Rotora Big Brake kit on CLEARANCE!
Former Vendor of MBWorld
Hey guys,
There's a set available under clearance pricing for ROTORA BBK on your C-class W203
Features:
-Rotora billet aluminum alloy 6piston racing calipers with sequentially sized piston bore sizes engineered to each specific vehicle.
-Rotora billet aluminum hat with �floating� disc assembly to reduce heat related stress and unsprung weight.
-Rotora 2 piece vented heat treated directional vane disc system to improve airflow/cooling under severe braking. Slotted or drilled & slotted oversize discs (355x32mm) to ensure equal heat dissipation and increase thermal capacity while relieving the disc and brake pad surface free of excess debris.
-Rotora ceramic formulated pads designed for extreme street and track application with high co-efficient of friction and high temperature fade resistance.
-Rotora DOT compliant stainless steel braided brake lines to improve stiffer pedal feel and prevent brake hose expansion.
-Rotora carbon steel (SC45) mounting brackets (depending on application) and hardware.
Clearance Kits available in:
Front- 6 piston 14"
Rear- 4 piston 13"
RED Calipers with DRILLED/SLOTTED Rotors
**Only 2 sets available for the front kit and 1 rear kit under clearance
PM/EMAIL/CALL ME for pricing!
Features:
Front- 6 piston 14"
Rear- 4 piston 13"
'97 S600, '93 300SE, '98 CL500, '04 S320, '07 525D
I really like the rotors, please tell me if they are ok for a C Class C220 CDI , and the price and the shipping cost to Romania. Thanks a lot
BUMP!!! Updated Pricing posted, need to move all this kits
**Sale price is on RED
Contact ME for questions or to place an order - 480 966 3040 ext 228
C CLASS (EXC AMG) 01-07 W203 F RBK097.02 6 FC6 355X32 2-PIECE $2,695.00 $1,886.50
R RBK098.02 4 FC4 330X30 2-PIECE $1,995.00 $1,396.50
