Help
Old 02-14-2010, 12:31 AM
jmarais01's Avatar
2001 C240, 2006 C55 AMG, 2007 Ducati 1098s, 2005 C240 4Matic Wagon
Help
My car has been showing this warning message since I cam back to the cold Cleveland weather. When I was in Florida it showed up only on the coldest days. The seat will not work until i drive the car for a significant time. Does anyone know what this means?
Old 02-14-2010, 12:54 AM
Super Moderator
samaritrey's Avatar
THE C350
That is an interesting error is it in the owners manual any where?
Old 02-14-2010, 01:26 AM
jmarais01's Avatar
I have not seen it in the manual, even the dealership can't figure it out. Also the drivers seat controls work backwards.
Old 02-14-2010, 01:41 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
It sounds to me as if you have some seat switching or limit switch problems.Is there been any water ingress around the seat area. I think the system is being told that the back seat swab has not locked in the correct position.
I would try extending the seat swab to the limit of its travel in both directions to see if it resets.
Old 02-14-2010, 01:47 AM
jmarais01's Avatar
I don't think any water has gotten in. It is strange that it only happens in cold weather though.
Old 02-14-2010, 02:05 AM
acr2001's Avatar
2012 C300 4Matic
I've read about that warning in a manual or document somewhere...
There is/was supposed to be a warning generated when you move your seat on its tracks but don't lock it into place. There is also a steering lock error if you move your steering wheel and do not push the lever back in to lock it. I assumed these warnings were only for vehicles with manually operated steering wheel / seat adjustments. I'm also thinking that they eliminated the sensors for this at some point, because in my 05 if I drive around without the steering wheel locked, I get no warning.
Old 02-14-2010, 02:17 AM
jmarais01's Avatar
Yea, both the steering and seat are powered.
Old 02-14-2010, 09:16 AM
Super Moderator
Glyn M Ruck's Avatar
Likely a microswitch or limiter switch that sticks when cold. Our older cars had all that trickle down stuff from the then S Class that got deleted later. My car even has heated mirrors & headlamp washers in South Africa - I ask you!!!
I would get some electrical spray & spray everything that has a wire going to it under the seat. Do both front seats stick or only the driver's? Seems to be the rake adjustment motor circuit that is out of whack.
010 2039100536 001 SEAT ADJUSTER LEFT
010 2039100636 001 SEAT ADJUSTER RIGHT
015 2039101536 001 L SEAT ADJUSTER LEFT, WITH MEMORY
015 2039101636 001 L SEAT ADJUSTER RIGHT, ON MEMORY
015 2039101536 001 R SEAT ADJUSTER LEFT, WITH MEMORY
015 2039101636 001 R SEAT ADJUSTER RIGHT, ON MEMORY
017 2038203642 001 ELECTRIC MOTOR HEIGHT ADJUSTMENT,LEFT
017 2038203642 001 ELECTRIC MOTOR HEIGHT ADJUSTMENT,RIGHT
017 2038203742 001 L ELECTRIC MOTOR
017 2038203742 001 R ELECTRIC MOTOR HEIGHT ADJUSTMENT
017 2038201242 001 L ELECTRIC MOTOR FORE-AND-AFT ADJUSTMENT
017 2038201242 001 R ELECTRIC MOTOR FORE-AND-AFT ADJUSTMENT
017 2038203842 001 L ELECTRIC MOTOR RAKE ADJUSTMENT
017 2038203842 001 R ELECTRIC MOTOR RAKE ADJUSTMENT
018 2039190114 001 L BRACKET CONTROL UNIT, LEFT
018 2039190114 001 R BRACKET CONTROL UNIT, LEFT
019 2039190214 001 L BRACKET CONTROL UNIT, RIGHT
019 2039190214 001 R BRACKET CONTROL UNIT, RIGHT
020 A2038201526 2118200126 - L CONTROL UNIT
020 2118200126 001 L CONTROL UNIT FRONT SEAT
020 A2038201626 2118200226 - L CONTROL UNIT
020 2118200226 001 L CONTROL UNIT CO-DRIVER'S SEAT
020 A2038201626 2118200226 - R CONTROL UNIT
020 2118200226 001 R CONTROL UNIT CO-DRIVER'S SEAT
020 A2038201526 2118200126 - R CONTROL UNIT
020 2118200126 001 R CONTROL UNIT FRONT SEAT
025 2105403033 001 ELECTRIC CABLE
033 2039183830 001 COVERING RIGHT CUSHION FRAME
035 2108213751 001 L SWITCH LEFT *920
035 2108213851 001 L SWITCH RIGHT *920
035 2108213751 001 R SWITCH LEFT *920
035 2108213851 001 R SWITCH RIGHT *920
040 2039190137 002 SPRING
045 2039190014 002 BRACKET LEFT
045 2039190014 002 BRACKET RIGHT
048 2039190104 001 TAKE-UP DEVICE LEFT, SEAT LEFT
048 2039190204 001 TAKE-UP DEVICE RIGHT, SEAT LEFT
048 2039190104 001 TAKE-UP DEVICE LEFT, SEAT RIGHT
048 2039190204 001 TAKE-UP DEVICE RIGHT, SEAT RIGHT
050 2029900122 008 SCREW M8X28
052 2039190042 001 BEARING INSIDE
053 2039190142 001 BEARING OUTSIDE
055 2039190188 001 L HANDWHEEL *921
055 2039190188 001 R HANDWHEEL *921
065 1409844729 008 SCREW M10X12
070 2039120041 002 CLAMP
070 0039888778 016 CLIP
075 2039180014 004 DOWEL PIN AN BUEGE
075 2039180014 004 DOWEL PIN AT CLAMP
090 2039190021 002 STOP LEFT SEAT ADJUSTMENT
090 2039190021 002 STOP SEAT ADJUSTMENT, RIGHT
095 2039190121 002 STOP LEFT SEAT ADJUSTMENT
095 2039190121 002 STOP SEAT ADJUSTMENT, RIGHT
110 2035450540 001 BRACKET SEAT SEPARATION POINT
120 2035450503 002 COVER
----- 2039120041 002 CLAMP LEFT SEAT ADJUSTMENT
130 2035451840 001 BRACKET SEAT SEPARATION POINT
Old 02-14-2010, 04:36 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Hey my car has a heated driver side mirror (think passenger side is dead but maybe cost cutting?) and heated windshield washers.
