C32 AMG Brake Upgrade Discussion Thread
They won't make the car stop even one inch shorter than it already does.
In fact, they will be of ZERO benefit to you (unless you want them for cosmetic reasons - which I don't understand, but some people here apparently are willing to spend good $$ on brakes and rotors for purely cosmetic reasons, so go figure).
If what you guys say is true, the C32 would stop longer than the C320, not so. Any data?
Maybe not worth it, but that is an entirely different argument.
In addition, it's been previously discussed that the larger brakes will require more heat to work efficiently than the stock brakes... if they are not fully warmed up, you might actually see longer stopping distances than stock.
That's my understanding, at any rate.
How many miles do you have on the car that requires replacing the brakes already? Just had my 2001 model C320 brakes state inspected and they have more than 85% of their pad life remaining after 12,000 miles.
my brakes are in need of replacing, i may have to replace the rotors as well, i was considering brembos, or the amg c32 setup. it's partially for performance and somewhat cosmetics. i plan to do more to the engine in the future. so from the current replies i'm figuring it's not worth it for the c32 kit. thanks for the help.
Looks like your going for cosmetic reasons. I believe the c32 braking system would be cheaper to purchase than Brembo's.
The Brembo Gran Turismo Kit, just for the front would run you $3200 - $3500 "yikes" looks good though!
Or you could just go crossdrilled rotors like me and spend a little under $1000.
I'll post pics once I take them.
Purly cosmetic!
I might upgrade to Gran Turismo once I get the blower installed though
Most importantly, we all will agree that the change is very very expensive, several thousand dollars for sure: AMG/Brembo Calipers, Drilled Rotors, Pads, AMG Wheels (special wheels are required to clear the big AMG caliper), thus probably Tires too. (and ALSO maybe some ABS change as you suggested).
After all is said and done, MAYBE the car stops like a C32, even a couple of feet shorter, say 10 feet shorter. Lost of money for 10 feet (out of 120).
I agree with others, if "looks" is the goal, then just install standard-sized but drilled rotors, they will look good. I found drilled Brembo rotors for my old car that were very inexpensive.
why won't the larger brakes that use to stop a 300+hp car not stop any better then the standard brakes on the c320 ?
My spec's may not be correct but isn't the AmgC32 brakes 4pot and the stardard 1 or 2 pot ?
Also I belive the amg setup use a larger rotor setup too.
I really think the amg setup would do wonders on the c320 or better yet the cCouple. =D
I personally if I was to upgrade brakes look at the AMG setup also, who knows what u'll find in a junk yard right.
SO, the main question is. which the guy has been asking is will the c32AMG brakes fit on other c-class ?
Anyone know what is needed in order to have it fit ?
caliper, rotor, pads, brackets maybe ?
I believe SoCal and Timmy are making the point that the AMG brake's potential capacity to stop shorter will be offset by the ABS system, which will pulse the heavier duty brakes using the same settings as the standard brakes. The AMG brakes might lock up sooner, but ABS will let the wheels roll anyway.
There seems to be a lot of misunderstanding as to how ABS/ESP works.ABS does not pulse wheels at specific settings. The wheel speed sensor detects whether the wheel is about to lock up so there is no specific calibration for a certain rotor size at all. A locked wheel has a longer braking distance (has to do with friction co-efficient) than one on the verge of lockup.
Increasing the rotor size will obviously give you better braking performance since there is a larger swept area for the pads to clamp down onto. Brakes don't need to warm up to be efficient. It's tires that need to warm up for better grip.
This is completely untrue!!
A "bigger" brake system will NOT give shorter stopping distances using the same tire, because ABS only pays attention to the impending lock-up of the tire. I wouldn't dispute that a "bigger" system has better stopping potential, but it will only lock up the tire sooner, bringing ABS into play sooner. Hence, no better overall performance.
Changing tires to a softer (stickier) compound or a wider contact patch would help. But I think the original question implied keeping the stock wheels and tires and just upgrading the brakes.
I have not seen any side-by-side comparisons of braking performance between a C320 and a C32 AMG. If the C32 were to stop shorter, it would be because of the differences between the tires (compound/contact patch size), not the size of the brake rotors, etc.
There seems to be a lot of misunderstanding as to how ABS/ESP works.Putting C32 brakes on a C320 will NOT give the C320 any shorter stopping distance. Period. End of story. Anyone who thinks or tells you otherwise simply does not know what he is talking about.
The only time bigger brakes would decrease stopping distance is if the stock brakes are so small that you could overheat them and/or boil the brake fluid.
Believe me, no C320 street driver (is there any other kind of C320 driver???) will ever cook his stock brakes, no matter how hard a driver he thinks he is.
Thus, putting C32 or IndyCar brakes on a C320 won't do anything to decrease stopping distance.
Further, even if the C32 and the C320 didn't have ABS at all, putting C32 brakes on a C320 would not help it stop shorter. Without ABS, the C320 brakes would be more than strong enough to cause the wheels to lock up and skid. Obviously, that is the most one can ask of brakes. If the brakes on an non-ABS car are strong enough to lock up the wheels, obviously putting stronger brakes on cannot do anything to decrease stopping distance. A locked wheel is a locked wheel.
So, all the brembo, kleenman(sp I think) and other tunners big brake kits does nothing in improving braking ?
Now, lets go back to the original question.
Does anyone know if the c32 brakes will fit on the other c-class ?
ok, are u guys saying that there u nothing u can do to the c320 brakes in order to improve breaking ???
Get the AMG brakes, it will help your car brake better, in the sense of less stress and warping chances, will look better, and they will help you brake easier (not shorter but easier)
Looks better??? Umm, ok. That's a lot of time, effort and money to have "better looking" brakes.
Brake easier?? The brakes on these cars are overboosted as it is. Any easier and you will have Buick Le Sabre brake feel.
