Oil in MAF
Old May 3, 2009 | 08:46 AM
MOBC200K's Avatar
c200k
Thumbs up Oil in MAF
ok so yesterday i cleaned out my maf and i found oil in it wtf that can't be right is it. while i was at it i cleaned out the throttle body and i'm very happy with the throttle response and car is running much better but can anyone clear up about the oil thanks
Old May 3, 2009 | 11:11 AM
krisv420's Avatar
02 C320 Sedan
What type of air filters are you running?
Old May 3, 2009 | 12:55 PM
Glyn M Ruck's Avatar
Super Moderator
K&N ????
Old May 3, 2009 | 03:07 PM
MOBC200K's Avatar
c200k
no its stock filter. i didn't think there would be oil at the mass airflow i figured it should just carbon build up am i right
Old May 3, 2009 | 03:28 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
I had some oil residue in mine as well. It came up from that flex hose on the bottom rear of the airbox. I just cleaned it all up with MAF cleaner and pray that there is nothing wrong.
Old May 3, 2009 | 03:58 PM
91RS's Avatar
2016 Chevrolet SS, 2006 Cadillac STS-V
Not exactly on topic, but how hard is it to remove the MAF? I want to clean my throttle body and possibly do a BG Induction Service.
Old May 3, 2009 | 05:46 PM
Super Moderator
The closed circuit crankcase ventilation systems on these cars does foul the system upstream of the fuel supply where the fuel can't keep things clean.
Old May 3, 2009 | 08:26 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
All the more reason to add a compressed air filter in the circuit.
Search on 'oil catch tank'.
Don't buy the crappy ones on ebay!
Old May 4, 2009 | 04:20 AM
Super Moderator
Yes - agreed.
Old May 4, 2009 | 04:35 AM
AzCamel's Avatar
10 GLK350/ 15 Accord/ 94 Supra Turbo
clean it, check it again in a 2weeks. see if there is still oil, if so check all hoses in going to the intake, im betting that one of those crank hose valve is failing. you can either replace it or install a oil catch can, if you do that i suggest a vented one.
Against what others have said, ebay catch can is fine, just put a breather on it and vent it, done it to mine and other 500rwhp monster and have no problems
Old May 4, 2009 | 07:22 AM
MOBC200K's Avatar
c200k
cheers everyone can you's giveme more info on the oil catch can thanks
Old May 4, 2009 | 07:47 AM
AzCamel's Avatar
all the catch can does is give a place for the oil to collect due to blow by.. venting the can gives a place for pressure to release with out going all out as in just unpluging the hoes all together, still give crank pressure.
EDIT... sorry but i totally forgot that these cars are run a closed loop system.. do without the vented can.
Old May 4, 2009 | 07:58 AM
MOBC200K's Avatar
c200k
does it make a differnce if its a m111 or m271 cos mine is a m111. is it a big problem
Old May 4, 2009 | 08:31 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Oil catch can FTW.....installed by TVT (MBWorld sponsor)
Old May 4, 2009 | 09:02 AM
MOBC200K's Avatar
c200k
cheers for that so i take it its a common problem on mb's is it
Old May 4, 2009 | 09:57 AM
C43AMG's Avatar
Veteran: Army
I think it's common on all cars.I had the intake taken off and port & polished.It's amazing the amount of build-up after only 70k miles.
Old May 4, 2009 | 11:37 AM
fanito's Avatar
02' C230k Sport Coupe
Because of a bad oil separator I had to replace my MAF and, of course, the oil separator. This cleared up my CEL... of course, after $1064 for repairs
Old May 4, 2009 | 04:13 PM
PA_Pete's Avatar
2001 C320
+1 I was also told that MB's are notorious for extreme blow-by (more so than other cars).
Old May 5, 2009 | 05:30 AM
MOBC200K's Avatar
c200k
oh **** thats the last thing i went they were talking about an oil catcher can but to be honest i wouldn't know where to start has anyone fitted one on the m111 engine
Old May 5, 2009 | 04:16 PM
http://www.benzworld.org/forums/w203...roblems-3.html
I did it after this guy did his... can't find the thread.
Initially I ordered some POS off ebay, but then found it leaked and
was going down to 1/8" opening which would likely fry something.
I picked up some hose from Ace, and a craftsmen compressed air filter, which I got from Ace or Osh I forget, but it had the correct size opening, won't cause extra pressure in the circuit.
It's been on there a couple months, and there's maybe an oz of oil in the bottom...and I haven't driven much, maybe 1K miles...
that oz would spread out thin and make a giant mess...
over a year, I'm sure it would be a lot.
Make sure you get one that seals. I found one at home depot, but it wouldn't seal when I blew into it with the ends covered.
Damn, I can't find the thread I posted anywhere? I wonder what happened to it?
Old May 6, 2009 | 04:19 AM
MOBC200K's Avatar
c200k
cheers for the pic. i'm gonna check it in 2 wks and see what its like and take it from there i think
