Upgrading and adding speakers in a C230k coupe
With that being said I would like to change the front speakers (5.25") and the "back" speakers (6.5") to better ones and Add a set of real rear speakers. Who decided that it was a good idea to put the rear speakers on the door? anyway ... So my questions are:
- Do we have something speaker related prewired in the trunk?
- What will be the easiest solution to get an additional pair of speakers other than "tapping" into the existing ones?
- If I tap into the original speaker will I experience loss of output power?, if so, what will be the best "inexpensive" solution to do something like this?
Thanks!
https://mbworld.org/forums/c-class-w...-possible.html
Replace the existing speakers - that's easiest & cheapest
Next step - add a sub - keep out of sun.
Final - step - add a stand alone multichannel amp & use the Avic as a head unit only.
I have no idea what prewiring exists in a 02 Coupe. - so much depends on where it was built & what harness it has. Considering it's age it probably only has the stock speaker wiring.
Thanks!
Here or there, I'll get to your questions.
So part one to your answer first.
The front and rear mounts are a crappy plastic mount. Ditch them, and REALLY free up your options for what type of speaker you can mount.
Here is what I did in my car. I ditched the stock plastic mounts. I made trim rings out of MDF and mounted them to the stock mounting holes. The stock mounts had odd holes in them that allowed the rear wave to immediately "leak" and cause cancellation. Result was a lot of speaker movement and a reduced output.
Here is the huge openings we have without the silly plastic mounts.
With this custom MDF mount I have a 6.5 in the front and a 6.5 in the rear. The front has a TON of space! You can really mount something big in there. I sprayed the MDF mounts with a coat of varnish to seal them should moisture get in the door.
I have since turned off the rear 6.5 and found it unnecessary.
Accomodating the new MDF speaker mounts meant that I now had to trim the door's panel.
I found that pretty easy to do, but it involved a lot of trial and error filing.
Stock front door panel opening
Trimmed front door panel to fit MDF ring
I realize the trim job isn't pretty, but nobody will see it. You may have noticed that I have some clay on the MDF rings. I did this in order to add mass to the speaker's mounting rings. I didn't hear a differance, but its what the guys are doing right now.
So, your application...
If I hear you correctly, you simply want to add some nice speakers up front and hook them up to a Kenwood stereo.
Are you going to get an amp? I'll assume not.
So, for someone who is wanting better sound, I would do this.
Take the door panel off. Somewhere on here is a good DIY already done up. Someone feel free to add the link.
After removing the door panel and tweeter panel, take off the plastic speaker mount. Take it and the sail panel into a audio shop. Find out what fits that openings. I used to have an MB Quart 6.5 in the front. Fittiment was so so. I think it was just a bit small for the mount. Once you know what will fit, listen and figure out which speaker sounds the best to you.
All the wires are there to get sound from a deck to the door. You just need to cut them from the stock harness.
When I get a chance, I'm going to show where I am in my door. It has been deadened, has a sound diffuser behind the speaker...further I went with an Alpine Imprint to get time alignment and eq'ing done. But I'll get to that.
Ed
They have a new board among other updates to take care of the early bugs. If only I could afford some hertz milles as well.
In my car, I upgraded the speakers, headunit etc. I hated the bass response and utter lack of clarity in the sound. So, I had to do some research.
What I found first was that I had phasing issues. I confirmed this by playing test discs that would have vocal tracks with an in phase and out of phase portion. Curing this was a sit down with all of speaker leads for the mids and highs. I had to play with the polarity of my speakers, but eventually I got it all right.
I am far from an expert, and may possibly be giving bad advice. But I think the large transmission tunnel in the car really plays a bit in creating a sound wave that emminates from the speaker, then bounces back and cancels itself.
After I felt good about the phasing I didn't like the mid range clarity. So, I got a sound diffuser to "suck" up the rear sound waves behind the speaker.
I recall distinctly this was something that really made me go WOW! after installing this, I really felt like I was listening to music, not listening to a speaker. By diffusing the rearward sound waves, I'm able to let the speaker play with less reflections in the door.
Next up dampening.
Those are great DIY instructions... I wonder why I didn't find them in the sticky. Are the stock speakers 6.5 (front) and 5.25 (back)?EDIT: Found the linky for the door panel removal. Clicky Here
[IMG]http://i74.photobucket.com/albums/i262/emrliquidlife/audio/IMGA0304.jpg[/IMG
[IMG]http://i74.photobucket.com/albums/i262/emrliquidlife/audio/IMGA0307.jpg[/IMG
[IMG]http://i74.photobucket.com/albums/i262/emrliquidlife/audio/IMGA0308.jpg[/IMG
[IMG]http://i74.photobucket.com/albums/i262/emrliquidlife/audio/IMGA0302.jpg[/IMG
[IMG]http://i74.photobucket.com/albums/i262/emrliquidlife/audio/IMGA0316.jpg[/IMG
[IMG]http://i74.photobucket.com/albums/i262/emrliquidlife/audio/IMGA0315.jpg[/IMG
[IMG]http://i74.photobucket.com/albums/i262/emrliquidlife/audio/IMGA0318.jpg[/IMG
[IMG]http://i74.photobucket.com/albums/i262/emrliquidlife/audio/IMGA0320.jpg[/IMG
Next up dampening.
So where did you get those sound diffusers?
