View Poll Results: MB & AMG wheels
AMG
0
0%
OEM MB
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 OEM MB & AMG Wheel Thread - All you want to know
Old Apr 7, 2009 | 05:29 PM
  #326
Glyn M Ruck's Avatar
Super Moderator
Tyre Dimensions Explained
Please forgive the limitations of the text editor
Tyre companies through out the world follow standard norms for tyre dimensions, tolerances, load carrying capacities and inflation pressures for the different tyre categories and sizes. These are decided and governed by tyre manufacturer's association. The basic tyre and rim nomenclature is explained below:
OUTSIDE DIAMETER (OD): The diameter of an unloaded tyre, mounted on its recommended rim and inflated to recommended pressure.
SECTION WIDTH (SD): The width of the inflated tyre section, excluding any lettering or decoration.
SECTION HEIGHT (SH): The radial distance between where the bead sits on the rim to the outer most point at centerline.
STATIC LOADED RADIUS (SLR): The radial distance between the road surface to the axle center under nominal tyre load /inflation conditions.
LOADED SECTION WIDTH: The width of the loaded cross-section.
MINIMUM DUAL SPACING: The minimum recommended distance between centerline of dual mounted tyres to avoid the tyres rubbing against each other.
ASPECT RATIO: The ratio of section height to section width expressed in percentage.
There's a lot of useful information molded into the sidewall of a tyre. It shows the name of the tyre, its size, whether it is tubeless or tube type, the tyre grade, speed rating, the maximum load, maximum inflation, an important safety warning and more.
Radial:
P 215 65 R 15 89 H = as below in order
Passenger Car
Section width
Aspect Ratio
Radial
Rim Diameter
Load Index
Speed Rating
"P" means this is a passenger car tyre (as opposed to a tyre made for a truck or other vehicle). P- metric is the U.S. version of a metric tyre-sizing system.
"215" Section Width: The width of the tyre in millimeters from sidewall to sidewall. This measurement varies depending on the width of the rim to which the tyre is fitted: larger on a wider rim, smaller on a narrow rim. The number on the side of tyre indicates the width measured with the tyre fitted to the recommended rim width.
"65" Aspect Ratio: The ratio of height to width; this tyre's height is 65% of its width.
“R" Construction: How the plies are constructed in the tyre carcass. "R" means radial. "B" in place of the "R" means the tyre is belted bias construction. "D" in place of the "R" means diagonal bias construction.
15" Rim Diameter: The diameter of the wheel in inches.
"89" Load Index: This tyre has an industry-standard maximum load of 580 kilogram. Different numbers correspond to different maximum loads. The maximum load is shown in lbs. (pounds) and in kg (kilograms), and maximum pressure in PSI (pounds per square inch) and in kPa (kilopascals). Kilograms and kilopascals are metric units of measurement.
"H" Speed Rating: This tyre has an industry-standard maximum service speed of 210 km per hour. tyres using an older European system carry the speed rating in the size description: 215/65HR15. Different letters correspond to different maximum service speeds.
The letters "DOT" certify compliance with all applicable safety standards established by the U.S. Department of Transportation (DOT). Adjacent to this is a tyre identification or serial number; a combination of numbers and letters with up to 11 digits.
The sidewall also shows the type of cord and number of plies in the sidewall and under the tread.
Attached Thumbnails W203/CL203 OEM MB & AMG Wheel Thread - All you want to know-tyreschool_nomenclature.jpg
Old Apr 7, 2009 | 06:15 PM
  #327
Super Moderator
Speed Rating etc.
Tyre Grades: Uniform tyre Quality Grading System or UTQG
Except for snow tyres, the DOT requires tyre manufacturers to grade passenger car tyres based on three performance factors: tread wear, traction and temperature resistance.
