How to set clock with Comand?
You have "lost" your ability to set the time how you want (5 / 10 minutes ahead for example) if you have now installed COMAND.
This radio is out of a G-Class but I don't see why that should make any difference.
I have the same exact problem; I just retrofitted a W209 Comand into my W209 and I can't set the clock.
I read in the manual that when the Comand is reset it defaults to the Central timezone. I can only assume it is set to standard time which would explain why our clocks are two hours behind.
Until I read your post I was thinking my timeset option was disabled because I haven't had the cluster coded, but reading that yours has been coded and you're still unable to set the time is not very reassuring.
I am going to try to set my analog clock and see if that helps -- I'll report back my findings.
http://www.benzworld.org/forums/audio-telematics-forum/1529557-unable-set-time-my-comand-retrofit-new-post.html
There is hope for us 91RS!
