Violent Shake/Shudder when Cabin Fan is On (Unrelated to Idle Speed)
So my thoughts are that it is likely the AC compressor (this assumes the AC Off button disengages or otherwise lets the compressor/condensor pulley or whatever spin freely on the serpentine belt). I think its a mechanical issue, not electrical, since it'll continue for a few seconds even when the car is shut off.
Any thoughts?
I'm thinking the culprits is/are:
- compressor
- condensor
- stepper motor
- blower
Does the blower run only when the a/c is regardless if ac is on/off?
Is there a separate AC only blower/fan?
The stepper motor is related only to vent direction, right?
So all years have no clutch (mine is 2003)? This means its always being engaged by the belt right? I have a hard time wrapping my head around that
Does the blower run only when the a/c is regardless if ac is on/off? Because I can have the cabin air at full blast with the ac off but as soon as i turn it on. it gets crazy.
All years have no clutch. The compressor runs all the time driven by the Poly V belt - It has an actuator that gets it pumping. This is common in modern vehicles - even Land Rover use it.
The whole car shakes violently...like its going to disentegrate if I allow it to continue for a significant length. it seems to be originating from something on the belt. Its hard to pinpoint, because frankly the whole engine bay shakes so bad, yet alone any specific component on the belt.
I also just noticed a hissing vacuum leak-type sound emanating somewhere on the front top driver side of the engine (near the Throttle Valve/electronic gas actuator) but I haven't been able to determine if it is a loose hose or what. Just thought I'd point that out as it may/likely be related. This occurs regardless if the AC is on or off.
i'll look for the "notorious vacuum leak". i noticed one of the hoses following the collision repair was loose a few months back but that was easily detected. this one is tougher to locate. anyway, i'm more interested in if this could be related to the violent shaking. my guess is its not.
How about the harmonic balancer? Maybe it got damaged in the accident and it's starting to come apart? And just a little more pressure on the belt from the AC causes it to fail? The thing that is weird about your symptoms is the continued shaking after the motor is shut down. Is it dieseling? That is...does it continue to run after turn off? Or does the motor stop turning and the shaking continue?
the vacuum sound was a torn/deteriorated piece of hose. i think it was the one I'd mentioned in the previous post.
Ruck and mleskovar, i greatly appreciate your continued input. at the very least, its been documented on the forums some other things to check for should anyone have similar symptoms.
