climatronic
Who has managed to change the a/c control from the analog buttons to the digital display controller. I am talking about a w203 sedan and not coupe. I have read people changing it in a coupe using a certain climatronic (from the older generation)! So anyone managed, once again it is a w203 sedan! Here in austria, i have been told, one needs to change the entire A/C which makes it damn expensive!! Another question, can the temp be shown only in °F or also in °C?
Thanks for your help
greetings from vienna, austria
Rumman :p
However, there have been some problems on Coupes when making the switch because Mercedes changed suppliers for the unit sometime in 2002. Make sure you get an older one or it probably won't work.
Search the forum for part numbers (to determine old vs. new), etc.
Cheers, BT
rumman
203 830 09 85
If you find 203 830 02 85 it might not work since it does not work in the coupes, but then again it might work in the sedans.
Erik
Thanks for your answer... i am just wondering whether anyone did it for a w203 sedan...
Look for a user on here named MBenzNL (Steve) and ask/PM him, he's the king of parts swapping. He'll know for sure.
Cheers, BT
thanks,
greetings from vienna,austria
rumman
and it is just a plug and play with all functions? I mean i have read things like just hot air coming out or just cold air over two vents etc...
thanks,
rumman
Erik
i have read through most of the threads and the people who had trouble are the ones that used 203 830 02 85...
what did you mean with people had trouble: if it is like that they were not able to use the tunnel mode then i am fine with that, i am not that bothered about the mode, main thing is that the functionality of cooling and warming is ok...
thanks, Rumman
PS: what is more advisable: getting a 203 830 05 85 or .. 09 85
hi again
thanks, Rumman
There is no 203 830 05 85
Its 203 830 09 85
or
203 830 02 85
The '09' works in the Coupe...however both should work in the sedan...if you can find a '09' you prob. have better odds that it will work fine.
Erik
As discussed per mail, I have used several 05 85 units...they worked in my father's (euro) C200K (sedan) and in a US G500 and C230k (coupe) but NOT in a US C240 (sedan).
The C240 sedan only blew cold air and no heated air at all...
The airflow can only be adjusted from the driverside selector...the passenger side selector doesn't do anything. The tunnelmode did function as far as windows go...the roof didn't react to the tunnelmode feature though.
These units automatically display degrees Celsius or Fahrenheit when plugged into a US/Euro car.
greetingz,
greetingz,
I've read where people think that simply replacing the low end climate unit with the climatronic they will have output equivalent to climatronic. Is this true? What about the extra ducting and controls for the second charcoal filter?
erm...I am pretty sure there is a 203 820 05 85...I have sold 2 of those in the past and have 10 left...and 10 with the 09 85 partnumber...
02 85 doesn't appear to work at all in a C230K/C240. 09 85 works in most cars (but maybe not in California ones according to CitronC230K_03's parts guy). The 05 85 should work, but apparantly not in every car (although people have been able to make this one work in a California car). My impression is that for some reason, it is just luck of the draw if the 05 and 09 versions work or not.
Cheers, BT
It should be possible.
Cheers, BT
i was unable to get the older generation unit to work in my coupe. i had a unit which ended with 09 85, and it just blew cold air out of the defroster vents no matter the setting. i couldnt figure out why it didnt work, i installed 4 times before i sold it. i havent heard any ocmpaints so im assuming it worked for him. my car was built dec. 19, 2002. id be guessing so i have no idea why it didnt work!
Erik
one told me that it may be because my production date requires a 02 85 model, but i dont want to buy one and not be able to return it.
- BT
