recall - camshaft - 2002 W203
Rating: Thread Rating: 5 votes, 5.00 average.
Old Jan 21, 2010 | 11:02 AM
govertime's Avatar
Originally Posted by tommy
Um, SPCL K posted it.
No, SPCL K posted the recall for the camshaft/solenoid recall. I'm inquiring about the thermostat housing leak that HeirKranz refers to.
Old Jan 21, 2010 | 02:02 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Ah, my bad. Carry on!
Old Jan 21, 2010 | 07:11 PM
slackeruf's Avatar
2002 c230k coupe
I haven't received calls on either recalls. Maybe I'll ask the dealer about it when I take my car in for service B.
Old Feb 3, 2010 | 01:05 PM
totita's Avatar
C230 K
Clicking noise
I recently had the dealership perform the Camshaft Solenoid campaign. I'm getting a clicking noise (like a sawing machine) coming from the front of the engine after they replaced the parts. Took the car back and they told me my supercharger belt tensioner is causing the problem. My car has 127K and is a 2002 C 230K. Anybody experienced the same problem?
Old Feb 3, 2010 | 01:48 PM
govertime's Avatar
Make sure they add the isolating wires (aka pigtails, extenders) so you don't run into the same or worse problems down the road.
271-150-27-33
Old Feb 3, 2010 | 02:05 PM
jcnash's Avatar
2002 Mercedes Benz C230 Coupe
Its weird...in Canada they have no clue about these recalls, service bulletins etc.
I called a few dealerships here and they took my VIN# and said theres no pending work on my car. Did you guys have to give them the recall # or the service bulletin # before MB agreed to do the work?
Old Feb 3, 2010 | 02:18 PM
  #32
totita's Avatar
C230 K
271-150-27-33
Based on the working order they did that. But it does not explain the noise. The noise is more prevalent during cold starts. I guess I need to take a look at the car and check where the noise is coming from.
The dealer called me and let me know about the Open campaign.
Old Feb 3, 2010 | 06:19 PM
  #33
samaritrey's Avatar
Super Moderator
THE C350
Open your hood and look to see if is the little black thing near the esp module. it is a valve of some sort that makes a ticking noise.
Old Feb 3, 2010 | 08:54 PM
  #34
jahoo's Avatar
2002 C230 Coupe 1999 Mazda Miata
What is the little black valve near the esp module that ticks? Ours has been ticking rapidly after a drive during the winter months.
Haven't heard anything about a recall, but it would be nice to get a loaner for a day or two while they got it done.
Old Feb 3, 2010 | 09:35 PM
  #35
samaritrey's Avatar
Super Moderator
THE C350
I don't remember what it is called. I think it is something to do with emissions. i know they redesigned the mount for it at some point to try to help isolate the sound but it still made a sound from what i have read. i just ignore mine because i never could find the PN for the redesigned mounts.
Old Feb 3, 2010 | 10:00 PM
  #36
Dr.Fox's Avatar
2013 C300 4Matic Sport
I had this done recently. I took the car in for a catalytic converter replacement and they performed the recall service. It is NOT for the camshaft, it's the solenoid.
Old Feb 3, 2010 | 10:29 PM
  #37
jerryml430's Avatar
2006 c230
so is the recall only for 2002 or what? i have a 2006 c230 and the guy at the shop told me that i need to get my solenoid replace, so i'm just wondering if the 06 are coverd under the recall
Old Feb 4, 2010 | 06:57 AM
  #38
Glyn M Ruck's Avatar
Super Moderator
That is the purge valve. Mount it on rubber to shut it up.
Old Feb 4, 2010 | 07:04 AM
  #39
Super Moderator
Old Feb 4, 2010 | 08:35 AM
  #40
krisv420's Avatar
02 C320 Sedan
Wow everyone seems to be happy that your car is being recalled.. Lol i wouldn't be 2 happy o well have fun in your free loaners =(.. M112 ftw
Old Feb 4, 2010 | 08:40 AM
  #41
tommy's Avatar
As we've seen with Toyota, stepping up to the plate and admitting (and fixing) broken sh*t will always lead to happier customers.
Not sure why you'd be happier with a broken car instead of getting a free fix.
Though this will be my one and only Benz, I'm glad they had a recall. I still think too much stuff goes wrong with them (like my SRS sensor in the passenger's side seat, which is getting replaced now).
  #42
govertime's Avatar
I mentioned the isolating wires not as a possible solution to your noise but just to make sure they did it. They didn't (before the recall campaign) when they replaced my cam sensors and after arguing with SA/manager why its required (since the cam sensor design flaw was not fixed) I finally gave up and bought them elsewhere and added them myself. Of course they're now covered under the campaign.
Actually its a camshaft sensor (which I believe happens to be a mechanical solenoid design, no doubt one of several found in the car).
Old Feb 4, 2010 | 09:35 AM
  #43
krisv420's Avatar
02 C320 Sedan
Bummer to hear about your ride.. Ive only had small issues which should have been done in common maintenance stuff as in new battery plugs and wires oh and 1 stepper motor i fixed, Fuel filter coming soon. But like i said pretty much error free until summer rolls around then my dash can't be seen at all LOL
Old Feb 4, 2010 | 09:51 AM
  #44
tommy's Avatar
I'm with you - as soon as it gets to be 65 degrees or so constantly here, I'm going to replace mine. Have you started looking at replacement cost for the part? I think that it was about a grand at the dealership, but I'm sure it can be had cheaper. Valex bought the entire cluster off ebay and switched the MFD panel, which may be a route I go down.
Old Feb 4, 2010 | 10:22 AM
  #45
krisv420's Avatar
02 C320 Sedan
Ebay is the way to go.. But mine only goes out when its about 80+ outside which makes it 100 million on the inside It isn't to bad yet but it seems like all w203 that are 2004 and older have this issue.
Old Feb 4, 2010 | 12:33 PM
  #46
tommy's Avatar
Just for sh*ts and giggles, looked at the bay. Bought a cluster from a 2003 w/38k miles. So looks like I have a swap to do in June.
Old Feb 4, 2010 | 06:44 PM
  #47
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
If you want company, let me know. I'll need to do the same but would want to see you do it first.
Old Feb 4, 2010 | 07:52 PM
  #48
tommy's Avatar
Sure, that would be no problem. What I'll do before spring is break apart the replacement and document how it was done, then we can crack open the current cluster and replace the MFD.
Old Feb 5, 2010 | 12:41 AM
  #49
krisv420's Avatar
02 C320 Sedan
How much did you get it for? Pm me or post it.. I kinda wanna get the CLK one and mess with it
Old Feb 5, 2010 | 09:44 AM
  #50
tommy's Avatar
$165 (with shipping) - a couple of others were a little cheaper, but this was (at least stated) a lower mile car that it was from. And in my twisted mind, I rationalized that it would be in better shape. I have no idea if that's realistic, but that's my logic, and I'm sticking to it.
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
