CARBON FIBER AMG SHIFT PADDLES in W203
Old Apr 22, 2010 | 09:43 PM
c32///'s Avatar
C32 AMG x 2
hey guys, im planning on retrofitting amg shift paddles onto my c320 and if it works eventually on my e500...heres the link if anyones down too : http://cgi.ebay.ca/ws/eBayISAPI.dll?...#ht_6328wt_941
i know some people who have done it with the switch/module on the steering wheel but me and my buddy are going to try and wire it straight to the gear shifter -/+. Im gunna try to splice the wires for -/+ and make a two way connector and plug those ones in too. Hopefully it works, im going to order these tommrow so if anyone has comments, tips or anything let me know now please. Thanks.
Old Apr 22, 2010 | 10:15 PM
XsuperbeeX's Avatar
C320 coupe
look at the lcd screen... airbag malfunction
Old Apr 23, 2010 | 12:47 AM
HellsAngel's Avatar
03 c320 coupe
LOL. i wonder if someone is going to buy it with those pictures !
Old Apr 23, 2010 | 05:24 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
you can buy the oem ones for $100. The part numbers are on the c32 forum. You also need a harness or a relay board to trick the pressure sensor that the shifter is being moved. Its been done on the c300 and charger forums.
Old Apr 23, 2010 | 10:00 AM
zerocover's Avatar
2007 C280 4Matic
Why did no one tell me about this?
I demand paddle shifters!! Are there any how-too's? Can we make a real legitimate thread about it?
For some reason I was under the impression that we needed to reprogram the ecu.
Old Apr 24, 2010 | 03:55 PM
c32///'s Avatar
C32 AMG x 2
thats just because the airbag is removed. those pics are demonstrating the diffrent gears ex. D1, D2, D3..etc., not really a good example though.
Old Apr 24, 2010 | 03:56 PM
c32///'s Avatar
C32 AMG x 2
oem for 100?!?!?!?!?!?! WHERE , i called MB and they want 299 for the c63 ones and 180 for the slk55 ones. Im in Canada if you know where i can get em cheper it would be a big help
Old Apr 24, 2010 | 05:33 PM
OneOfaKindTrini's Avatar
Nike Turbo Shox
That's gonna throw some codes, i'd bet on that.
Old Apr 25, 2010 | 11:16 AM
TemjinX2's Avatar
basically its the slk55 ones. there part numbers are on the thread i listed below. Yes to do it properly you need a New sam and programming and etc.
If you have a steptronic transmission where you can shift the gear using the shifter, you can tap the + and - wires of that shifter with the paddles.
The relay board just tricks the computer into thinking you shifted up or down using the shifter when your really using the paddles.
No one has wrote a straight diy on the mb forum. there is a pretty detailed diy on the Lxforums where a lot of c300 and charger members have been successful. Certain c300 and charger models uses the same mercedes transmission as some of the older w203's.
I'm not sure if it'll work with the 7g.
https://mbworld.org/forums/c32-amg-c...-c32-w203.html
Old Apr 25, 2010 | 02:49 PM
c32///'s Avatar
C32 AMG x 2
true true, where do i find the relay board at? (canada)
Old Apr 25, 2010 | 04:51 PM
TemjinX2's Avatar
its on the link that pshek posted on the thread link. the guy is just custom making them. Just message him and he can send you one.
Old Apr 25, 2010 | 05:19 PM
c32///'s Avatar
C32 AMG x 2
do you know which one exactly it is the 37 $ or 65$? Thnks
Old Apr 25, 2010 | 07:04 PM
timmynabenz's Avatar
2006 C230 SS, 2006 S500, 2008 CLS550 Lorinser
im interested in doing this too.
ive gone through all the threads and im still about lost as to what exaclty we would need, which sutff will work, etc
can somebody please just take 5 minutes and spell out in Lame man's terms what we need and where to get it if you know? Also, im would trust myself to do a DIY, any members on here in Socal that oculd do this?
Old Apr 25, 2010 | 11:50 PM
TemjinX2's Avatar
basically you need the $65 one. You need the paddle shifters. If you a c55 or c55 steering wheel its a direct swap. You just punch out the button shifters and bolt on the paddles.
The c32 you need the relay board to trick the pressure sensor that the shifters is being moved and you tap the paddles to the up shift and down shift wires on the shifter.
At least thats my understanding from what i read on the LX forums. There is a diy on there with a lot of pics.
atl
Old Apr 26, 2010 | 04:52 PM
Nike Turbo Shox
So this is mainly to manipulate the computer?
