Is the Door Handle on a C320 part of the Panel
Old Sep 25, 2009 | 12:39 PM
VillaCocos's Avatar
C320
I own a 2001 C320 and the driver side inside door handle won't do anything. I had it checked out at a body work shop and was told I needed a complete driver side door panel since the handle is part of the panel. It broke a small plastic base which is part of the handle. Is it true that I have to replace the whole panel? And if this the case, where can I get a new or used replacement?
Old Sep 25, 2009 | 12:57 PM
mleskovar's Avatar
'17 Jaguar XF
What part are you talking about? The door pulls often break and the pieces are available to repair. There are several posts (look through '01 - '03 years) on the problem and fix.
Old Sep 25, 2009 | 02:39 PM
acr2001's Avatar
2012 C300 4Matic
Are you talking about:
Exterior handle
interior plastic door pull
the chrome interior door handle (for opening the door)
Old Sep 25, 2009 | 02:44 PM
VillaCocos's Avatar
C320
The part I'm talking about is the inside openning handle (chrome). It still swings when you pull to open the door but if feels completely free; obviously, the door doesn't open from the inside. I have to open the window and open it from the outside.
Can it be fixed or do I have to replace the door panel like I was told at the shop?
Thanks to all for the help.
Old Sep 25, 2009 | 02:47 PM
e1000's Avatar
a quarter mile at a time
you mean the door handle shells????
Old Sep 25, 2009 | 02:54 PM
VillaCocos's Avatar
C320
It's the inside handle (chrome) that opens the door from inside. See previous comments for more info.
Thanks for your interest.
Old Sep 25, 2009 | 03:00 PM
e1000's Avatar
OH I see. I'm not sure then and I don't remember what it looked like when I took apart my door panel last.
Old Sep 25, 2009 | 04:11 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
you should be able to remove the door-lock handle separately.
Old Sep 26, 2009 | 03:00 AM
WaveyKat's Avatar
Something Slow
yes its separate! there is a screw on the inside of the panel thats holds it in place.. you need to check and see if the Cable attach to the Chrome Handle didnt came loose.. i may be able to get you one!
Old Sep 26, 2009 | 04:04 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Ouch. Having to open the window to open the door on a Benz must be a real mood killer.
Hope you get it resolved!
Old Sep 28, 2009 | 09:01 AM
VillaCocos's Avatar
C320
Thanks to all for the comments. WaveyKat; the cable did not come loose, there is a small plastic base on the handle that broke. This plastic piece is on the inside side of the panel.
Old Sep 28, 2009 | 01:07 PM
krisv420's Avatar
02 C320 Sedan
i still need to learn how to remove the door panels then i can take apart the whole car by myself =P
