M272 oil consumption
Old Feb 28, 2010 | 01:47 PM
nathandimond's Avatar
2006 Volvo S40 T5 AWD 6spd
I know the M271 engines have issues with consuming oil/low oil level warnings but should I be worried about oil problems(leaks, burning, etc.) if I will have a M272 engine?
Old Feb 28, 2010 | 04:45 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
I wouldn't say any of these cars have issues consuming oil.
Old Feb 28, 2010 | 08:12 PM
Glyn M Ruck's Avatar
Super Moderator
Benz engines consume very little oil. Don't even worry about it. The 272 is bullet proof.
Old Feb 28, 2010 | 08:23 PM
e1000's Avatar
a quarter mile at a time
some early m272 engines were reported to have some oil consumption issues. I haven't heard of any widespread issues in the C class however. One off issues can happen to any engine.
Old Feb 28, 2010 | 08:54 PM
W203E35's Avatar
2006 C350 Sport 6MT
The m272 is pretty good with oil consumption. Me personally I had an oil leak from the cam plugs and I thought it was consuming oil. The dealer even did an oil consumption test and said it was fine. Which it wasn't...basically after visiting dealer 8 times and warranty almost ending I did my own test. I started to feel around the engine then I found the oil leak.
After the fix (knock on wood) I have never had a problem with the oil light coming on.
Old Dec 29, 2022 | 04:44 PM
BenzClass's Avatar
280c
Hi,
That sounds like the problem I might be having.
Would you be able to explain precisely which seals?
Old May 24, 2023 | 04:00 PM
NY450SEL's Avatar
S4/M3
Thanks, all. This is the wife's GLK350. I do always check and mark the dip stick length. Just ordered 5 quarts M1 0W-40 for the GLK and the BMW and will give it one last try with the evacuator and some of these tips before I contract out the work.