Tread Wear
More Than 100 - Better
100 - Baseline
Less Than 100 - Poorer The tread wear grade is a comparative rating based on the wear rate of the tyre when tested under controlled conditions on a specified government test track. A tyre graded 200 would wear twice as long on the government test track as one graded 100. Your actual tyre mileage depends upon the conditions of their use and may vary due to driving habits, service practices, differences in road characteristics and climate. Note: Tread wear grades are valid only for comparisons within a manufacturer's product line. They are not valid for comparisons between manufacturers.
Traction
A - Best
B - Intermediate
C - Acceptable
Traction grades represent the tyre's ability to stop on wet pavement as measured under controlled conditions on specified government test surfaces of asphalt and concrete. The Traction grade is based upon "straight ahead" braking tests; it does not indicate cornering ability
Temperature
A - Best.
B - Intermediate
C - Acceptable
Load Index and Speed Rating
The speed rating is the maximum service/sustained speed of a passenger car tyre. Truck tyres are not speed rated. Here is a list of rating indicators and their mile-per-hour equivalents. This rating system applies to all tyre makers.
Attached Thumbnails W203/CL203 OEM MB & AMG Wheel Thread - All you want to know-speed-ratings.gif
Old Apr 7, 2009 | 06:33 PM
  #328
Super Moderator
For your edification - from wheelbarrow to Veyron.
Speed index Speed in mph
A1 3
A2 6
A3 9
A4 12
A5 15
A6 19
A7 22
A8 24
B 31
C 37
D 40
E 43
F 50
G 56
J 62
K 69
L 75
M 81
N 87
P 93
Q 99
R 106
S 112
T 118
U 124
H 130
V 149
ZR >150
W 168
Y 186
I give up with this text editor
Old Apr 7, 2009 | 06:37 PM
  #329
acr2001's Avatar
2012 C300 4Matic
Thanks Glyn!!!
Old Apr 12, 2009 | 05:52 PM
  #330
CMFIC's Avatar
C230 coupe
Will W204 wheels fit my W203?
I have an 03 C230 sedan that I would like to put wheels from an 08 C350. The C350's wheels are 17". Anyone know if these will fit? I know the tire size/bolt pattern is good. I am more concerned with the offset.
Any help would be apprecaited.
Old Apr 12, 2009 | 07:15 PM
  #331
HellsAngel's Avatar
03 c320 coupe
you will need spacers. search for forum for more info... already discused 100 times
Old Apr 12, 2009 | 10:38 PM
  #332
mlg's Avatar
mlg
06 C350 sport 6MT
no longer needed
Old Apr 15, 2009 | 02:36 PM
  #333
carusomaas12's Avatar
Need OEM wheels - Want to trade for mine?
I need four 17" OEM wheels for a 2007 C230. Will trade straight up for these Rial, 18". I am trying to return my leased C230 and need my OEM's back on it to do so. Otherwise I love these wheels. See below/attached. I am in NJ
Attached Thumbnails W203/CL203 OEM MB & AMG Wheel Thread - All you want to know-rial_porto_bstn_ci3_l.jpeg
Old Apr 15, 2009 | 02:38 PM
  #334
sleewell's Avatar
2011 E350 4matic
don't you think size would be a good thing to include here; both of the ones you have and what you are looking for???
putting in your location will never hurt either.
just a thought....
Old Apr 15, 2009 | 03:23 PM
  #335
Was editing as you wrote it...but thanks
Old Apr 15, 2009 | 04:39 PM
  #336
bdgdl08's Avatar
1999 CLK320 (sold), 2007 C230 SS (gone), 2000 Grand Marquis, 2011 CR-Z, stay tuned...
What mods do you have to accommodate the 18" wheels? You said it was a 2007 C230? Everything else stock?
Old Apr 15, 2009 | 04:51 PM
  #337
Everything else is stock
Old Apr 15, 2009 | 04:52 PM
  #338
bdgdl08's Avatar
Any rubbing issues that you have noticed? How's the ride difference? Could you post some pics of the wheels on your car?
