Adding 1 quart of oil to 2005 C230 Kompressor sedan
My Service B was 7,000 miles ago, and the car was serviced with 5w-40 Kendall GT-1 synthetic.
Next Service A is in 6,100 miles.
Should I keep plugging along until the Service A, or get an oil change now?
7k before adding a quart is nothing to be too worried about, imho.
As Tommy said - do as the computer says and don't think too much into it.
I have burned 1/2 quart so far and I have 4,000 miles till next service.
bad or worn valves (seals/guides), pressurized crank case, or blow-by from worn pistons. I already had a valve job and the head replaced on my C230 at 34,000 miles... so I'd be a bit more cautious than most... because it's a freaking expensive fix. Don't wait for your computer to tell you that your car's f*ck'd up.. that's just stupid advice.. sorry.
I wouldn't call a quart of oil (assuming that it was originally fully topped off, of course) in 7k to be that much out of spec, and MB doesn't, either.
Maybe your car and my car should meet up for a couple of drinks (my car will outdrink your car-my car is the one on the right)
On a serious note, I think you are fine. Since you added a quart measure the oil see how much you got in there. Maybe you were low to begin with
My car loves to drink oil and the dealer did an oil consumption test and said by the time my interval is over I will have to add 3 quarts of oil
So you are fine (for now)
Use 229.5 oils for future reference. Mobil 1 0W-40 Euro Car formula is an excellent choice.
Edit: Also, use dyno mode and check your level. It should say 5.5L (5.8 quarts).
Should I get an oil change right now, or wait until my next Service in 6,000 miles?
Is that 1 quart of different weight oil that I added going to cause damage?
http://bevo.mercedes-benz.com/bevoli...&language_id=1
Chevron make Chevron Supreme in a fully synthetic & the ISOSYN version which is just a Group II ISO dewaxed product from the Richmond refinery. Still a very good product but does not meet 229.5 - was never designed to.
Relax. As long as you did not put gear oil etc in the engine you are fine.
off topic...Not sure about this...but my MB mechanic have advised me to change the oil every 5K and not wait 10K. (Synthetic Mobil1 5w-40.)
That's too early isn't it? (half the interval)
