C-Coupe HATCH won't open
switch. Just observe how much it would need, like probably just a couple thou's of an inch. Then bend it ever so gently till it's consistently pushing the switch. Problem solved....permanently.
I'm not a trained mechanic, but I play one on TV and in this forum.
Started with 2 cycle motorcycles, did a head gasket out of necessity on a 20R Toyota when I was 19, SOC. And it worked to my amazement! I went to the shop and bent the mechanics ears and got all the info, pre-internet.
Then on to FIAT's. Belonged to a club and learned a lot at their tech sessions.
then an older 3 series. BMW. They actually come with a tool kit and detailed instructions in the owners manual with everything right to adjusting the valves!
Pretty much everything I've learned since then had been online here and other forums, and more recently lots of good info on youtube too!
As far as bending it goes, just bend it while in the latch assembly. You can't really disassemble it.
For me, I used vice grips, and it left some teeth marks right where it contacts the switch, so don't do that! I had to sand the marks off a little so it won't wear down the area where it contacts. I chewed it up pretty bad, wasn't looking closely at where I had the tool in relation to the area where it would come in contact. Again, all pretty obvious.
As far as the technology goes, yeah when problems get past a certain point, there's no way to get around just paying someone, but most things are just the same crap I saw on any other car.
Brakes, alternators, starters, switches, fuses, bulbs, fluids, filters.
I just received the parts (micro-switch + "screws" for lateral panels) from Mercedes and I am around to start.
6 months ago I removed all panels to see if that was not too complicated to do, but then I was stuck with the final part ==> how to remove the "block" where the microswitch goes in?
So if somebody could explain how to remove this "block" step by step in order to be able to change the micro-switch ... or is it possible to change this switch without removing the "block" ?
No need for explanation for the panels .. even if 6 months I destroyed one of the two "lateral panel screws".
Thanks in advance,
Waiting for your input before starting the change.
Cheers,
Phil
It was the micro-switch.
The last part was easy finally.
Remove two big screws, then unplug the cable on the left and remove the micro-switch by pulling the little security plastic.
So happy to open the hatch in a normal way!
Phil
If the green switch inside works, likely it's not the wiring.
Both switches are on the same circuit.
It's what I said some years back in this thread.
Bend the metal piece that accesses the switch ever so slightly to
get a positive action on the switch every time.
Replacing the 'snorkel' is PIA, I did mine, as I replaced the entire hatch,
due to 2 different accidents, the last one resulting in a shattered window.
Insurance paid me $2500...hatch cost $450 same color even + my time and gas and $10 for the snorkel.
You'd need to pull down the headliner, and access the wires, and either pull everything from the hatch, or go the other
way. I pulled everything out of the hatch, and then reattached.
I'm pretty sure I posted pics and more info around here somewhere...some years ago.
I used dish soap to get the snorkel to go on...
someone had suggested that...
I would think WD40 would ok too since it dries eventually.
1) remove the panel nearest the bottom of the hatch per the pdfs above. (go buy the plastic pry tools for $10 from your local parts store, if you don't have them already)
2) Remove the panels on each side of the window per the pdf above. You do have to unscrew the hatch string mounts.
3) At the lower edge of the hatch, there are four screws on the bottom of the panel along the bottom of the hatch. Remove them.
4) There are two screws along the sides of the window that were exposed when you removed the side panels. Remove them.
5) Here's the fun part: There's a panel in the center you can see with the hatch open, about 8"x10" size. It's just behind where the third tail light is. It has a small notch in the center. Take a small flat blade screwdriver into that slot and push the blade in. You should be able to detach one of three hooks holding that edge. Slide the screwdriver over until you can feel the edge of the next hook. Push the screwdriver in to release the side hook. Do the same on the other side.
6) Once the lower edge of that cover has all three hooks released SLIDE the cover along the glass, downwards, to release the upper hooks. You don't pry this cover out.
7) Once the cover is removed there are two screws to be removed.
8) With the hatch open at about eye level, grab the back of that big panel and push towards the front of the car, to release a couple of hooks. At this point the panel should be removed, and you can get to the handle and microswitch that are the real problem here.
Once you get the trim pieces off it's pretty obvious.
But the tabs on the trim end up getting destroyed.
HINT: Get some stick on felt from a lighting supply store and cut
super thin strips to put on the trim edges, and no more squeaks.
Extinct:: If the wires to the green button work, you've got your answer, spice and extention,
cut the connector leaving enough wire to connect the wire, with some solder and
shrink tubing and yer done.
EDIT- I decided to test my searching skills and those old threads seem to be gone from the W203 forum.
Maybe they got moved?
FOUND IT!
https://mbworld.org/forums/c-class-w...on-t-open.html
Oh f'in hilarious, it's THIS thread, back at the top. 10 year old thread lives on.
FWIW, here's the fix I came up with, rather than a rubber band that would eventually decay and fail.
I got some very thin picture hanging wire, tied a slip knot in one end, and put that around the plug of the microswitch. Then I made multiple wraps of the wire around the body the switch is mounted to, and sealed everything off with metal tape. That provided enough tension to keep the switch in place, and not move the .010" that renders it inoperable (not a good design).
I'll try to attach photos of the panel that shows six of the eight screws needing to be removed, and the backside of the center panel that covers the other two (hatchback, btw)
