Resistor for side marker lights?
Old Aug 19, 2009 | 07:59 AM
Oxygen's Avatar
W220 S65 AMG
Question Resistor for side marker lights?
Gentlemen... how are you? This is a FANTASTIC forum and I've been reading the stickies and stuff here the past few days and you guys have a wealth of information and very helpful members.
I've searched up and down, left and right and I still can't seem to find the information that I am looking for.
I painted my orange side markers to match the color of the car:
In the process I removed the bulbs because on my last car they melted the plastic lens because of the head due to the layer of paint.
As you can imagine I have the annoying SIDE MARKER L, R CHECK LIGHT message on the MFD now every time I fire up the lights.
Do you guys know how to eliminate this? Which resistor should I use? I tried a 100ohm resistor but it got ULTRA HOT and burned in about 60 seconds. I tried a 10W 100ohm resistor and it got pretty hot but seemed to dissipate the heat better, but I am weary of stuffing that in my bumper and waiting for it to go on fire as I'm cruising down the highway.
Your help is VERY appreciated!
Old Aug 19, 2009 | 08:08 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Resistors will get HOT. To help with that you can see if you can mount the resistor against metal, or locate it into an airflow. Both of these might help you with better heat dissipation.
Old Aug 19, 2009 | 08:59 AM
advans's Avatar
C55 ///AMG, 535xi
ahhh resistors.... I tried using 5ohm, 25watt resistors for my side markers, it worked great, and it didn't heat up THAT hott... but..chris, there's another way you can do this if you want "LEDS" just get another socket, splice it, and put another regular bulb.
Old Aug 19, 2009 | 09:25 AM
omg its nate's Avatar
06 C230 6 Speed FTW
OT: Rims are sweet.
Old Aug 19, 2009 | 10:27 AM
amanonfire's Avatar
W203
I tried a 100ohm 5W resistor and the message did not go away, despite the resistor getting very hot. I'll try a 5ohm and see.
My fit for the resistor heat was to pull the wires inside the engine bay and tie them to the fender support such that the resistor hangs in the air and touches nothing.
Old Aug 19, 2009 | 12:06 PM
shivi1345's Avatar
MK IV .:R32
Oxygen.....your car is AMAZINGG
I left the bulbs in the sidemarker.....but I wrapped them in electrical tape. At night you can kinda see a orange glow tho
Old Aug 19, 2009 | 12:14 PM
Oxygen's Avatar
W220 S65 AMG
Oh... is that safe? I think the electrical tape will melt.. FAST!
Thank you for the compliment, highly appreciated!
Someone suggest wrapping the bulbs in tin foil.
Old Aug 19, 2009 | 12:49 PM
06 C230 6 Speed FTW
I also heard warping them in foil is fine.
Old Aug 19, 2009 | 01:26 PM
amanonfire's Avatar
W203
Depends where you live. Wrapping them in foil will only serve to collect salt/water and corrode the contacts, and you'll be replacing them eventually.
Ask me how I know.
Old Aug 19, 2009 | 01:31 PM
shivi1345's Avatar
MK IV .:R32
lol I actually haven't looked at them in while.......
I guess I will when I get back home
......tin foil seems like a good idea.....it doesn't rain much in so cal
Old Aug 19, 2009 | 01:35 PM
Oxygen's Avatar
W220 S65 AMG
Oh SoCal.. the place I dream of being everyday.
Old Aug 19, 2009 | 07:40 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Just lay down like 6 more layers of paint on your side markers and leave the bulb in. It shouldnt show through
Old Aug 19, 2009 | 07:45 PM
Oxygen's Avatar
W220 S65 AMG
I don't know why it has not happened to anyone else... when I painted my markers last time and left the bulbs in, the plastic light casing melted from the plastic getting so hot because the paint held the heat in.
By the way I love those CLS wheels on your car... looks amazing!
Old Aug 19, 2009 | 08:13 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Woah woah. That def hasnt happened to me. Ive painted / sold like 10 sets of those things things w/ at least 3 layers of primer, 5 layers of paint, and 5 layers of clear... I have only used stock side markers though... Im assuming you are using the same 194 wedge bulb and cant imagine them running any hotter in the w220 than in the w203...
I love your comment on my photo, haha... Cracks me up every time I go back to that page. Sadly, I see that more and more people are doing what Ive done... Maybe its time for a change :x
Old Aug 19, 2009 | 08:21 PM
2006c230Mike's Avatar
2006 c230
Measure the ohms of the bulb you took out. (Resistance measurement with the VOM meter).
Divide 13.6 volts by the resistance to get the current in amps.
Multiply the current by the volts (13.6) to get the watts.
So a 100 ohm resistor draws .136 amps and 1.85 watts.
So anything less than a 2 watt 100 Ohm resister will burn out.
A 5 ohm resistor draws 13.6/5 or 2.72 amps.
13.6 x 2.72 = 37 watts. So the 5 ohm resistor should carry at least a 40 watt rating for safety.
Anyways, measure the ohms of the bulb and go from there to determine the wattage needed for the resistor.
Best of luck.
Old Aug 19, 2009 | 08:35 PM
Emin's Avatar
2010 C300, 2012 Mustang
The foil wrapping sounds like a good idea
Oxygen's Avatar
W220 S65 AMG
Oh snap I had no idea what you were talking about at first then I looked through your photos... I see the time that comment was left: 11-02-2008 06:00 AM... I must have just stumbled in.. probably pretty ****ed up... got a little excited about your car.... but it is sweet!
Old Aug 19, 2009 | 08:38 PM
Oxygen's Avatar
W220 S65 AMG
This is a great board... I appreciate all the input guys!