Old 02-14-2010, 05:33 PM
Super Moderator
And 1 brake pad sensor Yours is an early facelift car - more seemed to be removed as time went by. We really don't need heated mirrors, headlamp and screen washers in SA. They make real sense in much of the US. I might use my rear screen demister twice a year.
Old 02-14-2010, 06:12 PM
LILBENZ230's Avatar
Do you know if both mirrors are supposed to be heated in a USDM 2005? I wish I knew if the element was dead or if it was just deleted. Either way, my passenger side doesn't heat.
Old 02-14-2010, 06:41 PM
Super Moderator
Matt - pop the mirror cover off. The mirror heater mini spades & wiring is very obvious once off. I have no idea what they have done on US cars.
Old 02-14-2010, 07:03 PM
XsuperbeeX's Avatar
C320 coupe
did somebody swap a coupe seat in your sedan?!?!?!
Old 02-14-2010, 09:52 PM
acr2001's Avatar
2012 C300 4Matic
Yes. Both are supposed to be heated (when the temperature is under ____). My passenger side heated mirror stopped working also. Mirror replaced under warranty - fixed the problem. I think the contacts / leads were corroded.
Old 02-15-2010, 03:38 AM
Super Moderator
They are supposed to come on with the rear screen demister.
Old 02-15-2010, 03:41 AM
LILBENZ230's Avatar
That might be how they work in SA, but in the USA this is not true. The car activates and de-activates them based on outside temp and the driver has no control over it.
Old 02-15-2010, 04:00 AM
acr2001's Avatar
2012 C300 4Matic
I take such pride in saying this because it is so rare that I get to correct you
You are incorrect Glyn.
Maybe its different in the US vs ROW? I can tell you for sure that they come on below a certain temp which is in the manual.
Edit: Nooo! LILBENZ beat me to it.
Old 02-15-2010, 04:26 AM
LILBENZ230's Avatar
ACR you were savoring the moment.
Just giving you a hard time, Glyn. It's interesting that Benz would program things that differently in USA vs ROW,
Old 02-15-2010, 04:56 AM
Super Moderator
No - in ROW they come on when you switch on the rear demister. Same in W204 including American models the 204 forum informs me. See recent post by RLE. He claims his previous US C320 (W203) also switched in same as ROW with rear demister.
This of course might be something that changed in later production. It's not reflected as a facelift change though.
Hey! - I don't mind being wrong for a specific market - I **** you off & learn at the same time That's what I call bang for the buck
Personally I would rather be able to turn them on & off.
Some perverse people think I'm always correct. I'm not! - I try desparately to be - typical Virgo - but I'm human & make mistakes. If I realise the mistake I will always try & correct it - I suffer no saving of face issues. If I've been a BF I will be the first to admit it. See Origins of M271 thread LOL.
Old 02-15-2010, 05:54 AM
acr2001's Avatar
2012 C300 4Matic
I was only joking - you're usually the voice of reason. You should take my jokes as a compliment.
Old 02-15-2010, 12:40 PM
Super Moderator
I do
Old 02-15-2010, 02:05 PM
jmarais01's Avatar
That's funny, I am actually from Cape Town, been living in the States for 12 years.
Old 02-15-2010, 05:41 PM
Super Moderator
samaritrey's Avatar
THE C350
well glyn is right for my car at least i have to hit the button for the rear screen to get the mirrors on. btw they get pretty dam hot i had them on the other day and felt to see how warm they get they are like little heaters lol.
Old 02-15-2010, 07:50 PM
Super Moderator
Mnr. Marais - I wondered about your origins. Yeah - I lived in Dallas for many years & then Bay Area SFO - Marin County - then Sydney Aus & all over Asia & finally home.
Hope we can help you from Cape Town with your seat.
Old 02-15-2010, 11:08 PM
acr2001's Avatar
2012 C300 4Matic
They must have a bunch of engineers running around in the factory playing duck duck goose with the cars. All of these tiny differences in programming between random models drives me crazy. The last time this came up it was about the "low coolant level" warning, which apparently comes up on certain US models when the wiper fluid is low! On others you get the proper wiper fluid warning...
Quick Reply: Help
