ASP Pulley
Old Feb 1, 2003 | 03:45 PM
QC1's Avatar
QC1
C230 Coupe
ASP Pulley
Hello, Im ordering an ASP pulley as soon as the new ones are ready to be shipped out. Im not really to good with toold so I was thinking about taking the car into a local mechanic to get it done. Does anyone know of anything I should let the mechanic know of for installing the pulley? Also what belt size should I tell them to go for or would the mechanic know which one to use?
Old Feb 1, 2003 | 04:01 PM
Lynn's Avatar
He should make sure that the washers are installed in the right direction and use a 56" belt.
Old Feb 3, 2003 | 05:00 PM
TaiwanBoy's Avatar
You wanan buy MIne? I pmed you
Old Feb 3, 2003 | 08:22 PM
Lockbuster's Avatar
By the way take some insurance on the engine!
Old Feb 3, 2003 | 09:48 PM
Buellwinkle's Avatar
Get the new steel hub version. It's $300 U.S. The belt you can buy at any auto supply store. Got mine at Pep Boys for $18.99 U.S. Just ask for a 6 rib 56" belt. Also pickup a K&N or ITG drop in panel filter for an extra 3HP.
Old Feb 3, 2003 | 09:50 PM
antonio's Avatar
2002 C240 Classic
buel, why is it many have had probs with the asp but yours has been flawless? any ideas?
Old Feb 3, 2003 | 09:56 PM
Sure, if you truly don't know what you are doing and modify the pulley to make it easier to install like a few have. Did you know that some pulleys are coming back to ASP so badly sanded that it's a wonder they haven't failed. He said he won't warranty any modified pulleys whatsoever. I can't believe how lazy people are. The pulley is a press fit, it's not supposed to glide on effortlessly. But morons sand the heck out of the hub and this creates vibrations and can lead to a failure and damage the key. For all I know they hammer it in. The proper way is to align it with the key and use the bolt to ease it in. I can see why Renntech and Kleemann insists on a professional installation to maintain the warranty. I have a picture of a modified pulley at work and I'll post it to show how stupid people can get. Then when it breaks they blame ASP. To those people, please buy a Kleemann pulley!
If any of you sanded the hub for an easy fit, remove it at once and send it back to ASP for the free steel hub upgrade and if you have trouble installing it, take it to a professional, don't sand it.
Old Feb 3, 2003 | 11:10 PM
Matt230K's Avatar
2010 C300 4matic
I sanded mine just a bit to make sure it was perfectly smooth and wouldn't cut into any seals. But it's stupid to sand it just because you want it to go in easier. The stock pulley being relatively hard to get out should be some indication of how tight it needs to be.
Old Feb 4, 2003 | 12:28 AM
Lockbuster's Avatar
Buel,
So in short it is operator's error in installing a pully when it fails!
:p
Old Feb 4, 2003 | 10:45 AM
Buel,
:p
Just telling you what Lee told me about the pulleys that are coming back for retrofitting to the new steel hub. If I show you the picture you will see how badly sanded some are and you can judge for yourself, some to half their thickness. One nice thing about stainless steel, they won't be able to sand it easily. Don't want to scare anyone from installing any pulley on their car but Lee would like to discourage them from getting creative.
Old Feb 4, 2003 | 12:08 PM
avlis's Avatar
2008 VW GTI
Let's see that picture already! The suspense kills me.
Old Feb 4, 2003 | 12:27 PM
QC1's Avatar
QC1
C230 Coupe
I hope wherever I take it they dont do it the easy way and cause me problems latter on. I will make sure to tell them not to Sand it. Also what exactly should they remove in order to get it installed correctly.
Old Feb 4, 2003 | 12:37 PM
Don't want to cause anyone any an ulcer
Old Feb 4, 2003 | 01:04 PM
avlis's Avatar
2008 VW GTI
It's not terribly clear to me what they did. Is it that big chamfer that they added or those gouges inside?
Either way, sanding is something that you do to wood furnature so that you don't get spinters. I don't know why people are sanding "precision" machined aluminum parts. If there's a burr on the diameter, then it should polished out with emery cloth or carefully knocked off with a swiss file. Sanding the ID is like sanding the cylinder bores in order to get the piston rings to fit in...
Old Feb 4, 2003 | 01:13 PM
young's Avatar
GLB 250 4matic
it sounded good at the time... that picture is very poor. hard to discern anything.
Old Feb 4, 2003 | 02:49 PM
Sorry, didn't take the picture but what it shows is that half the hub was sanded specially down in the keyway area where it's very thin. You can see that the area in the hub is not black as it came from ASP. Also note the keyway is virtually gone in the sanding. Sanding not only weakens the hub as you are removing the hard annodized coating but sanding it the way this individual did it throws the hub off center. If this pulley didn't come back in for a new hub it likely would have failed. Young, you at least realized that you were in no position to install it yourself and galdly pay someone to do it. I think with halfway decent mechanical skills and with the assistance of the many that did install it themselves on this forum one can install it themselves.
Old Feb 4, 2003 | 03:06 PM
20FHK02's Avatar
2002 C230 Coupe
When I had the pulley I only sanded the outside surface of the steel ring with 1000 grid paper, in an attempt to smooth it more because I had a leak before. I will never sand the inside though.
Old Feb 4, 2003 | 05:22 PM
DCX Engineer's Avatar
I can't believe how much material that user removed. WOW!
Old Feb 4, 2003 | 07:54 PM
TNblkc230wz's Avatar
C320 Coupe
You would think someone with the equipment or elbow grease to sand that much out would know better.