Old Apr 15, 2009 | 05:06 PM
  #339
07 Benz's Avatar
2007 C230 Sport
I have a pair of the OEM wheels I need to get rid of... not looking for a trade, cash only. Let me know.
Old Apr 15, 2009 | 05:22 PM
  #340
dblock2151's Avatar
I may be interested. Can you post some pics of the wheels, and do they include tires? If so, how much thread is left? My stockies only have like 1500 miles on them.
-Amar
Old Apr 15, 2009 | 05:55 PM
  #341
CMFIC's Avatar
C230 coupe
Wanted: OEM wheels/tires W203
Looking for a set of stock wheels for my 03 C230. I need them to have tires mounted. Preferably in good condition. SoCal preferred.
Old Apr 15, 2009 | 06:34 PM
  #342
shivi1345's Avatar
MK IV .:R32
PM sent
Old Apr 15, 2009 | 07:02 PM
  #343
FFemt5287's Avatar
2005 C230K Sport Sedan, 2004 ML350
im selling a set in the classified section
Old Apr 15, 2009 | 07:04 PM
  #344
Nokiemon's Avatar
CLK55 AMG, SL55 AMG, C55 AMG
I too have an OEM set listing in classifieds and will deal with you on price and shipping if interested. PM me if you wish. Thanks,
Old Apr 16, 2009 | 06:56 AM
  #345
I would be open to trading the tires too....easier to trade. They are about 10k miles in. I am also open to meeting at a body shop and having them demount mine from the tires, and mounting them to yours (and your wheels to mine). I'm flexible
Pics below
Someone also asked about potential "rub". I've not experienced any with these.
Attached Thumbnails W203/CL203 OEM MB & AMG Wheel Thread - All you want to know-img_5823.jpg   W203/CL203 OEM MB & AMG Wheel Thread - All you want to know-img_5824.jpg   W203/CL203 OEM MB & AMG Wheel Thread - All you want to know-img_5825.jpg   W203/CL203 OEM MB & AMG Wheel Thread - All you want to know-img_5826.jpg
Old Apr 16, 2009 | 07:53 AM
  #346
SickSpeedMonte's Avatar
2007 C230 and 1985 Monte SS
They're going to have fun trying to mount 17" tires to 18" wheels and vice versa... I'd say you are going to have to trade tires to get what you want/need.
You might want to add whether its a staggered setup.
Old Apr 16, 2009 | 09:57 AM
  #347
ha..thanks. I didnt think of that. I guess we're talking about trading wheels/tires as a package.
Old Apr 16, 2009 | 04:41 PM
  #348
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Though they are not stock, they have styling cues from various stock rims.
Interesting.
Old Apr 21, 2009 | 09:02 PM
  #349
91RS's Avatar
2016 Chevrolet SS, 2006 Cadillac STS-V
I figured I would just revive this thread to ask this question, since it'll probably help someone else in the future. I just bought my set of C63 wheels, so now I'm looking for spacers. I assume the W203s have the 66.5mm hub? That's what I'm seeing in all the spacers I can find. I'm looking at spacers from this seller:
http://cgi.ebay.com/ebaymotors/ws/eB...%3AIT&viewitem=
Also, what length lugs should I get? I've been looking around the internet, but haven't found how long the stockers are.
Old Apr 22, 2009 | 01:05 AM
  #350
CMFIC's Avatar
C230 coupe
Lug bolt length question
I have an 03 C230K Sedan, going from 19" aftermarket wheels to stock 17" from the 07 C230 sport package (5 spoke).
I do not have the bolts from the factory 17" set, the shop I took the car to thinks the lugs I am using for the 19s are a bit too short.
I dont want to have any issues, I know too short is bad. I have also read too long brings issues with the brakes, etc...
Question:
Where should I get these bolts, and how do I know if they will be the correct length? If I go to the dealer, should I request the lugs for the 07 sedan (b/c the wheels are from the 07)?
Is there a good dealer alternative so I dont pay $400 for lugs?
Anyone have a set for sale?
Thanks!
