All About Trey and Cars
Old Nov 17, 2013 | 01:37 PM
  #626
samaritrey's Avatar
Super Moderator
THE C350
Sad way for a Mercedes to go out.
Old Mar 2, 2014 | 01:31 AM
  #627
samaritrey's Avatar
Super Moderator
THE C350
So to update everyone on my car I am at 212,000 Miles. Car is doing decent needs the passenger side lower control arm replaced (have part just need some warm weather) also needs new front brakes as something happened to the rotors and the pads are wearing out really fast for some reason. Just ordered some new Rotors and Akebono pads so hope they will serve me well. I also have a fuel filter to go in as the current one has about 110,000 miles on it. I am also having some engine noise that I believe is the timing chain posted a link to a video what do you guys think? (FYI it makes the same noise with belt off I replaced the water pump because I thought it was what was making this noise and was very upset to find water pump was perfect even with 200,000+ miles on it and still had this noise) At first startup I can hear it very slightly but really don't hear it till car is warmed up unless it is just a tensioner I am going to ignore it until it snaps/skips as it is way to much work to deal with on an engine with this many miles. I also need to change the fluid in the Rear dif (have had fluid for 2 years now) and do a transmission fluid flush or drain again which should I do flush or pan drain? I did an oil change a few months ago and had an analysis done as you can see in the picture the 0w-40 had 9,600 miles on it when I did the change and I had to add 3.25 quarts of oil over the life of the oil (I am leaking at the rear main seal and probably burning some at this many miles) Glyn if you read this what do you think about the results also any insight on the fuel in the oil?
Engine Noise link http://www.youtube.com/watch?v=QRKnL...ature=youtu.be
Old Mar 2, 2014 | 02:09 AM
  #628
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
Pretty cool oil analysis for 212k man!
Old Mar 3, 2014 | 07:43 AM
  #629
Glyn M Ruck's Avatar
Super Moderator
Hi Trey ~ Saw PM.
Excellent oil analysis. The slight bit of fuel is from cold weather open loop fully enriched starts.
If there was more fuel I would suspect a dribbling injector but not at this level. You can run one tank with Techron concentrate to make sure if you want to.
That slight clatter with Poly V Belt off could be oil pump chain, or upper timing chain or a slightly gummed up hydraulic lifter. You need to take a stethescope to the engine to pinpoint exactly where it is coming from. The sample shows clearly that there is no abnormal wear coming from any component.
Good for the next 200K miles.
Old Mar 3, 2014 | 03:13 PM
  #630
samaritrey's Avatar
Super Moderator
THE C350
Well that's good to hear I put Techron through as it has been probably 2 years but I never use sub par gas.
As for the noise the timing chain noise would be right behind the front cover but where would I hear a lifter making noise? If it is a lifter how much labor is involved with that vs a timing chain? My father did notice a little oil was burned at startup yesterday morning which is the first time we have seen that which is surprising with that many miles.
Old Mar 3, 2014 | 05:34 PM
  #631
Super Moderator
Yes ~ behind the water pump. Oil pump drive just above the crank. Lifter along the cam covers on each bank.
Lifter is easy on the single cam per bank engines because you just have to lift the rocker shaft.
Old Mar 3, 2014 | 05:55 PM
  #632
samaritrey's Avatar
Super Moderator
THE C350
Ok going to get stethoscope in the next few weeks and check. Midterms this week and also have surgery next week for spring break so doubt I will be working on car much
Thanks Glyn I still need to buy you a beer one of these days!
Old Apr 29, 2014 | 12:14 AM
  #633
Jhartmann3's Avatar
2001 C240, 2011 Honda pilot EX-L RES, 2005 Tundra
Have you had a chance to figure out that noise yet? I've been wondering about it.
Old Apr 29, 2014 | 01:34 AM
  #634
samaritrey's Avatar
Super Moderator
THE C350
Nope ignoring the issue as I am going to trade car in/sell it in next few weeks. About to post about replacement!
Old Apr 29, 2014 | 02:00 AM
  #635
samaritrey's Avatar
Super Moderator
THE C350
So sadly the time has come to move on from my trusty old W203. I have been thinking about this for months now as the timing chain noise as well as having to replacing every dam control arm has been driving me nuts. The car also has the door rust that is common in the early w203s so she is not looking her best anymore anyway. I have been suffering from poor fuel mileage on top of all that so she is old and expensive to keep up. My plan is to get the headlights removed and sold and then sell her as is or trade her in if they give me enough. She is currently at around 214,000 miles and I haven't even driven her in two weeks besides moving around community.
I had been driving the families 2008 G8 GT which is amazingly fast and drives great but interior and fuel mileage leave a lot to be desired but hey its cheap. So as the car was given to me I decided to just trade it in on something that would be safe, get good MPG and had to have onstar/mbrace or some type of crash response system (I drive a lot at night family said it had to have it). Well my dad had a 2005 e320 cdi that I remember got great mileage and had a great interior so I thought maybe that would be ok but I went on the car hunt anyway looking at everything from a new corolla to Mazda cx-5 and many other cars and decided that I would want an 07-09 e320 Bluetec as it would have mbrace and I liked the v6 engine. Well I found a 2008 E320 Bluetec with the P1 package (sadly no bix) that was at a mb dealership and a decent price. Took some negotiating on the trade but today I picked it up. So far it is amazing on the way home from dealership I average 39.6 MPG it was only 15 miles I believe but still that is just amazing! The car inside looks brand new outside has a few cosmetic things but overall it is a great car that has the best maintenance history I have ever seen to be honest. Who changes the rear diff fluid at 48k? Well here is a link to the thread I started in the w211 section to continue this on I will post pics soon in the new thread. https://mbworld.org/forums/e-class-w...ml#post6024736
Old Apr 29, 2014 | 05:10 PM
  #636
samaritrey's Avatar
Super Moderator
THE C350
Also if any one is interested in my BIX let me know I will have them ready in the next week or so hopefully so I can by bix for the w211!
