How to install a flat hood emblem for W203
Old Jan 29, 2002 | 12:46 PM
deschute2000's Avatar
C 320 2002
I have a difficulties to uninstall the original star emblem , can someone help me please ?
Old Jan 29, 2002 | 12:56 PM
benzomonterey
Guest
Posts: n/a
star removal instructions
Try this link
star removal
Old Jan 29, 2002 | 12:57 PM
Jorel C320's Avatar
2001 C320
Get some pliers and twist.
Old Jan 30, 2002 | 11:40 AM
Addy's Avatar
C240
I didn't even use a plier, i just turn it 90 degree to the right by my fingers, it will free to go from the hood
Old Mar 29, 2002 | 02:07 PM
jy2010851's Avatar
2002 C320
flat emblem hood
Hi,
I just got the flat emblem hood but can't seem to find the way to install it. I took off the original emblem but the flat hood one doesn't seem to fit( it's a bit loose). Am i missing some pieces or is there anything i have to detach from the flat emblem hood itself? (All i can play around is the nut and this black rubberish thing)
Please help
Old Mar 29, 2002 | 02:25 PM
MB-BOB's Avatar
Admin Alumni
See Garage
The flat, brass piece goes from the top of the hood (threads first), and the black rubber thingie wedges it to the hood from underneath. The bolt holds the rubber thingie in place and ensures the tight fit.
The emblem itself has two plastic posts. There should also be two white grommets, that fit into the brass piece from above. Don't push them all the way into the brass fitting, otherwise it will be difficult to press the emblem all the way down... leave about 1/8" protruding. Then push the emblem posts into the grommets and all the way to the hood.
It takes some fiddling.
Old Mar 29, 2002 | 07:40 PM
M Brabus's Avatar
97 E420
tighten the nut, but not all the way (not on the hood yet). then insert from top of hood and rotate it, so the black rubber is horizontal/perpendicular to how you want the 2 holes to line up.
the tricky part is while you're tightening the nut all the way (from under the hood), the top brass piece will rotate with it (which means your emblem will be mis-aligned).
what i did was to insert a screwdriver from the top so it would prevent the brass piece from rotating.
tighten the nut so there is no play or movement. then insert the emblem with the grommets. (the thing i did different from MB-BOB was that i had inserted the grommets onto the emblem itself as opposed to the brass piece). i don't think it'll make a difference though...good luck!
Old Mar 29, 2002 | 10:42 PM
MB-BOB's Avatar
Admin Alumni
See Garage
Nice variation, M Brabus. I'm sure there's no difference in the procedure, but I was concerned if I put the grommets on the emblem, there might be a chance to break the posts from the emblem while pushing the emblem into the mount (if it turned out that I had to push really hard to get it to lay flush with the hood). That didn't turn out to be a problem, so I'm sure either procedure will work.
And you are certainly right about the alignment. Took several "loosen/rotate/tighten" cycles for me to get it straight!!!
Old Mar 29, 2002 | 10:50 PM
jy2010851's Avatar
2002 C320
when i first got the emblem the badge was already attached to the brass piece..so all i could do was rotate the black rubber thing and then tighten the screw..i hope i did this right.
by the way does anything come off from the original that might go under the screw part, because first i thought i had to detach the spring part of the original and somehow attach the flat emblem into the rotating piece of the original emblem
thanks for your replies~ Great help!
Old Jul 26, 2004 | 01:30 PM
wdougla1's Avatar
2018 C43 AMG SEDAN
flat hood emblem
Where can I buy a flat hood emblem for my 2005 C230 Sports Sedan?
Old Jul 26, 2004 | 01:34 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
the dealer.
Old Jul 26, 2004 | 02:13 PM
Kev04C320's Avatar
'09 911 C4S
formymercedes.com
Old Jul 27, 2004 | 07:14 AM
turbo t terry's Avatar
We just asked our dealer to put the flat medallion on the car in place of the star before we took delivery. They said it was a simple change, since they have to install the hood ornaments on all the cars anyway.
