C240 Misfire - NO CEL
2002 Mercedes C240
Current Mileage: Approximately 78,000
Plugs changed at 52,000 miles to Bosch Plat 4.
Symptoms:
I started to experience some vibration a few months back and assumed it was the engine mounts since no CEL came on. It feels like its coming from under the seat at times and its rather violent with the thought of "this could be trouble" running through my mind. It feels like something is about to fall off.![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Action Taken:
I went to an independent shop here in Los Angeles. The mechanic swapped out the engine mounts only to discover that the shaking became more severe from a cold engine. The old engine mounts were less than 50% so I decided to leave the new ones in.
Assessment:
The mechanic hooked up a computer and determined that the problem was coming from cylinder no. 5. He suggested I swap out the cables.
I ordered two new cables (G, both short) and will install them to see if this remedies the issue. It could be the coil pack.
I'll update as I move through the process of elimination. I welcome any comments.
Symptoms:
Action Taken:
Assessment:
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
That's interesting. It's often Cyl 5 that goes first. I suggest that you get hold of a scanner & move the coil & leads for cyl 5 to another location. If the misfire changes to the new location you know whether it coil and cables causing the problem. Mark the coils with a felt pen so you don't mix them up. Misfire codes = 301 to 306 in your case or 300 = multiple misfires.
It could be other things but do this first & let us know.
Once I get the cables, I will put them on. I am starting to suspect the coil pack. I am also wondering if an O2 sensor could cause this.
Super Moderator
O2 sensors tend to cause the engine to stumble under acceleration & should give you a fuel trim code. I'm surprised there are no stored codes. You can have stored misfire codes without the CEL coming on. It has to have enough misfires to trigger the CEL.
Change the leads - Why did the mechanic suggest Cyl 5? - it must have shown codes which he deleted - & maybe change the coil pack.
Before you spend any more money - please check the MAF - just to eliminate it from the equation. Unplug it and let the car run on a default map. If this makes no difference then replug it and cancel the code it will throw.
Does anything rattle in the exhaust system?
I started the car up and waited until it warmed up. I listened to the exhaust from the driver’s side and looked under. I did not hear any rattling or see any strong vibration.
Cylinder Misfire on No. 5
The mechanic hooked it up to the computer and informed me that the misfire was originating from cylinder no. 5.
I reviewed the spark plugs DIY and realize that I made two mistakes.
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
1. I did use any ant-seize but FORGOT the dielectric grease.
2. I did not use a torque wrench as the final step. I just tightened them so that they were real snug. I did not want to over tighten and risk a problem later.
On Monday, I will call the mechanic and ask for more info and see if he cleared any codes. The new cables should be here by wednesday at the latest.
I probably should buy and apply the dielectric grease to the tips. I guess a clean rag should suffice to clean?
Plugs can be defective; I'd rather buy a new plug first and replace it before buying a new coil pack.
Glyn, Thanks for all your help.
Super Moderator
Good - then you likely don't have a piece of catalyst broken off.
Yes, plugs are worth another try even with 2 per cylinder. Dielectric grease is a good idea. Lack of it is not likely the cause of misfires but coil packs seem to last longer with it.
Torque is one of the most critical aspects of spark plug installation. Torque directly affects the spark plugs' ability to transfer heat out of the combustion chamber. A spark plug that is under-torqued will not be fully seated on the cylinder head, hence heat transfer will be slowed. This will tend to elevate combustion chamber temperatures to unsafe levels, and pre-ignition and detonation will usually follow. Serious engine damage is not far behind.
Off to get a torque wrench!
Super Moderator
Yes, plugs must be tightened just right for proper heat transfer - not too tight either. Detonation is unlikely in a modern vehicle but it's still important to get this right.
Super Moderator
In response to your PM, their torque specification ~22 ft-lbs/30 Nm.
https://mbworld.org/forums/c-class-w...-plug-r-r.html
Their is some bad news.
1. I dropped set of foldable allen wrench tools
![Mad](https://mbworld.org/forums/images/smilies/mad.gif)
2. It sounds like a guide is loose. I hear a high pitch wheel sound almost like a "space ship" sound. I have a recording taken with the iPhone and the quality is descent but can't upload.
3. If I turn left sharp such as turning into a drive way to turn around, I hear a crunch noise. I wonder if a bushing is going. The odometer has 78,000.
Super Moderator
Allen keys are as hard as hell - get them out of there before they get caught where you don't want them & do damage - If you can't fish them out with a piece of wire the drop the cover plate.
You are going to have to give us more detail about "space ship" noises.
Check your Castor bushes
![](https://mbworld.org/forums/attachments/c-class-w203/144275d1227436886-vibration-up-front-need-help-control-20arm.jpg)
https://mbworld.org/forums/attachmen...h-bulletin.pdf
Also check sway bar bushes & links
Ignore VIN numbers - applies to all W203
I'll check out the remaining issues per your sage advice. An impressive display of knowledge; many thanks Glyn!
Super Moderator
Space ship noises. These engines do produce some high frequency noise that seems temperature dependent. Don't be too concerned. The things that fail are usually the belt tensioner/pulley or the idler pulley.
The mechanic says he does not clear codes unless he fixes something. I did a rescan after connecting the new cables and MIL status says OFF, no codes. The car is due for a smog check so hopefully everything is A-ok.
I'm still getting a vibration under the driver's seat BUT only when the car is in Park and idling. In Drive with my foot on the brake, nothing.
Anyone have any thoughts?
Had it checked out and they say its fine. I ordered a new coil pack to replace for cylinder 5. I'm going to install shortly to see if that solves it.
New problem
On the left side of engine (passenger side) I saw that the spark plug cable was soiled (middle coil pack). Put my finger under it and there was fresh oil, not good.
Also noticing a fair amount of black dirt and oil around the whole engine.
I wonder if the gasket seal is going and/or perhaps the spark plug seal.
Going to take in to the shop on Monday.
New problem
Super Moderator
See TruTaing's thread on cam cover gaskets & sealing the crankcase ventilation covers on the camboxes.
https://mbworld.org/forums/c-class-w...03-thread.html
I searched and found his thread. Many thanks. I also found a source for a step by step process for replacing the Valve cover gasket with pics. I posted a link on Trutaing's thread:
https://mbworld.org/forums/c-class-w...ing-cover.html
Update on Misfire & Shaking Issue:
The mechanic replaced the engine mounts mistakenly at first and then realized it was a misfire. The engine mounts were low so I decided to leave the new ones in. I replaced the coil and leads on cylinder 5.
I took the car in today. He hooked it up and said A-ok, no misfires. He stated that he needed the car "cold" in order to determine where the vibration is coming from and thought it was very minor. He did ask if it was involved in accident stating that something could be coming into contact and thus the vibration. It did not feel like this at 48,000 when I bought the car and no accidents since I have owned it. It now has just under 80,000. Maybe its time I went to the dealer.
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
Super Moderator
One thing I would do is replace all plug wires. You are at about the mileage that they can play up.
I really appreciate everyone's input.
Super Moderator
i would do what others here do and have an extra coil pack in the car for emergencys. on the m112 the coil packs seem to last way longer then on the inline 4's. on the m112 they don't get as hot which seems to help them live longer. i have not replaced any of them on my car in the 49,000 miles i have owned it. btw my car has 135,000 on it.
Going to switch to Denso plugs as I am questioning Bosch PLATINUM IR FUSION.
Super Moderator
I only use OE Bosch plugs - You could have a coil problem. If changing the plug wires made a noticeable difference to smooth running then I'm sure your problem is ignition system related.
