Is my C320 auto transmission faulty?
First, the transmission often seems to shift funny from 2-3 and from 3-4 gears under moderate-to-heavy acceleration. Just when it disengages the throttle to shift to the next gear, it will hesitate for a moment and then kick-in semi-abruptly when accelerating into the next gear. This is best described as a stutter. This stuttering sounds like engaging the next gear, then backing off very briefly, thenly re-engaging. Almost as if I killed the throttle right when hitting the next gear, then reapplied.
The other problem I believe is also related to the transmission, or maybe the throttle management system that works in conjunction with the transmission and shifting program. The other day, I was crusing at about 20 mph and accelerated sharply to get onto a freeway on ramp. I reached the top RPM range (far from red line) for the gear I was in (probably 3rd), and car went to shift on to the next gear. When it went to shift out of 3rd, it was like someone shut off the ignition (the throttle was cut off completely for about 1.5 seconds and the car slowed abruptly) though I still had my foot on the gas pedal. When the throttle and transmission re-engaged, it was in the next gear and accelerated rapidly. I've experienced this twice since I've owned the car.
Has anyone had these types of issues? Any suggestions or thoughts on what may be the problem? Of course these are intermittent problems, so I'm concerned they won't be able to reproduce them while it's in for service.
(I'd consider changing mechanics)
I am not sure if this means anything. Anyone
?First, the transmission often seems to shift funny from 2-3 and from 3-4 gears under moderate-to-heavy acceleration. Just when it disengages the throttle to shift to the next gear, it will hesitate for a moment and then kick-in semi-abruptly when accelerating into the next gear. This is best described as a stutter. This stuttering sounds like engaging the next gear, then backing off very briefly, thenly re-engaging. Almost as if I killed the throttle right when hitting the next gear, then reapplied.
How many miles are on the car and do you know if the transmission has ever been serviced?
Is there any service history on this car. Has the transmission been serviced every 39K miles or 60K Km's? If the transmission has not been serviced you are taking a big chance. At that mileage you are getting the car cheaply I presume. A major transmission repair could cost what the car is worth.