Old Apr 29, 2014 | 05:16 PM
  #637
tommy's Avatar
2004 Civic Si. FWD for the Win!
Well, good luck to you with the new car; think you'll be able to control yourself and not mod it too much? Though to switch cars just so you don't have to buy Glyn a beer seems a bit extreme to me.
Old Apr 29, 2014 | 08:15 PM
  #638
Jhartmann3's Avatar
How much are you looking to get?
Old Apr 29, 2014 | 10:29 PM
  #639
samaritrey's Avatar
Super Moderator
THE C350
Heck if he ever ends up within a few hours of me I will so go meet him and buy him many beers! Thanks its sad to move on but I will still be around don't worry.
I really don't know back in the day a set would go for $1,000 + but I know now that the demand is not what it use to be so maybe like $750 will have to research. Open to offers
Old Apr 30, 2014 | 09:57 AM
  #640
tommy's Avatar
That's what I was afraid of.
Old Apr 30, 2014 | 01:52 PM
  #641
samaritrey's Avatar
Super Moderator
THE C350
You know I haven't banned anyone in a long long time....
Old Apr 30, 2014 | 02:23 PM
  #642
C230 Mulac's Avatar
1999 E320 4matic Wagon, 2005 C55 AMG - sold, 1998 VW Jetta TDI - sold, 2006 C230 Sport - Totaled :(
Hey Trey, just catching up with what's been happening with your car! Glad to see you're enjoying the new purchase.
I had a question for you since you live in NOVA. I've been looking at houses around here and will be purchasing something in the near future. When I do, I can no longer use my parents' address as a permanent residence and will now be subject to the VA emissions inspection
Seeing as I have my secondary cats and resonator removed, but I DO have my primary cats still, I was trying to find out what exactly do they do in Fairfax/Arlington Counties for emissions? I know that in MD they simply plug into the OBDII and if there are no CEL codes that refer to any of the emissions components it passes. Not sure if VA is the same. Any light you can shed on this would be appreciated!
Old Apr 30, 2014 | 03:02 PM
  #643
samaritrey's Avatar
Super Moderator
THE C350
Well we have both state inspection and Emissions inspection.
For state inspection you can get a list of what they check on VA state police website that said I have passed with Xenon kit installed in high beams and my horn unplugged (testing them) and that was at a dealer lol
As for emissions if exhaust is amg quiet then you should be fine as long as no CEL and monitors are ready. I don't believe they put car on lift and even if they do you have cats so it should pass with flying colors.
Old Apr 30, 2014 | 03:07 PM
  #644
C230 Mulac's Avatar
Cool man, thanks for the info!
I already live in VA so I have an up to date state inspection, there's actually some place right off route 50 at 7 corners that I went to last time and it was pretty easy to pass haha. They just don't require emissions in the county I am registered in (Fluvanna County) so I've never had to deal with it.
Old Apr 30, 2014 | 03:48 PM
  #645
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Doooo it.
BTW - Trey is just copying me.
Old May 1, 2014 | 02:18 AM
  #646
samaritrey's Avatar
Super Moderator
THE C350
Thats near Cville right?
Originally Posted by LILBENZ230
Doooo it.
BS I was looking at w211's the same time as you. It is strange that we both ended up with new cars within a week too bad mine is better as always
I was driving down the highway today going 70mph and the only noise I could hear was the cars passing me. Couldn't hear wind, windshield wipers, tires, engine ect... all while getting 37MPG I believe was my average for the day doing ~70% highway
Old May 1, 2014 | 04:03 AM
  #647
LILBENZ230's Avatar
Celine, playing on my COMAND unit via DVD, begs to differ about yours being better. Although that fuel economy is certainly much, much better.
It is stunning to me how quiet the W211 is inside. It's silent. And even with the AMG Sport pack and 18" monoblocks the ride is so good.
Old May 1, 2014 | 04:08 AM
  #648
VVF's Avatar
VVF
BTW, is the diesel engine on these cars more expensive in maintenance, or is it just a myth?
I know about BlueTec fluid, but that's def a DIY thing.
Old May 1, 2014 | 04:24 PM
  #649
W203E35's Avatar
2006 C350 Sport 6MT
Hey Matt and Trey!
You 211 punks..I can't believe you guys changed cars. Congrats!! How have you 2 lovebirds been? Long time no talk. I've been ok. Major maintenance this weekend.
Replace engine plugs
Replace all Engine mounts (including transmission)
Transmission oil and filter change
Engine oil and filter change
Front and rear shock replacement
Front arms (all of it)
Rear arms (all of it)
New tires
Spark plugs
Fuel filter change
Allignment
Car just hit 100k!
Other than being a little wobbly biatch she is doing fine (that'll change this weekend). Looking for a new tune as well and maybe a 55k airbox.
No real update on my end. Have C55 front and rear seats. AMG door panels and dyed headliner and other misc interior parts black. Changed carpet and floor mats to black. Dash to black. Interior is all black now. Hated the damn ash color.
How are the new cars? You guys still have my email? Shoot me an email. Hope there is a Celine Dion concert soon in LA so I can see you guys lol
Old May 1, 2014 | 04:35 PM
  #650
LILBENZ230's Avatar
It's just like old times.. Ahhh, to be home (on the interwebs) again.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
