How long does it take for the AC to turn off?
Old Oct 9, 2009 | 03:52 PM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
How long does it take for the AC compressor to turn off when you push the AC button off? My dealer is telling me it should take 15 minutes from the time that I push the AC button to "Off" for the compressor to turn off. The LED goes off immediately. This sounds bogus to me. This is on an '06 with the temperature dials.
Old Oct 9, 2009 | 04:35 PM
e1000's Avatar
a quarter mile at a time
#1, why are you turning the AC off in Phoenix!
#2, yes it takes a while, i wouldn't be suprised if it was more than 15 mins. There is no AC compressor clutch on our cars like other cars.
Old Oct 9, 2009 | 04:54 PM
glocati's Avatar
2016 GLE 350
Mine seems to stay on for ~ 10 minutes before it stops pumping refridgerated air.
Old Oct 9, 2009 | 05:30 PM
wvadam's Avatar
C230 COUPE 2003 M271
why does it have no clutch? and how does this work. why does it take that long to shut off?
this is very strange indeed
Old Oct 9, 2009 | 05:57 PM
acr2001's Avatar
2012 C300 4Matic
No idea why they designed it to wait 15 minutes after you turn it off, but they did. If you turn the climate control off completely and then turn it back on the A/C will shut off immediately.
Old Oct 9, 2009 | 06:13 PM
lkfoster's Avatar
That's how I force the AC off.
The curious bit is that the loaner w204 turns the AC off almost immediately when you toggle the AC button off while in Auto.
Old Oct 9, 2009 | 06:17 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Same with my 05.. takes a while to stop putting out cooled air.
Old Oct 9, 2009 | 06:46 PM
Glyn M Ruck's Avatar
Super Moderator
These units use a swash plate compressor to reduce NVH - no clutch. When you turn off the switch the compressor swash plate returns to vertical & ceases compressing refrigerant. It takes a while for the pressure in the circuit to drop & refrigerant circulation to cease in the evapourator. Only way to stop it is to cut air flow through the evapourator
Old Oct 9, 2009 | 07:53 PM
e1000's Avatar
yeah what Glyn said
Old Oct 10, 2009 | 02:40 AM
hanknum's Avatar
'02 C320 Wagon, '78 308 GTS, '06 Highlander Hybrid
Kind of a lame system I think. Most people will turn it off when they start to get too cold...now I have to guess that I'll get too cold in about 15 minutes.
Old Oct 10, 2009 | 02:52 AM
e1000's Avatar
if you turn the heat on, warm air will come through the vents instantly. We're talking about shutting AC system off only.
Old Oct 10, 2009 | 03:02 AM
hanknum's Avatar
Yeah, me too.
Old Oct 10, 2009 | 10:39 AM
Super Moderator
Well at least it is silent & does not induce vibration like crude crappy old clutched units.
