M271 Oil Analysis
I'm not sure, amsoil has some euro spec oils and they are generally of higher quality (true synthetic) than most of the approved stuff, here is a link to the oil I was planning on using:
http://www.amsoil.com/catalog.aspx?code=AFLQT-EA
They also make a 5w40 that the local guy stocks so I might get that instead. I've had great luck with amsoil in my vette (not approved for that either
).Also the MANN filter is OEM so you can never go wrong with that
I made them use 0w-40 on my last service after getting way too much clattering at cold start, keeping in mind that my cold starts are 50 deg F.
While AMSOIL's AFL oil is a very good oil, it is not approved for our cars. I am a dealer for AMSOIL and I can tell you that they are in the process of reformulating their 5W-40 European oil to meet 229.5 spec and also reformulating their 5W-40 Heavy Duty Marine Diesel oil to meet 229.51. You should use one of the approved oils in Glyn's Definitive thread here
Ok, ok, you've convinced me, no amsoil until they reformulate
. Could I pull off a 10k change using mobile 1 or castrol? I've always done 5k changes using mobil 1 on my grand am...
I personally ran M1 0W-40 up until last change and have since switch to the Pentosin Pento High 5W-30 from RM European (On the Mercedes ROW approved list, meets 229,5 spec). The reason I switched is Mobil 1 0W-40 seems hard to find in my area, and is usually priced at an outrageous $7.99/quart. 2ea 5 Liter bottles of the Pentosin costs ~$70 shipped from RM European.
I think I'll stick with a 7500 mile change with mobile 1 and a paper mann filter (both available here), it will be less expensive than an amsoil change so it should even out. Does amsoil make transmission and rear diff fluid that will work? If so which part numbers do I need?
Thanks!
