Oil change trouble, HELP :)
2K6 C230 Sport
Okay, so I thought I would do my own oil change to save $75.00.
Changed the oil, put exactly 8.5 quarts back in. Changed the oil filter and O-rings.
Now there is a sweaking noise. I thought it was the oil filter. So I pulled it out and noticed that the rod that holds the filter is a little loose. Is that normal? It's really annouying.... Please Help! arghh..
Has anyone else seen this?
2K6 C230 Sport
Great... Then I have no idea what it is. Could someone else please confirm that there should be a little play in the rod in the oil filter houseing?
Its very possible that I may have dripped a little oil on the belt but I cant belive it still be sweaky after a few minutes.
Super Moderator
2007 C230SS; 2014 ML350 BT
2K6 C230 Sport
Well, I woke up this morning and it's still doing it! Looks like it's going to the dealership. God damnit! There goes all the money I saved by doing it myself! This car is rediculious! All I did was a oil change! I've been doing my own for years! Jesus!
Ironic it would happen right after you changed your oil. Mine had the same problem and I think there is a TSB on it. Atleast that's what the dealer told me. Seems like a common problem.
2002 Mercedes Benz C230 Coupe
Hmm..I might actually have the same problem. When its very cold outside (below -10C) and when I start up the car, everytime the car revs around 1500 rpm, I hear a squeaking noise coming from the engine. This happens again at 2000RPM. Goes away when the car warms up a bit. Does that sound familiar?
2K6 C230 Sport
Turns out this is a very common problem. I was told if you drop oil on the belt. Take some soap and clean both sides of the belt.
From now on, if you plan on doing your own oil changes make sure you cover your belts and pullys. I learned my lesson. Well at least I dont have to change my belt for 5 yrs!
2K6 C230 Sport
