Tranny Question
will ANYTHING bad happen to the tranny if i dont flush it????
i just took my car out for a sprinted run when chasing this guy i caught paint balling my house!!!
and using my touch shift manual mode, down and up shifts were extremely jerky and i started getting really worried. yes, i know, the jerkiness is because i didnt flush the tranny.please can anyone tell me what can go wrong if i keep driving without flushing the tranny???
btw, my car has 89k mi, no service has been done to the tranny that i know of.
(man lucky they didnt gun my car or someone could have gotten "hurt"..)
oh and i thought flushing and changing the fluid is the same concept, is it not?
drainning and refilling is cheaper than a flush? i'm clearly lost here.
I had an 02 Acura TL a few years back with one of Honda's glass transmissions. I was a member of Acurazine and members there who had higher mileage TLs and had never flushed it were told not to do so. That flushing it at such a late stage would cause an issue quicker than prevent one.
Now this never seemed to make much sense to me. I don't imagine this could possibly be the case. But if it is, you won't need to flush it at this point. Let's see what the experts say.
Change the fluid.
ok, so sounds like i need a tranny flush and check the ATF. how long does Mercedes OEM ATF usually last??
it makes sense the first problem to occur as mentioned by glyn is the 1st to 2nd one way clutch since shifts from 1 to 2 is hard.
He said since you were in traffic the transmission learned and when you wanted to accelerate it took some time because of this.
He said if you drive aggressively the throttle and transmission will learn to react quicker.
Is this true guys (transmission masters, Glyn)?
Edit
He also mentioned a lot of people bring it in because they say the same thing, that something is wrong with the transmission that its different. Also can I reset the transmission to make it learn again? Or is this automatic?
My car has the same amount of miles as your 320 does =P im going to be flushing my tranny as soon as i get some $$$ teehee... I was so pissed off i broke a bolt on the case that sits above the valve cover.. so so scared to drill it out today but i did IT =D so proud of myself.. but anyways
My car sometimes gets jerky its odd it stopped after i checked all the vacuum lines on the car and pushed them all in tightly.
if i use manual shift mode and down shift from 2 to first.. Talk about a hard downshift.. Only sometimes..
And yeah you can reset it theres many posts around here just search =D
It will feel like a brand new car again =D
https://mbworld.org/forums/w211-amg/...set-works.html
I never knew about this, but apparently this feature has been around for awhile on mercedes cars.
Edit: It's not really called an ECU reset, but it does reset something related to the tranny and gearbox to learn your driving habits. So, the guy at the dealership you spoke with was not completely feeding you BS. hahaha!
Edit
60,000 miles
60,000 Km / 37,000 miles for torrid zones
https://mbworld.org/forums/attachmen...e-products.pdf
Please note this pdf above for Asia/Vietnam which is the same for Africa/Middle East/Australia. If you drive your car hard (like you stole it) - and reading this forum I know many of you do - High torque, foot flat up changes away from the lights etc. Please adopt the 60,000Km / 37,000 miles tranny oil change intervals. It will save you a lot of heartache in the long run.
People who drive more gently like mleskovar, with less in city driving, can go 60,000 miles or more. I will be changing at 60,000 Kms in 9000Km time.
Maybe I didnt do this that is why It didnt learn to be more responsive?
Also I remember seeing a thread about Dyno more. On mine it's pretty wierd I have to set it to 2 position then to 1 position then do the 3 clicks. But on the forum it says just on 2 position. Am I doing something wrong that Is why I am not feeling it? People claim they have felt a big difference but not me.
Basically my Dyno more was a different process to get into would this mean that the reset might be different as well?
I guess I can try both ways (2 position, then 2 then 1 position just like the dyno)
Thanks guys
In regards to the Dyno mode, I too just recently read about it, but have not tried it since I just got new rims and tires and don't want to shred them to bits yet, hahaha! Back to the topic; check out Buellwinkle's how to page on how to set Dyno mode. He's got some great How to's and not to mention sweet pics of his rides!
http://www.buellwinkle.com/howtos.html
Hmm didn't know the 230 could shred tires
I floor the car all the time =D feel the need for SPEED.. can't do it anymore way to many cops now.. I see about 4 bike cops every time i go out.. I got pulled over for going 3 miles over the speed limit!! No ticket but he pissed me off right in front of my girl..
Im getting tired of these power trippin pigs =/
60,000 miles
i dont drive my car hard every single day, only when its an emergency and when the road conditions allow it to.
i do the throttle reset and put my car on dyno mode, it makes my car feel like its a whole different vehicle, feels like 10 extra hp is added (its really not though). better throttle response, no delay upon launch, nothing but you and the car, no electronics restrainning you from the power.
Thanks guys
as for the dyno mode, depending on the year, its all gonna be different. once you do get it down, having both the reset and dyno mode on, you can finally have some fun!
