Another MAF Thread
NOTE: If you remove the butterfly/throttle plate (whatever you want to call it) make sure it goes back into the throttle body evenly, I didn't do this and when I started up the car, I heard popping and the idle jump up in speed. The ESP Malfunction Visit Workshop appeared on the MDS and the car would only rev up to about 3,000 RPM's. Apparently the throttle body does some sort of synchronization when the key is set to the No. 2 position (not started), I watched it as I plugged it in and started the car while I had the TB sitting on my wipers. So I had to take the TB back out and re-adjust the throttle plate within the TB, what a pain in the @$$. What appeared to be happening was, it was jamming itself against the walls of the throttle body since it wasn't in there completely even, although the two screw holes matched up and threaded up with no problem.
Check vacuum lines
How old is your fuel filter?
Could be O2 sensors but the likelyhood of both sides going at the same time on a V6 is slim indeed.
That's what I figured and also ruled this out as a possibility.
Yup, both banks. I've never checked the vacuum lines, so I'll do that either tonight or tomorrow. Can a fuel filter cause this??? It's still the original one on the car, but I have a Bosch replacement for it, which is basically same as stock. I just haven't put it on yet. Should I replace the fuel filter before buying and replacing the MAF sensor?
Also & this is something I need to start drumming into people on this forum - we have decided that the O2 sensors are OK and we have no O2 codes - Please never use any silicone containing sprays under hood. If silicone gets ingested into the intake system it will immediately poison & destroy the O2 sensors
Keep us posted.
Keep us posted.
Sooo, I'm not going to go that route. Anyone have any sources for a new Throttle Body for a C320? I'd love to get the 74mm throttle body that TVT was offering, but they don't have any left, at least the last that I heard. So that being the case, if I'm forced to buy a NEW throttle body, would I HAVE to go with the stock one for the C320? When I had it out previously, I measured the opening, it was 68mm. Could I buy a NEW one for say, a 4.3 (M113)? Or is the compatible 74mm from a 5.0 engine? I don't know what to do. Any suggestions would be appreciated.
That's crazy, but your TB went out a lot later than mine did...
Sorry, I couldn't help you Pete.
Thanks for the fast reply too! You lucked out, which is great for you. I'll figure something out. I think I may try to call Anthony at TVT tomorrow to see if he has any Stock TB's laying around from the 3.2 engine. That or try to order one online somewhere.
P2004 - Hot Film MAF (Probably cause I had it unplugged, otherwise, it's a new sensor)
P2006 - Air Intake Sensor (No idea?)
P0120 - Throttle Valve Actuator (Figured this was the main problem)
ESP:
C1000 - ESP Control Module (Again, no idea)
C1022 - CAN comm. with Engine (Was told this was from the throttle body not working, hence the ESP error as soon as you start the car)
C1140 - Steering Angle Sensor (I know what it is, but I'm guessing this code is stating that it is malfunctioning?)
C1202 - BAS Release Switch Plausibility (No idea?)
At this point, the shop cleared all the codes and started her back up again. Here is what they got after clearing all the codes.
What they had to say on the write up: Check data stream info. Activate throttle valve with scanner, no movement (scanner?). Check resistance to ME control unit. Must replace throttle valve actuator to continue testing.
So, that's what I have to show for my car as of now. I have a NEW TB on it's way which I'm going to install once it gets to my house. PLEASE, if anyone can shed some light on ANY of the about info provided, I would be thankful! Thanks!
ESP:
I suspect there is nothing wrong with the steering angle sensor or the rest. Turn the cars steering lock to lock 5 times. This will reset the steering angle sensor.
Replace the throttle body & clean & plug in the MAF. Allow a while to adapt & then look for codes. I'll bet there won't be any.
EDIT: Check this out, courtesy of Buellwinkle's site(thanks man!), the MB DTC for P0120 isn't even the "Throttle Actuator" as the independent shop told me it was and as it shows on the work order. Now, what? Replace this sensor too? Should I go back to the shop and complain?
P0120 Throttle/Petal Position Sensor/Switch A Circuit Malfunction
P2004 = Intake Manifold Runner Stuck Open Control Bank 1
P2006 = Intake Manifold Runner Stuck Closed Control Bank 1
P0120 - TPS/Pedal Position Sensor A Circuit Malfunction
Is that the drive by wire sensor in the gas pedal?