Old Jul 27, 2004 | 10:24 AM
Jon200's Avatar
which brand ur after?
search on eBay, there are heaps in there
Old Aug 2, 2004 | 12:55 PM
rootsmon's Avatar
Need a Flat Hood Star Emblem
Need a Flat Hood Star Emblem for my 05 c230 sedan. Anyone know where to get a good deal online for an MB authentic one of these? Is the install pretty easy ?
Thanks!
Old Aug 2, 2004 | 01:01 PM
check ebay, or the classified section of MBWorld. easiest, and fastest way i would say is go to the parts dept. at your local MB dealer. Try and find one the sells wholesale. Hoehn MB in Carlsbad does.
Old Oct 17, 2004 | 12:22 PM
bigtree1316's Avatar
How to remove stock hood emblem W203
Does any one have photo instructions on removing stock hood emblem? I have hear about using piler then turn 90 degree. Is there more detail?
Old Oct 17, 2004 | 01:18 PM
Incendiary's Avatar
2014 E350S4
formymercedes.com has the cheapest price, and I just got one from them. They were backordered for a week or two, though, so who knows if they'll be out of stock again now.
From their website:
Installation:
Remove the original Mercedes "standing star" emblem by twisting it from under the hood. Once the spring pressure is released, it will pop out. Insert the white sleeves into the top of the emblem holder. The flat part of sleeves will be on top. Install the emblem holder with the attached nut and black clamp firmly, but not completely tight - so it can still be turned for proper positioning of the emblem. Add a little silicone adhesive under the hood emblem. Then press the fingers of the emblem into the white holder sleeves. Position the emblem to face correctly, then tighten the nut on the holder.
You can remove it easily by just getting pliers and gripping the prongs underneath, not squeezing them together, and just turning. Then the whole assembly slides out.
Old Oct 17, 2004 | 02:11 PM
05 KOMP SS's Avatar
05 C230 SS Brilliant Silver
Just received mine from formymercedes.com this week. Installation is as described above very simple to do.
http://www.formymercedes.com/mb_resu...tegory=Grilles
Old Oct 17, 2004 | 09:07 PM
pickupjason's Avatar
C230 K
buy it from formymercedes.com..Jerry is cool as well as the price. Also, Jerry sells the mb flat emblem, I believe some ebay seller sells "fake" piece of shxt emblem from Asia.
Old Oct 19, 2004 | 12:42 AM
thanks
Old Oct 19, 2004 | 01:12 AM
Sauceboy01's Avatar
Blimp
it's actually cheaper on EBAY!! make sure you check it out..
here's a link to one.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
ebay rocks! and it's cheaper then formymercedes
-Danny
Old Oct 19, 2004 | 03:00 AM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
yeah,
if you're into cheap Taiwan knock-offs that will chip away in the sun.
Plus with the Shipping & Handling charges all these scammers charge, you make out better buying from the Dealer, AUTOWERKS Direct, or ForMyMercedes.com, and you get an authentic MB part.
$0.02
Old Dec 1, 2004 | 03:58 PM
terp97's Avatar
20 E350 & 17 GLS450
Originally Posted by CitronC230K_03
the dealer.
I just got off the phone with the dealer because some vandels toke the upright hood ornament off and had to have it replaced at the cost of 81 dollars. I asked if he could replace with the flat hood ornament and he said not able to do it on my 2004.5 C230K Sport Sedan. I asked again are you sure and he said the tech said you could not... IS this true or not? I might research tells me it is not!
Old Dec 1, 2004 | 04:02 PM
MBAMGPWR's Avatar
W215 CL600
Not correct and $81 is freakin' outrageous! It's a shame that dealerships still try to ripoff their own customers. Try eBay or the recommendations here in this thread to get a flat hood emblem.
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
