4matic Front drive shafts - service or run it till it fails?
Old May 10, 2010 | 04:25 PM
Kar don's Avatar
Mercedes-Benz
Indy is quoting around 1000 bux to replace the 4 boots and service the joint, dealer is about 1100 bux. Car is a 2003 with 75k miles on it and the boots are torn.
I'm wondering if i should dump all that money to service a 7 year old drive shaft or should i just wait till they start to go bad and just buy new shafts (with new boots on em obviously). I can get the new shafts for about 650 each.
What do you think?
Old May 10, 2010 | 05:07 PM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
What do you think?
Man, that really sounds outrageous for CV boot replacement. But, most CV Shafts will go to 150K, and some beyond if the boot is always kept intact. Hard call, that is for sure. I have over 200K on Jeep Grand Cherokee on the original CV shafts with no issues, and I replaced the boots and regreased at ~110K.
Old May 10, 2010 | 07:08 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
I always thought CV boots and whatnot are "lifetime" as long as they're not damaged? Kinda like the wheel bearings..
Old May 10, 2010 | 08:03 PM
contact148's Avatar
2003 c240 4matic wagon
my 2003 c240 4 matic wagon also has both cv boots torn they have been for a year at least now Im going to probably just get the boots replaced as its too much $$ for new shafts if I bother i may just run them till they die
my car has 118,000km
Old May 10, 2010 | 11:55 PM
Kar don's Avatar
Mercedes-Benz
Well I was told its a big job to do the inner boots as there is no tool to pull off the clamps on the inner boots. The boots themselves are around 100 bucks total, they want 3 hours per side on labor however.
Old May 11, 2010 | 12:15 AM
mleskovar's Avatar
'17 Jaguar XF
...What do you think?...
$650X2 + $1000 labor = $1650 after they fail, or $1000 before they fail. No contest, fix them now or always worry about failure that could do more damage than just shafts. How much do you think a front wheel drive trans axle costs for your car?
Old May 11, 2010 | 10:25 AM
Kar don's Avatar
Mercedes-Benz
Going to do the boot replacement, will keep this updated.
Old May 11, 2010 | 05:34 PM
contact148's Avatar
was at my local dealer today picking up a part and asked about the boots
this is in canada! boot kit each $37.00 A 220 330 01 85
labour he said was about 2 hours a side give or take a bit (this included cleaning repacking and installing the boots
service manager said they usually lasted a long time and if the joints are not clicking yet replace the boots before they do as its cheaper then doing the shafts
Ill look at doing mine myself or wait till the fall and let MB do it
Old May 25, 2010 | 11:20 PM
Kar don's Avatar
Mercedes-Benz
So I just had the boots completed. Cleaned the joints and repacked with the grease supplied in the kit. Technician said joint looked to be in good condition. Total damage was around 640 bucks parts and labor for all 4 front boots.
Old May 25, 2010 | 11:29 PM
mleskovar's Avatar
'17 Jaguar XF
Good choice, now you can drive in peace.
Old May 25, 2010 | 11:58 PM
FraKctured's Avatar
W203-4M W163
+1
Prevention is the best medicine. Fix it before it screws you.
Old May 26, 2010 | 05:42 AM
Glyn M Ruck's Avatar
Super Moderator
Really good choice
Old Jun 3, 2010 | 05:53 PM
Kar don's Avatar
Mercedes-Benz
yah i figured the car is running excellent right now, might as well keep it that way.
Old Jun 3, 2010 | 05:58 PM
KA8's Avatar
KA8
2002 E430
Can't Indys do this? They do it all the time on fwd vehicles. $640 to replace boots seem outrageus to me. You can probably get it done for under $250 max.
Old Jun 4, 2010 | 12:28 AM
Kar don's Avatar
Mercedes-Benz
this was done by an indy with parts purchased @ cost. MB OEM parts.
