Right front wheel fluid leak??
Old Apr 6, 2010 | 02:31 AM
dbboy's Avatar
'03 C240
I just noticed what appears to be a fluid leak under the right front tire of my 03 C240. Now I'm worried it could be a nasty brake problem (caliper?) Anyone experience this? Am I dealing with a costly fix? Just bought the car and wondering. Thanks.
Old Apr 6, 2010 | 03:21 AM
e1000's Avatar
a quarter mile at a time
What kinda fluid? I sound like a broken record but it's probably your lower control arm bushing that has cracked open.
Old Apr 6, 2010 | 03:39 AM
dbboy's Avatar
'03 C240
It seems to be a somewhat clear odorless fluid with some viscosity..? Can't tell right for sure as it's dark now. Wouldn't a brake warning light come on if it was brake related? If it's the bushing, is this a costly fix? So many questions.. Sorry for being such a noob and really appreciate your answers.
Old Apr 6, 2010 | 08:47 AM
AdidasC230's Avatar
Saab 900 SE
Im with E1000 now that you said its clear fluid, brake fluid in a car of your age would have a reddish hue to it, so a bushing sounds right, its a bit involved to fix but do-able. Would take a few hours, I did it on a focus and it wasn't to bad. Dont know what part are but Im sure some one will chime in who does! Good luck
Old Apr 6, 2010 | 10:52 AM
e1000's Avatar
If you want to replace the bushing without replacing the whole control arm, you'll need to find someone with a press to remove the old bushing and push in the new one.
Brake fluid has hopefully been replaced at least once, so there's no telling what color it is. If it was brake fluid you will absolutely get a low brake fluid warning.
Old Apr 6, 2010 | 11:28 AM
glocati's Avatar
2016 GLE 350
You may want to check coolant level as well. Some benz coolant will appear somewhat clear. There is a cover/splash guard under the whole engine-underside of the front of the car. Often times fluid from elsewhere in the engine compartment can run over to the lowest point and drain in an odd spot giving you a false clue...how big is the spot/puddle ? A control arm bushing will leak, but not a huge amount....
Just saying, check all fluids and see if there are any leaks under the hood from elsewhere.
Old Apr 6, 2010 | 02:09 PM
dbboy's Avatar
'03 C240
Checked this morning and saw that it indeed has some "color" to it. Attached is a phone pic of it. Ignore the dark spots as they are from an older vehicle. Still no warning light, btw and can't see any visible leak under the hood. Thanks so much for your help.
Old Apr 6, 2010 | 10:04 PM
jimbonnet's Avatar
2002 E320 Wagon 2007 C230 Sport
Do you have a strut leaking?
