Manual Transmission
If you are in 4th gear and your rpm is say 5500 and you accidentally shifted to 2nd, would there be a mechanism that would prevent you from shifting into a lower gear so that you won't kill your engine?
Scenario:
1. Your at a standstill and rev engine
2. You rev much higher then redline
A friend drove my car and downshifted too early...the car slowed down quickly, but the fuel was cut until below redline...in a normal car, he would have blown the engine.
Either way, its not good for the car, don't do it on purpose.
Erik
I suppose it would be useful if the electric device failed, having a mechanical backup, but I don't know of any such system.
Erik
Scenario:
A rev limiter is only useful if you forget to shift or if you miss an upshift.
There is no such mechanism on any gear. If you do what your scenario suggests, you will over rev the engine. A fuel shut of or ignition based rev limiter won't help. The engine is mechanically connected to the wheels. When you down shift to the wrong gear, the wheels will force the engine to turns the revs that match that gear. There is absolutely nothing on the car that can prevent this and the damage that may result.
Scenario:
No doubt someone will find a way to blame MB for this 'oversight'.
If you want to drive stick you need to learn how to push that clutch back down if you need to and do it quickly to not hurt the engine or your car. If you do not know at what speed you can downshift to a certain gear then you need to either not downshift or you need to get an automatic. My wife did not know how to drive stick until 3 weeks ago and she has picked it up quite well. She even downshifts to stop now and she knows what gear she can hit and when she can hit it. And it has only been 3 weeks and she learned on the Benz. It is not rocket science but if you need protection from damaging the engine on a downshift then I am sorry to say that you may have made the wrong transmission choice.
Standstill - Fuel Cuts at 4,000 rpms.
While Driving - Fuel Cuts at 6,250 rpms.
Redband is 6,000-7,000rpms.
Erik
and he was floring it but accidently shifted into 1st gear instead of 3rd. Well anyway all i heard was a LOUD noise and i saw the RPM go into 7 or 8k? what ever the highest # on the tach is. Well suprisingly nothing happend to his car.
My wife did not know how to drive stick until 3 weeks ago and she has picked it up quite well. She even downshifts to stop now and she knows what gear she can hit and when she can hit it. And it has only been 3 weeks and she learned on the Benz. .
Automatics are pretty boring.
