C230K Coupe wind noise from sunroof at speed > 50mph
Is there any way to fix it or is it a common problem?
https://mbworld.org/forums/c-class-w...ars-fixes.html
or that's MY problem on my coupe.
Anyone else know what this annoyance is all about?
It's actually great having the glass roof, just sounds terrible when you try to drive with it open. Funny that it took someone else complaining about it for me to remember this annoys me, too.
I'm under extended warranty so guess I'll try to complain. It works great mechanically.
I've never tried STT to find out what that little thing is for.
I just got a new sunroof, and still no hump, which is fine with me. The more wind, the better. My hair will always have that just-blown dry look.
Something like this would actually solve the problem. I think it was a VW part or VW third party add on. I recall recoiling at the 35 dollar price tag.
otherwise, air would enter the sunroof causing more turbulent flow over the top.
i have the same problem and noticed that at certain speeds there is a "tone" that the open sunroof makes, and i think that it is not the best design. if i drive just at the right speed it can get very loud just like blowing into a large coke bottle. BUT... if i drive either faster or slower than that speed it goes away.
There is actually more than one speed that this happens relating to the sound harmonics and its annoying. Just adjust your speed (faster or slower... i recommend faster)
to avoid ithope that helps
it gets so loud at times, it is basically impossible to drive with it open, unless you want to go deaf
I'll record a video today with my camera phone
My car was on the sun the whole day, dunno if that had anything to do with it...
Just ordered the repair DVD manual from mercedes
I shall investigate further!
), and I think part of the reason why the humming noise exists is because that front wind deflector that raises up isn't really fully doing it's job. I think when you go fast enough, that stream of wind that is supposed to be redirected over the sunroof opening ends up hitting the sunroof itself, or even coming into the car (making noise). I think that wind deflector, at high speeds, needs to adjust to a steeper angle in order to allow that wind stream to "make it" to the rear of our roofs, rather than hitting the sunroof itself, or whatever else is causing wind turbulence/noise.
Just my wanna-be-aerodynamics-engineer .02
, and on my way back, I drove with the sunroof open, it started making the noise , and I pushed the wind deflector down with my hand, held it for a few seconds and the noise was gone!Now the question is, how do we make it so when it opens, it sits at a steeper angle, like you said.
Yep, it appears (for me) at about 45 mph and reappears at about 90...and should (I'd assume) reappear at about 135.
Changing speed by just a bit either way solves the issue.
There are several fixes.
1. Close sunroof slightly. You'll notice that each position of the sunroof has a "sweet spot" that causes this buffeting noise. Adjust as needed.
2. Open a side window a crack.
3. Retrofit a glass deflector with one that has a hump. Looks like MB recognized this as a real problem, so they made a new OEM part. ($$$)
4. Make your own "hump" to minick the MB solution. I used a $2 black rubber "door guard". You wouldn't even know it wasn't OEM.
I thought maybe it was the rubber gasket at the front of the deflector, and if you pull the deflector down the noise does go away. I was going to disconnect the arms that raise the deflector and just let it sit there limp. But if there is a fix
I tried the sunroof in all positions, once the noise starts, it will not go away until it is almost closed, at least on mine. Windows opened closed or cracked a little. I happen to like riding around, especially at night, with the roof open, what PIA with the noise.
So if you cold please post up the fix I think it would be greatly appreciated by all that still have some of our hearing left
Any thick rubber strip can do the job in theory if glued down. And yeah, I used a rubber door guard. I would recommend some good glue though, as mine flew off on the highway during a really hot summer.
