Check Coolant - Problem
car was stored for winter = rubber parts get harder
run the car after a long time = cold hard rubber reacts to heat = cracks/breaks rubber
solution:
inspect other rubber parts and replace what needs to be replaced.
This occurred for my car just a week ago so I can be of some help.
Don't bother driving it to the dealership, it will not be covered under warranty because coolant tube is considered a "hose / belt" which normally will break from normal wear and tear.
Do not drive your car anywhere, you will void your warranty if you damage your engine.
If you decide to have the dealership fix it, the bill will be around $300. If you have an independent shop do it for you, it may run you from $70-$120. Or if your lucky the service manager might just have it covered under warranty
Remember to refill the system with a 50/50% mix of MB genuine coolant.
If it popped off & did not break off it's OK to refit & clamp. From the pic it looks as though it popped off - why? that's why I ask if the system froze - fit a new clamp - dont reuse the Benz one. Good luck
Glad to hear you got your car running
