M272 Do It Yourself
I think any JDM ECU flash is probably cheaper than Mercedes. I wouldn't mind getting something like this started, I have programming knowledge but never messed with ECUs.
No problem Drex, once I have time i'll get more for all w203 engines. In the meantime if anyone need anything PM me and i'll get the diagram for you
http://www.mercedestechstore.com/pdf...2008-05-04.pdf
http://www.mercedestechstore.com/pdf...9%20062504.pdf
Good Reading
http://www.mercedestechstore.com/pdfs/
I would think it's straight forward (remove drain plug, let all fluid drain out, put back drain plug, open fill plug, pour new fluid, put back fill plug) but before I venture on to this project, I wanted to see if there are any other cross-members need to be removed or any other things I need to know.
https://mbworld.org/forums/c-class-w...haft-bolt.html
If i'm not mistaken the P0010 is the camshaft solenoid. Have a look at the solenoid document.
