Tech savvy: Fuel questions
Old Jul 17, 2009 | 07:26 PM
NegroC230's Avatar
08 ML CDI
Please no stupid comments by unknowledgeable.
I was looking around the fuel rail, and havent noticed any fuel pressure regulators ( FPR) like any other german cars have . They usually go in increments from 3.0 Bar thru 4.0 and 5.0 bar... do we posses such a thing? also whats up with the fuel pump? i noticed it has 2 access doors. anybody know any technical specs on our units? FPM?
thanks in advance.
Old Jul 17, 2009 | 10:16 PM
Glyn M Ruck's Avatar
Super Moderator
thanks in advance.
Don't be cheeky
Presume your car is M271 I4 engine which has Motronic?
Here are the diagrams of the fuel system. You have 2 hatches under the back seat - RHS = pump & sensor - LHS = sensor. Lines feed from LP pump to HP pump & then into the main fuel rail via a damper to the injectors. I have no idea how pressure is set on the HP pump. I'm more au fait with the fully electronic 6 cyl system. I have not included the EECS (Evaporative Emissions Control System)
Good Luck
Attached Thumbnails Tech savvy: Fuel questions-fuel-lines.gif   Tech savvy: Fuel questions-hp-fuel-pump.gif   Tech savvy: Fuel questions-injector-rail.gif
Old Jul 17, 2009 | 10:18 PM
NegroC230's Avatar
08 ML CDI
thanks, very informative, however ..i am 2.5L v6...m272?
ps: what is number 55 on the last picture? right next to the injector
Old Jul 17, 2009 | 10:20 PM
Super Moderator
Damper
Old Jul 17, 2009 | 10:26 PM
NegroC230's Avatar
08 ML CDI
i noticed to have the sameunit on my rail too....but its too small to be looking like the FPR i was mentioning not to mention it doesnt have a vacuum port on it.
Old Jul 17, 2009 | 10:58 PM
Super Moderator
Sorry - I don't have 272 loaded at the moment - need to get it done. I'm giving you 112. All diags same for tank & lines. Only diff is fuel distributor - diag below. V6 has no HP pump. ECU controls rear pump to provide desired line pressure (measured at 14 - don't know spec). Injectors do pressurisation & metering on the fully electronic system.
Attached Thumbnails Tech savvy: Fuel questions-m112-fuel-rail.gif
Old Jul 17, 2009 | 11:48 PM
p_gill's Avatar
E400 Cabriolet
I don't have a nice diagram to share but the regulator is built into the fuel filter.
That's why the filter has so many connections.
Good luck
Paul
Old Jul 18, 2009 | 09:33 AM
Super Moderator
If that is correct - it is extremely interesting. I was not aware of that. When you say regulating - Do you really mean damping line surge or really regulating a peak pressure? If it's truly regulating I will never complain about the cost of a filter again.
Old Jul 18, 2009 | 11:33 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
<---not tech savvy.
Specification is ~3.8 bar.
Originally Posted by p_gill
I don't have a nice diagram to share but the regulator is built into the fuel filter...
p_gill is correct.
Old Jul 19, 2009 | 03:42 AM
Super Moderator
Thanks John - I learned something today - that's good - Savvy
Old Jul 19, 2009 | 01:43 PM
NegroC230's Avatar
08 ML CDI
thats what i call German Engineering, LOL
Old Jul 23, 2009 | 07:16 PM
derffred's Avatar
10 MB E350, 05 Subaru LegacyGT, 07 Yamaha R6
Mercedes Benz Tech chiming in.. approximate fuel pressure at the rail is 55-60psi, those units on the fuel rail are accumulators, they dampen the fuel pressure pulsed from when the injectors open and close.
Old Jul 24, 2009 | 11:11 AM
bumpnzx3's Avatar
W203 C230SS
no wonder a filter costs as much as it does.
