2004 C230 driver side door does not lock
Old Feb 23, 2010 | 11:54 AM
n_akkawi's Avatar
2013 E350 sports
Smile 2004 C230 driver side door does not lock
Is there a special lubricant that can be used to help get the lock to work. I do not want to replace the lock, since I want to upgrade to E class. Will WD40 work!!
Old Feb 23, 2010 | 12:17 PM
jcnash's Avatar
2002 Mercedes Benz C230 Coupe
You first have to identify what the problem is before spraying lubricant into the mechanism. Does this happen all the time or only after the car has been out in the cold etc?
When you try and lock the car, do you hear any sound coming from inside the drivers door panel? If you dont you probably have a busted actuator and any amount of lubricant isn't going to help.
If the actuator tries to move the locking levers and fails, then I would recommend trying the lock-de-icing solution spray first.
Old Feb 24, 2010 | 10:51 AM
n_akkawi's Avatar
2013 E350 sports
I think I did not explain the problem properly. Sorry about that. I had this issue happen to me about four month ago. When I try to lock the car with the remote key, the knob will bounce up and down, until it finally locks. it makes a clinking noise, but it locks. So I spayed the lock, with WD40, and the problem went away after one day. then two weeks ago the same things started to happen again, and some time the lock do not lock. So I use the key to lock the driver side door. You can see the knob on the driver door setting higher than the others. As I said I don't want to replace the lock, since I want to upgrade to E class. Hope this will help.
Old Feb 24, 2010 | 12:00 PM
Smallbodybenz's Avatar
2002 c230 coupe
it sounds like your door lock actuator is going bad day by day. I had a similar prob in my BMW .. It started off working sometimes to not working at all.
Old Feb 24, 2010 | 06:46 PM
n_akkawi's Avatar
2013 E350 sports
any ideas!!
Old Feb 24, 2010 | 08:38 PM
govertime's Avatar
any ideas!!
search 'actuator' in the w203 sub-forum.
Old Feb 24, 2010 | 09:59 PM
samaritrey's Avatar
Super Moderator
THE C350
I had two in my car start doing this one last year and another this year. they both did it for about two weeks then one day started working fine and have since.
Old Feb 24, 2010 | 10:37 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
The bouncing lock thing was pretty common on early W203s. I've seen a lot of posts on here about it, including fixes.. just have to search around.
Old Feb 25, 2010 | 04:18 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
search door-lock pogo.
99% you will need to replace the actuator. no other way around it, sorry.
Old Feb 25, 2010 | 06:12 PM
Glyn M Ruck's Avatar
Super Moderator
+1 - Also WD40 is a hopeless lubricant. More propellant than light oil.
