Latest Guide to Resetting the Service Indicator - most models
Rating: Thread Rating: 6 votes, 5.00 average.
Old Jan 5, 2010 | 10:31 AM
Glyn M Ruck's Avatar
Super Moderator
Exclamation Latest Guide to Resetting the Service Indicator - most models
I know this is a perennial question with answers dotted all over the forum.
Here collectively in one place.
File Type: pdf
Old Jan 5, 2010 | 11:21 AM
jcnash's Avatar
2002 Mercedes Benz C230 Coupe
Thats awesome!
Thanks Glyn...great to have neat PDF's like these stored locally than having to search the forum for piddly little things like this.
Old Jan 5, 2010 | 04:06 PM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
stickied. thanks, Glyn!
Old Jan 5, 2010 | 04:52 PM
Super Moderator
Only a pleasure - Phil
Old Jan 20, 2010 | 07:02 PM
autojava's Avatar
C280 2006
What/where is R-button?
Hi, Guys:
For model 203 (2006 C280), at step 8, it said
that " push R-button for 3 seconds".
What/where is R-button though?
Old Jan 20, 2010 | 07:17 PM
skittles's Avatar
Moped
Reset button. see the square blips on the pics on the left side of the dash. thats the one.
Old Jan 22, 2010 | 03:28 PM
ChristianJan's Avatar
c230 Kompressor Coupe
Wow, thank you for this. I've been tryin to look for the real way of doin this, and according to my "Multifunction Display," it's been 143 days since I've been overdue.
Old Feb 23, 2010 | 01:52 PM
lazylazybonebon's Avatar
my 203 didnt work with 3 times method, it worked with 1 time hold method tho
Old Feb 23, 2010 | 06:48 PM
akundaria13's Avatar
2005 C230K Sport Sedan
Thanks for the pdf. I saw a youtube video on how to do this, but the pdf, is far more legit.
Old Apr 15, 2010 | 10:50 AM
Soster3333's Avatar
2002 C230 coupe
Why can I not view the PDF's?
Old Apr 15, 2010 | 06:18 PM
Super Moderator
Problem is your end. Opens perfectly - Good Luck!
Old Jun 9, 2010 | 10:15 AM
efzauner's Avatar
2005 C240 2011 R350
this is interesting... but... on my first oil change and service indicator reset. I was able to change the setting of the type of oil used.. from 229.3 or 229.5. I have never been able to get back into that service menu! any ideas? thanks
Old Jun 9, 2010 | 11:27 AM
Super Moderator
OK - Doors closed - Reset button in 7 O'clock position left of speedo (A) might have an 'R' printed on it, On steering wheel overlapping pages (B), button next to it (C), and button on top right hand side of steering wheel (D) - dont touch the phone buttons.
Ignition key to posn 1
Push B till mileage is displayed
Push A 3 times till it beeps
Ignition key to posn 2
Push C till message 'service display' is displayed
Push A once
'Oil type' will display
Push D till you have selected the oil spec you used - choices are 'standard', 'Qual 229.3' or 'Qual 229.5'
Push C
Message 'Confirm oil reset, press R button for 3 seconds
Push A for 3 seconds
Service confirmed will display
Ignition off
Good luck
Old Jul 13, 2010 | 11:46 AM
Taiwanese's Avatar
2003 C230
Saved
Thank you.
Old Sep 17, 2010 | 08:06 AM
Zillarpillow23's Avatar
I'm really glad that I've found this. I remember my service tech dude who works for me on the side, mentioned that this is a big no-no to the consumer. In other words, for tech eyes only. Personally, I like to do my own tweaking and car maintenance. Thank you for this.
Old Sep 18, 2010 | 10:09 PM
Super Moderator
Yeah! - The techs think we are all stupid. Meanwhile with some minor coaching & help from one another on this forum, most of us are fairly capable.
Old Sep 19, 2010 | 08:25 AM
Originally Posted by Glyn M Ruck
Yeah! - Meanwhile with some minor coaching & help from one another on this forum, most of us are fairly capable.
This advice has already saved me thousands of dollars since I bought my car in 2005. It's the reason why I'm proud to be part of this community.
Old Oct 5, 2010 | 02:12 PM
paypaboi's Avatar
03 W203, 13 E350, 13 W204, 14 C218
One Second...
I remember resetting the error code on my car actually once before and I never changed the oil type or all that and the procedure was maybe 5 steps long, what is the difference between that procedure and this procedure?
Old Oct 5, 2010 | 02:32 PM
Super Moderator
Just do this as per pdf. at beginning of thread for service indicator. The other is for oil type change. Your car will be set for 229.5 - leave that alone
https://mbworld.org/forums/attachmen...ator-guide.pdf
Old Nov 18, 2010 | 07:56 PM
mkim331's Avatar
05 C240
How come I dont get the final reset/confirm step? Instead it goes back to service indicator without prompting to reset. Any clue?
Old Nov 18, 2010 | 11:19 PM
Evolved8's Avatar
AMG Fam
Thanks SIR!!
Old Nov 19, 2010 | 06:57 AM
Super Moderator
Sorry - I don't know - never had a problem. Maybe someone else can comment.
Presume you have tried more than once?
Old Nov 20, 2010 | 11:07 PM
jegomes's Avatar
c230 sport
is there some trick for the 2002 sport koup, I have tried multiple times with no avail.
Old Nov 21, 2010 | 06:08 AM
Super Moderator
There are lots of 2002 Coupe's that get it right. PM C230 Sport Coup. He does all his own work on the car & owns a 2002. Ask him if there is a trick with the M111 engine.
Old Nov 22, 2010 | 02:43 PM
jegomes's Avatar
c230 sport
I ended up finding the solution after browsing the forum for a while. I would love to give credit but I cannot remember who the OP was for that forum. Any how I had to turn the key to position 2 then use the page button to get to the service reminder then hold the ILL button down for 10 sec, then it asks if you would like to reset the service interval and you hold the ILL button for 3 sec to confirm. It was quite simple and has been buggin the hell out of me for about 6k now oh well how this helps others out.
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
