Metallic scraping
When rolling backwards in reverse, the car would emit a constant metallic scraping noise from the rear. It sounds a lot like a brake pad audible warning, which would make perfect sense. The car has 70,000 on the original rear pads and no rear pad wear sensors. Fine, simple enough, I thought. But if it were a pad wear audible warning, it should do it consistently. In every previous car of mine, once the audible warning starts it will do it every time. The silence tonight from my car is much more disturbing because now I just don't know.
Ideas? Thanks!
If the pads are down to the metal they won't be doing your disc rotors any favours.
I do not feel comfortable unless I know the approx thickness of my brake pads.
Keeping a log of them is a good idea ( Thickness Vs Kms ) & you will be able to forecast the rate of wear .
I think you are out of back pads.
The only other things likely after rear wheels off are:
Wheel not tightened
Hoist damage to an exhaust heat shield through carelessness
Tyre shop lost a lug bolt & replaced with a longer one that is fouling the park brake mechanism (common)
Wheel not tightened
FYI, I think all US spec w203's 2005 and up only have 1 wear sensor on the front pads and 1 in the rear, both on the passenger side.
Wheel not tightened
