Melted Bix Socket Fumed Housing What to Do????
For some odd reason the socket to the bulb suddenly melted and fumed the housing to my bix...now the housing is fogged up.... i have searched the forum and found threads on it but none of them talked about how to clean it up...is it possible to just take apart the bix and wipe of the residue on the lense and i also notice other members saying the chrome piece is easily scratched so how or what should i clean it up with? Also can i replace just the clear glass lens for the bix if i can can anyone provide me with a PN...any help will be greatly appreciated ill try to post some pics later
thanks
I found it....
1st remove the offending headlight..
https://mbworld.org/forums/c-class-w...s-removal.html
Then go here start at post 53 I think it is...
https://mbworld.org/forums/showthrea...16#post3095316
Then go to last page of same thread for pn for new socket + igniter.
woulda saved me the it took to find it...
btw will the new igniter get more light output cuz it provides more voltage?
You won't get any more light by replacing the igniter. Disassembling the headlight isn't too hard. I havent had any problems with moisture.
so do u have any thoughts on what i should do to clean up the inside of the housing?
on the bright side, getting to the projector is easy once the light is apart
DO NOT RUB ANYTHING ON THE CHROME SURFACE OF THE PROJECTOR BOWL
cleaning the lens is ok, but the chrome is very fragile, and is very very very easy to damage
