***2003 w203*** Side Mirror Signal Bulb Size?
2003 c230k Sedan
I've been searching for hours with no success...![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
Does anyone know the Bulb Size for Side Mirror Signal Bulbs for 2003 w203?
Thank you !
Thank you !
Correct me if Im wrong but thier LEDs and they are in an assembly you would purchase from the dealer, you cant replace a singular bulb
Super Moderator
https://mbworld.org/forums/c-class-w...er-broken.html
read this those are the side mirrors![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
and yes they are led. if you have a led out or a side is not working your only real option is to buy a new one unless you want to crack one open and work on it. GL
2003 c230k Sedan
For 2004 w203 and up, the assembly is one piece.
However, for the 2003 model, you take the assembly out and replace each bulb.
The 2004 assmbly LED assembly doesn't fit in the 2003 model.
Any Suggestions??
I've actually replaced the amber bulbs for bright white in 2004 after a long and hard search.... but I haven't managed to find those bulbs, or the bulb size again
Any Suggestions??
2003 c230k Sedan
Success:
The Bulb Size for Side Mirror Signal is #74 bulb (looks like a mini-194 bulb) located: http://autolumination.com/74.htm
This is only for the 2003 w203 and not for 2004+
Super Moderator
i know all that but most people would not replace the bulbs individually that is what threw us off. sorry but did you even read the thread i sent you to the lights you have are the same as my 01 were and then i put in the new style. but if you like the frosties better enjoy
2003 c230k Sedan
I assumed the assembly was for the newer model car. You think it would fit on my 03?
I've purchased the assembly back in 2004 and it didn't fit and had to return.
The LED's look great on the car.
Did you order the amber ones? I'm looking for bright white as I've changed for the rest of the car.
Thanks for your help.
Super Moderator
if you order the one i have linked in that thread i know it will fit any w203. are you sure you ordered the correct one because they have not changed the shape or mounting of it on any w203 as far as i know. they are clear bulbs that light up amber. i don't think you would be able to make them white though. GL
2003 c230k Sedan
I did it back in '04, but once I get the new bulbs in, I"ll let you know if they are definitely the bulbs.
Here's what it looks like:
![](http://xb5.xanga.com/a67f650711335259445895/t206602627.jpg)
2003 c230k Sedan
I recently found Clear Side Mirror Lens with BRIGHT WHITE LED, not amber. Let me know if anyone wants the info.
First of it's kind.
First of it's kind.
2003 c230k Sedan
Success:
LED White Lights w/ Clear Lens in !
![](http://farm3.static.flickr.com/2747/4156968234_d7d9c00ac0.jpg)
Also Changed to new CL sports grille and flat Hood Badge
![](http://farm3.static.flickr.com/2669/4156966346_28c1fecc56.jpg)
Easy Install, less than an hour for all three mods.
Let me know if you have questions, happy to help.
