 2009 | 09:40 PM
Iwannagofast's Avatar
'06 C230
so what do you use for audio cables to get the sound to the subs?
Old Apr 21, 2009 | 11:35 PM
krisv420's Avatar
02 C320 Sedan
Correct.. I will have to look at what fuse i wired it to but you can. Amp powers on right before car is started in slot 2 i think.
Heres my little set up ive done a few things from this picture. But my system thumps =D
Just to note i have the bose system in the car as well
Old Apr 22, 2009 | 03:35 AM
W203E35's Avatar
2006 C350 Sport 6MT
Capacitor
Old Apr 22, 2009 | 03:53 PM
'06 C230
no one has said what are they doing for audio cables to get sound to the amp and the subs
Old Apr 22, 2009 | 04:31 PM
krisv420's Avatar
02 C320 Sedan
I have the stock Bose system in my car.. I removed my rear deck located the sub woofer removed the stock Bose sub woofer.. Cut the wires from the sub woofer .. Buy a LOC http://www.sonicelectronix.com/item_...TRUNK-LOC.html
Easy as that..
RUN RCA cables to your new AMP bingo
Old Apr 22, 2009 | 09:25 PM
'06 C230
yeah thats what i figured you guys were doing was using a line out converter. i just got an 06 c230. i had an 05 f-150 before and i kept the stock radio in that cause it had an in dash 6 cd changer. i used a lint out converter for that to hook up my subs in the truck. i am debating yet on the car if i want to go with a new head unit or just use the stock one.
Old Apr 23, 2009 | 11:36 AM
krisv420's Avatar
02 C320 Sedan
For my car this was the best way because i have the bose with the fiber optics bull ****.. I would have changed out the head unit a long time ago if it wasn't for this. But Keeping the stock. Looks pretty clean.. Good thing the ipod hook up works or i would dieeeeee
