What else is next????!!!
Old May 30, 2009 | 04:56 PM
danev6972's Avatar
2003 C240
Hey all.
I have replaced a few things to get rid of the front knocking sound over bumps @ slow speeds.
Lower control arm bushing R/L-Replaced
Left In/out tie rod end -- Replaced(had play per shop)
Sway bar links R/L -- Replaced
STILL KNOCKS!!!!
Soon to be installed: Front L/R in/out bearings
Front L/R upper arm bushing
Speedybenz camber arm
What else is there???
I read about worn out anti-roll bar links. Is that the same as the sway bar?
Then there's the arm ball joints. Any ideas where I can get these online reasonably?...Been searching with no luck for '03 c240.
PLZ PLZ HELP.
Old May 31, 2009 | 01:33 AM
bdgdl08's Avatar
1999 CLK320 (sold), 2007 C230 SS (gone), 2000 Grand Marquis, 2011 CR-Z, stay tuned...
Yes, anti-roll bars are the same as sway/anti-sway bars. As for the other stuff... ...sorry. Good luck, I had the same problem with my old CLK.
Old May 31, 2009 | 07:58 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
check the sway bar bushing bracket if they're tighten.
check the strut upper mount on the shock.
you can get most OEM parts from rmeuropean.com. not don't think I saw the ball joint sold separately, so you might need to replace the arms.
Old May 31, 2009 | 10:00 AM
Brad460's Avatar
2004 C-230
Did you change the struts themselves?? I just had to change out a rear shock that was "clunking". I initially thought it was some linkage issues, but when I took the shock out, drove the car, the noise was gone. Unfortuntely you can't do that with the front...
Old May 31, 2009 | 11:49 AM
danev6972's Avatar
2003 C240
I checked the driver's strut mount like frankW suggested.
I tried to tighten the bolt but the whole thing(bolt & metal plate) turns and does not tighten. ....see pic........
The passenger side mount does not budge at all.
Do I need a new mount or something else is wrong?
I really need to get this solved...I'm tired of chasing the problem & spending too much.
Thanks for all you input.
PS: Knocking was there before & after cupkit was installed.
Old May 31, 2009 | 12:08 PM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
Your hand is covering the critical part in your picture.
You need to tighten the nut with a box-end wrench, while holding the center rod of the strut stationary using an allen (hex) wrench.
Otherwise, turning the nut simply turns the whole center rod/nut/mount.
Old May 31, 2009 | 01:01 PM
danev6972's Avatar
2003 C240
Thanks dmatre. I figured it out right after my post although I did it a little different...It's tight now. I hope this will make a difference. I will find out tomorrow when I drive to work.
ANyway a question for all: When you turn your steering wheel about an inch or so to the L & R rapidly...does it make a sound?...Mine does...Just want to know if it's normal.
Thanks.
Old May 31, 2009 | 01:07 PM
LinDenKid's Avatar
C230 coupe 2002
what kind of noise? and car on or off?
Old May 31, 2009 | 03:25 PM
danev6972's Avatar
2003 C240
Either way but better if it's on & wheel unlocked.
It sounds like a dull knock & feels like it has a little 'play' to it. At least mine anyway.
Old May 31, 2009 | 04:47 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Sounds like your sway bar end links are not tight. Maybe the sway bar bushing brackets need to be tightened also.
Tighten wheel bearings?
Maybe your wheels / tires are hitting your suspension?
Something just seems to be LOOSE.
Old Jul 12, 2009 | 01:07 PM
danev6972's Avatar
2003 C240
Mechanic says it sounds like it's in the shaft itself. Could be a bushing in the shaft w/c is very difficult...
Man this car is falling apart it seems. My first & Last Benz for sure.
Going back to BMW or try a Lexus maybe. I might just get an F150 ford truck.
Old Jul 12, 2009 | 01:33 PM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
how many miles are on your car? i mean it is 7 years old bro, things tend to start breaking after x amt of years in any car! hence why i bought an extended warranty for my benz!
Old Jul 12, 2009 | 05:48 PM
danev6972's Avatar
2003 C240
It has 66,000 mi. Point taken... although I had a 1995 325is BMW before I bought the Benz that I drove for 10 years w/o as many problems.
Water pump was the only major repair. Others were very minor like power window switches & of course the regular maintenance items.
It had 116,000 mi when I got rid of it.
Anybody with steering shaft problems though?
Old Jul 12, 2009 | 06:31 PM
Glyn M Ruck's Avatar
Super Moderator
Problem can be outer steering rack bushes. Must look at sway bar links - they are frequently trouble.
Old Jul 12, 2009 | 09:09 PM
danev6972's Avatar
2003 C240
Sway bar links are fine so it must be the bushes then?
Is this a DIY or a pros job?
Thanks glyn.
